    Volvo on Call
    34 Posts 4 Posters 14.3k Views 4 Watching
      sdetweil @MZ-BER
      @mz-ber yes executing just like on console
      nothing built in to show results.
      but you could add a
      console.log(sdo)
      before the call to listResults()
      and see it where u start mm
      npm start
      it should be the same outout
      MZ-BERM 1 Reply Last reply Reply Quote 0
      • MZ-BERM
        MZ-BER @sdetweil
        @sdetweil Alright, I added the console.log before the call listResult() and it is getting the details from my car. I feel sooo close to get this running but I dont know where it is stuck. :anguished_face:
        Is maybe the regex search not getting the details viewed?
        listResult: function(output) {
            var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm
          sdetweil @MZ-BER
          @mz-ber so the regular expression isn’t finding your text
          I use this for building and testing rejects
          https://regex101.com/
          • MZ-BERM
            MZ-BER @sdetweil
            @sdetweil Yes, I also checked that with regex101. Can I just parse in the details I have?
                var re = B-PY 186 (V90) XVASS123345
              sdetweil @MZ-BER
              @mz-ber the regex returns an array of matched things
                sdetweil @MZ-BER
                @mz-ber i think the regex is not expecting the 186
                try ths one
                /^([^ ]+)\s.*\(([^\/]+)\/([^\)]+)\)$/gm
                start of string ^
                capture up to the 1st space ([^ ]+)
                skip everything to (and including) the open paren \s.*(
                get the two things in the parens, separated by /, not including the parens
                capture up to the slash ([^/]+)
                skip the slash /
                capture up to the close pareen ([^)]+)
                skip the close paren )
                end of string $
                • MZ-BERM
                  MZ-BER @sdetweil
                  @sdetweil Your one is not working. Here are the details I try to get:
                  B-PY 186 (V90/2019) YV1PWAKUDK1XXXXXX
                  I also played a bit with the expression and removed the white space:
                  before:
                  after:
                      var re = /^([^]+)\s\(([^\)]+)\)\s([^]+)$/gm
                  That is working based on regex101 and I dont get the error anymore. But nothing is loaded into the MM
                    sdetweil @MZ-BER
                    @mz-ber the regex has to return 3 items
                    • MZ-BERM
                      MZ-BER @sdetweil
                      @sdetweil Right! And I guess it is doing so? Or am I wrong? b5cae454-af0f-4887-abbb-bd6117d3fe82-image.png
                        sdetweil @MZ-BER
                        @mz-ber i do not know what the module is expecting or its process
                        it also does a voc dashboard…
                        and parses that…
                        • MZ-BERM
                          MZ-BER @sdetweil
                          @sdetweil Yes, I guess voc list should work. But really quick to voc dashboard
                          That is the list I’m getting
                          B-PY 186 Position             : (52.55352783203125, 13.4XXXXXXXXXX6, '2022-03-06 20:20:32+01:00', None, None)
                          B-PY 186 Door lock            : Locked
                          B-PY 186 Heater               : Off
                          B-PY 186 Odometer             : 34484 km
                          B-PY 186 Trip meter 1         : 131 km
                          B-PY 186 Trip meter 2         : 1 km
                          B-PY 186 Fuel amount          : 40 L
                          B-PY 186 Fuel level           : 72 %
                          B-PY 186 Fuel consumption     : 9.9 L/100 km
                          B-PY 186 Range                : 440 km
                          B-PY 186 Average speed        : 31 km/h
                          B-PY 186 Last trip            : 2022-03-06 20:20:32+01:00
                          B-PY 186 Engine               : On
                          B-PY 186 Door lock            : On
                          B-PY 186 Hood                 : Closed
                          B-PY 186 Tailgate             : Closed
                          B-PY 186 Front left door      : Closed
                          B-PY 186 Front right door     : Closed
                          B-PY 186 Rear left door       : Closed
                          B-PY 186 Rear right door      : Closed
                          B-PY 186 Front left window    : Closed
                          B-PY 186 Front right window   : Closed
                          B-PY 186 Rear left window     : Closed
                          B-PY 186 Rear right window    : Closed
                          B-PY 186 Front right tyre     : OK
                          B-PY 186 Front left tyre      : OK
                          B-PY 186 Rear right tyre      : OK
                          B-PY 186 Rear left tyre       : OK
                          B-PY 186 Washer fluid         : OK
                          B-PY 186 Brake Fluid          : OK
                          B-PY 186 Service              : OK
                          B-PY 186 Bulbs                : OK
                          B-PY 186 Doors                : Closed
                          B-PY 186 Windows              : Closed
                          With the regular expression /^([^\s]+)\s([\w\s]+)\:\s(.+)$/gm it is not perfectly matching the groups:
                          B-PY 186 should be always in group 1. Do you have an idea to adjust the expression?
                          • MZ-BERM
                            MZ-BER @MZ-BER
                            I got it to work! Finally.
                            The whole problem was my licence plate. The regular expression wasn’t able to grab the right groups. Thank you @sdetweil for helping me to investigate.
                              sdetweil @MZ-BER
                              @mz-ber how did u fix the regex?
                              i would change the 1st capture to
                              in the list
                              ^([^\(]+)\s  =capture up to but not including (
                              in the scan = capture 1st 8 chars
                              how long is a license number? always 8?
                              ^(.{8})\s
                              • MZ-BERM
                                MZ-BER @sdetweil
                                @sdetweil said in Volvo on Call:
                                German Number Plates can have the following format:
                                ABC-D 123
                                ABC-DE 12
                                AB-C 123
                                A-BC 1234
                                I’m using this regex to get the variations: ^([A-Z]{1,3}-[A-Z]{1,2}\s[0-9]{1,4})\s([\w\s]+)\:\s(.+)$
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @MZ-BER
                                  @mz-ber you are missing some german number plates:
                                  AB-CD 123E electric vehicles
                                  AB-CD 123H oldtimer, but probably not relevant because they do not have the digital information :D
                                  The other exceptions are not relevant for private vehicles.
                                  • MZ-BERM
                                    MZ-BER @strawberry 3.141
                                    @strawberry-3-141 True! Good catch! So I guess every variation can also have an E at the end. Do you know if there is a whitespace between the last digit and the E? If it is without a space, this will work:
                                    ^([A-Z]{1,3}-[A-Z]{1,2}\s[0-9,E]{1,5})\s([\w\s]+)\:\s(.+)$
                                    • strawberry 3.141S
                                      @mz-ber officially there is no space in between the numbers and the suffix, but I work for a provider of a mobility platform and I can tell you that users frequently come up with their own formats like AB-CD123 (no space) or AB-CD 123 E (extra space).
                                      Your regex works, but it would also cover some invalid plates like the following in case you want a challenge to improve your regex:
                                      • AB-CD 0E5E8
                                      • The number can’t start with a 0
                                      • The E can only be in the end not mixed with the numbers
