    Calendar module shows entries outer range
    12 Posts 2 Posters 3.1k Views 2 Watching
    • M
      Monkye
      Hello Together,
      My MM use the standard calendar modules. And the data come from an import via vdirsyncer ICS file. The calendar shows all events with the same day include from outside of the defined range in config file.
      Parameters in CONFIG.JS:
      MaximumNumberOfDays: 30
      MaximumEntries: 10
      GetRelative: 0
      Example:
      at date 2022/03/07 will show
      • Birthday of Jan-Peter Friday 03/11/2022
      • Party at Rico Friday 06/11/2022
      • Wedding anniversary Sunday 08/13/2022
      It looks like a filter is „ill“…
      Any ideas?
      THX, Uwe
        sdetweil @Monkye
        @monkye thanks for the ics file…
        reviewing the events, this is a bug in the RRULE processor the calendar module uses
        but not our code
        https://github.com/jakubroztocil/rrule/issues/275
        if you remove the BYMONTHDAY=11
        RRULE:FREQ=YEARLY;WKST=MO;INTERVAL=1;BYMONTHDAY=11
        then it works as expected
        just for info, this issue was opened on Sep 5, 2018 and has not yet been fixed
        so I am not hopeful on a more timely resolution
          sdetweil @Monkye
          @monkye can you paste the cal config here
          make the url xxxxx
          remember to use the code block markers
          • M
            Monkye @sdetweil
            @sdetweil No problem, the url’s are not a secret :-).
            	position: "top_left",   // This can be any of the regions. Best results in left or right regions.
            	fetchInterval: 240000,
            		maximumNumberOfDays: 30,
            		maximumEntries: 10,
            		getRelative: 0,
            					symbol: "birthday-cake",
            					url: "http://localhost:8080/modules/default/calendars/1.ics",
            					symbol: "calendar-check-o",
            					url: "https://www.zaoe.de/ical/8231/_1-3-4-6/23/"
            • M
              Monkye @Monkye
              And here a picture - SORRY german only
              The Lines marking the events out of date range
              red: december
              blue: august
              yellow: july
                sdetweil @Monkye
                @monkye but those say Friday and Sunday…
                show me the vevent from the ics
                use the url
                curl -sL url >somfile.ics
                then edit the ics w a text editor, it’s just a text file
                each event does
                BEGIN:VEVENT
                END:VEVENT
                • M
                  Monkye @sdetweil
                  @sdetweil Can I sent you a board mail?
                    sdetweil @Monkye
                    @monkye u can send text to my email. same userid at gmail
                    • M
                      Monkye @sdetweil
                      @sdetweil I sent you the mail to your account. Thank you in advance
                        sdetweil @Monkye
                        but not our code
                        • M
                          Monkye
                          Many, many THANKS to you. I‘m happy that you resolve this problem
                          • M
                            Monkye @Monkye
                            Workaround:
                            A little script solve the problem. In the ICS-file at HOME directory will the „BYMONTHDAY“ part deleted.
                            sed -r 's/INTERVAL=1;BYMONTHDAY=[0-9][0-9]?/INTERVAL=1/g' /
                            ~/mycalendar.ics
                              sdetweil @Monkye
                              @monkye nice!
