    PM2 startup Autostart didn't work
    3 Posts 3 Posters 3.2k Views 4 Watching
    • Z
      zimmerjo1
      This post is deleted!
      • romainR
        romain
        I think the issue is that the command you need to run isn’t “sudo pm2 startup”.
        If you run “pm2 startup”, the real command you’ll need to run appear
        pi@raspberrypi:~ $ pm2 startup
        [PM2] Init System found: systemd
        [PM2] You have to run this command as root. Execute the following command:
        sudo env PATH=$PATH:/usr/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
        johnnyboyJ 1 Reply Last reply
        Reply Quote 1
        • johnnyboyJ
          johnnyboy @romain
