    MMM-PythonPrint customisation
    46 Posts 5 Posters 26.0k Views 5 Watching
      sdetweil @RobCee
      @RobCee ok, fixed, tested… sorry again
      git pull
      R 1 Reply Last reply
        RobCee @sdetweil
        @sdetweil - apologies not necessary - I am just happy you are able to look at it.
        Hurrah! It works!
          diemen112
          i have also the MM os and i try to make it work
          I have added - /usr/bin/python3:/usr/bin/python3 to the docker compose
          and now i have the error
          [15.07.2022 14:23.42.599] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
          [15.07.2022 14:23.42.602] [LOG]   PythonPrint spawning /opt/magic_mirror/modules/MMM-PythonPrint/print_test.py using python3
          [15.07.2022 14:23.42.686] [LOG]   PythonPrint program error=Could not find platform independent libraries <prefix>
          Could not find platform dependent libraries <exec_prefix>
          Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
          Fatal Python error: initfsencoding: unable to load the file system codec
          ModuleNotFoundError: No module named 'encodings'
          Current thread 0x76fb37a0 (most recent call first):
          a played around with adding $PYTHONHOME to env but without any result
          does anyone know a work around to find the libraries?
          S karsten13K 2 Replies Last reply
            sdetweil @diemen112
            @diemen112 I think this answers
            https://askubuntu.com/questions/905372/could-not-find-platform-independent-libraries-prefix
            running under docker is a fun experience?
            did u install python as part of the container startup?
            • karsten13K
              karsten13 @diemen112
              @diemen112 said in MMM-PythonPrint customisation:
              this will not work. You have to use the fat image, see my post above (Apr 11)
                diemen112
                Thank you for the help,
                I made it work with adding some python dependent directory’s to the docker-compose file
                • kayakbabeK
                  kayakbabe
                  Sam,
                  Thank you for this MMM-PythonPrint. More than the sample module this really helped me follow how to wrap my head around how the script.js node_helper and anything else work together. The way you worded the variables and the input and output text really made sense and made it easy to follow what is happening. I am learning a lot. Again, Thank you.
                  Kelly
                    sdetweil @kayakbabe
                    @kayakbabe awesome, glad it helped!
                    kayakbabeK 1 Reply Last reply
                    • kayakbabeK
                      kayakbabe @sdetweil
                      @sdetweil I’m looking at the configuration variable repetative and trying to figure out what it is for.
                      is this correct logic for true and false?
                      repetative: true
                      if your python script runs in a loop forever by itself so the spawn in node helper will just keep its connection to the python script open
                      repetative: false
                      if your python script runs one time, and you need node_helper to keep spawning over and over so you can get the info from the python script over and over
                        sdetweil @kayakbabe
                        @kayakbabe so , maybe your python script starts and runs, prints one line, and ends. current temp is x
                        is that all you want your module to present, one line?
                        or do you want the output every few seconds minutes
                        this is repetative:false, but my module will rerun the script every cycle time milliseconds
                        but some python scripts do that internally.
                        print, sleep, print, sleep, print, sleep, print…
                        this is repetative: true
                        my module will just start the python script
                        there are two different ways to capture the output
                        should have named parm
                        script_is_long_running
                        I provided a sample of each
                        also, in many cases, you are using someone else’s script and don’t have control over how it works, and don’t want to rewrite it
                        • 3 / 3
