    MMM-PythonPrint customisation
    46 Posts 5 Posters 22.7k Views 5 Watching
    • karsten13K Online
      karsten13 @diemen112
      @diemen112 said in MMM-PythonPrint customisation:
      I have added - /usr/bin/python3:/usr/bin/python3 to the docker compose
      this will not work. You have to use the fat image, see my post above (Apr 11)
        diemen112
        Thank you for the help,
        I made it work with adding some python dependent directory’s to the docker-compose file
        • kayakbabeK Offline
          kayakbabe
          Sam,
          Thank you for this MMM-PythonPrint. More than the sample module this really helped me follow how to wrap my head around how the script.js node_helper and anything else work together. The way you worded the variables and the input and output text really made sense and made it easy to follow what is happening. I am learning a lot. Again, Thank you.
          Kelly
            sdetweil @kayakbabe
            @kayakbabe awesome, glad it helped!
            kayakbabeK 1 Reply Last reply Reply Quote 0
              kayakbabe @sdetweil
              @sdetweil I’m looking at the configuration variable repetative and trying to figure out what it is for.
              is this correct logic for true and false?
              repetative: true
              if your python script runs in a loop forever by itself so the spawn in node helper will just keep its connection to the python script open
              repetative: false
              if your python script runs one time, and you need node_helper to keep spawning over and over so you can get the info from the python script over and over
                sdetweil @kayakbabe
                @kayakbabe so , maybe your python script starts and runs, prints one line, and ends. current temp is x
                is that all you want your module to present, one line?
                or do you want the output every few seconds minutes
                this is repetative:false, but my module will rerun the script every cycle time milliseconds
                but some python scripts do that internally.
                print, sleep, print, sleep, print, sleep, print…
                this is repetative: true
                my module will just start the python script
                there are two different ways to capture the output
                should have named parm
                script_is_long_running
                I provided a sample of each
                also, in many cases, you are using someone else’s script and don’t have control over how it works, and don’t want to rewrite it
                • 3 / 3
