    Volvo on Call
    34 Posts 4 Posters 14.5k Views 4 Watching
      sdetweil @MZ-BER
      @mz-ber so the regular expression isn’t finding your text
      /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm
      I use this for building and testing rejects
      https://regex101.com/
      MZ-BERM 1 Reply Last reply
      • MZ-BERM
        MZ-BER @sdetweil
        @sdetweil Yes, I also checked that with regex101. Can I just parse in the details I have?
        listResult: function(output) {
            var re = B-PY 186 (V90) XVASS123345
        S 2 Replies Last reply
          sdetweil @MZ-BER
          @mz-ber the regex returns an array of matched things
            sdetweil @MZ-BER
            @mz-ber i think the regex is not expecting the 186
            try ths one
            /^([^ ]+)\s.*\(([^\/]+)\/([^\)]+)\)$/gm
            start of string ^
            capture up to the 1st space ([^ ]+)
            skip everything to (and including) the open paren \s.*(
            get the two things in the parens, separated by /, not including the parens
            capture up to the slash ([^/]+)
            skip the slash /
            capture up to the close pareen ([^)]+)
            skip the close paren )
            end of string $
            • MZ-BERM
              MZ-BER @sdetweil
              @sdetweil Your one is not working. Here are the details I try to get:
              B-PY 186 (V90/2019) YV1PWAKUDK1XXXXXX
              I also played a bit with the expression and removed the white space:
              before:
                  var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm
              after:
                  var re = /^([^]+)\s\(([^\)]+)\)\s([^]+)$/gm
              That is working based on regex101 and I dont get the error anymore. But nothing is loaded into the MM
                sdetweil @MZ-BER
                @mz-ber the regex has to return 3 items
                • MZ-BERM
                  MZ-BER @sdetweil
                  @sdetweil Right! And I guess it is doing so? Or am I wrong? b5cae454-af0f-4887-abbb-bd6117d3fe82-image.png
                    sdetweil @MZ-BER
                    @mz-ber i do not know what the module is expecting or its process
                    it also does a voc dashboard…
                    and parses that…
                    • MZ-BERM
                      MZ-BER @sdetweil
                      @sdetweil Yes, I guess voc list should work. But really quick to voc dashboard
                      That is the list I’m getting
                      B-PY 186 Position             : (52.55352783203125, 13.4XXXXXXXXXX6, '2022-03-06 20:20:32+01:00', None, None)
                      B-PY 186 Door lock            : Locked
                      B-PY 186 Heater               : Off
                      B-PY 186 Odometer             : 34484 km
                      B-PY 186 Trip meter 1         : 131 km
                      B-PY 186 Trip meter 2         : 1 km
                      B-PY 186 Fuel amount          : 40 L
                      B-PY 186 Fuel level           : 72 %
                      B-PY 186 Fuel consumption     : 9.9 L/100 km
                      B-PY 186 Range                : 440 km
                      B-PY 186 Average speed        : 31 km/h
                      B-PY 186 Last trip            : 2022-03-06 20:20:32+01:00
                      B-PY 186 Engine               : On
                      B-PY 186 Door lock            : On
                      B-PY 186 Hood                 : Closed
                      B-PY 186 Tailgate             : Closed
                      B-PY 186 Front left door      : Closed
                      B-PY 186 Front right door     : Closed
                      B-PY 186 Rear left door       : Closed
                      B-PY 186 Rear right door      : Closed
                      B-PY 186 Front left window    : Closed
                      B-PY 186 Front right window   : Closed
                      B-PY 186 Rear left window     : Closed
                      B-PY 186 Rear right window    : Closed
                      B-PY 186 Front right tyre     : OK
                      B-PY 186 Front left tyre      : OK
                      B-PY 186 Rear right tyre      : OK
                      B-PY 186 Rear left tyre       : OK
                      B-PY 186 Washer fluid         : OK
                      B-PY 186 Brake Fluid          : OK
                      B-PY 186 Service              : OK
                      B-PY 186 Bulbs                : OK
                      B-PY 186 Doors                : Closed
                      B-PY 186 Windows              : Closed
                      With the regular expression /^([^\s]+)\s([\w\s]+)\:\s(.+)$/gm it is not perfectly matching the groups:
                      B-PY 186 should be always in group 1. Do you have an idea to adjust the expression?
                      • MZ-BERM
                        MZ-BER @MZ-BER
                        I got it to work! Finally.
                        The whole problem was my licence plate. The regular expression wasn’t able to grab the right groups. Thank you @sdetweil for helping me to investigate.
                          sdetweil @MZ-BER
                          @mz-ber how did u fix the regex?
                          i would change the 1st capture to
                          in the list
                          ^([^\(]+)\s  =capture up to but not including (
                          in the scan = capture 1st 8 chars
                          how long is a license number? always 8?
                          ^(.{8})\s
                          • MZ-BERM
                            MZ-BER @sdetweil
                            @sdetweil said in Volvo on Call:
                            German Number Plates can have the following format:
                            ABC-D 123
                            ABC-DE 12
                            AB-C 123
                            A-BC 1234
                            I’m using this regex to get the variations: ^([A-Z]{1,3}-[A-Z]{1,2}\s[0-9]{1,4})\s([\w\s]+)\:\s(.+)$
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @MZ-BER
                              @mz-ber you are missing some german number plates:
                              AB-CD 123E electric vehicles
                              AB-CD 123H oldtimer, but probably not relevant because they do not have the digital information :D
                              The other exceptions are not relevant for private vehicles.
                              • MZ-BERM
                                MZ-BER @strawberry 3.141
                                @strawberry-3-141 True! Good catch! So I guess every variation can also have an E at the end. Do you know if there is a whitespace between the last digit and the E? If it is without a space, this will work:
                                ^([A-Z]{1,3}-[A-Z]{1,2}\s[0-9,E]{1,5})\s([\w\s]+)\:\s(.+)$
                                • strawberry 3.141S
                                  @mz-ber officially there is no space in between the numbers and the suffix, but I work for a provider of a mobility platform and I can tell you that users frequently come up with their own formats like AB-CD123 (no space) or AB-CD 123 E (extra space).
                                  Your regex works, but it would also cover some invalid plates like the following in case you want a challenge to improve your regex:
                                  • AB-CD 0E5E8
                                  • The number can’t start with a 0
                                  • The E can only be in the end not mixed with the numbers
