    3 tries 3 fails Raspberry b+
    28 Posts 7 Posters 25.5k Views 7 Watching
    • AlvingerA Offline
      Alvinger @infamoustiggr
      @infamoustiggr
      I didn’t fiddle that much with the mirror pi. But ahead of that I’ve been doing quite some fiddling with Pis in general so I didn’t start from scratch.
      To help you with troubleshooting:
      After installing DietPi and rebooting you are presented with the dietpi-software screen:
      0_1488462696670_upload-e5c282b6-f86e-4f85-9db8-c09d2112e649
      Look under “Software Optimized” and “Software Additional” and make sure that NONE of the options are selected, you want an install that is as clean as possible.
      Under DietPi-Config make sure that Autostart is set to option 0 (default):
      0_1488462810956_upload-7d9332c2-e5a0-4048-9a38-cd6b58a09246
      Change directory to /root and install MagicMirror according to instructions in the README.
      Following my instructions above to install all systemd scripts and their helpers. My /root contains the following:
      0_1488463243912_upload-a81285c4-984c-490f-9115-d51ae96b7284
      Stop magicmirror service (just to make sure it isn’t running) with the command:
      systemctl stop magicmirror.service
      Start the magicmirror interactively by running node serveronly from the MagicMirror directory. You should see something similar to this:
      root@mirrortest:~/MagicMirror# node serveronly
      Starting MagicMirror: v2.1.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: MMM-WunderGround
      Module helper loaded: MMM-ResRobot
      Module helper loaded: MMM-NetworkScanner
      All module helpers loaded.
      Starting server op port 80 ...
      Server started ...
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-WunderGround
      MMM-WunderGround helper started ...
      Starting module: newsfeed
      Connecting socket for: MMM-ResRobot
      Starting node_helper for module: MMM-ResRobot
      Connecting socket for: MMM-NetworkScanner
      Starting module: MMM-NetworkScanner
      Ready to go! Please point your browser to: http://localhost:80
      If any errors are shown, investigate them.
      Now that MagicMirror is running it’s time to move on to the browser part.
      Stop MagicMirror with ctrl+C and start the service with systemctl start magicmirror.service.
      Make sure browser and matchbox are stopped by running the commands:
      systemctl stop kioskbrowser.service
      systemctl stop matchbox.service
      Start matchbox with the command systemctl start matchbox.service. Check that it started ok with systemctl status matchbox.service. If not investigate.
      Once you get this far the “only” thing left to check is the midori browser. As you don’t have an X Display on the console it is slightly trickier. Let me know if/when you made it this far and we’ll take it from there.
      • I Offline
        infamoustiggr
        Ah… Found it thanks to the checking…
        Node.js:339
        Throw err;
        Error: Cannot find module ‘wtf-8’
        Then a long list of different places that I’m guessing it’s where it’s missing…
        I’ll have a blast at this for a bit. If it continues to fail so absolutely, maybe I’ll have to restart my bluetooth lawnmower project…
        AlvingerA 1 Reply Last reply Reply Quote 0
        • AlvingerA Offline
          @infamoustiggr
          Try installing wtf-8 module by running the command npm install wtf-8 from the MagicMirror directory.
            Doublefire.Chen @infamoustiggr
            @infamoustiggr Hello, may I ask you that did you make it? I also want to install MM on B+. Now the new board is so expensive that I just want to use my old B+ to do this awesome project.
              sdetweil @Doublefire.Chen
              @Doublefire-Chen last update was 5 years ago… so, unlikely to be helpful.
              try my script. it’s probably the only hope. arm6l aren’t supported much anymore
                Doublefire.Chen @sdetweil
                @sdetweil I have a idea. I have a linux server. I can use docker to install MM on my server and B+ open the browser with full screen to display info after I set port forwaring.
                  @Doublefire-Chen that works too. but don’t need port forwarding…
                  if u look in my run-start.sh script, u will see the parms I use to launch chromium to look like electron full screen.
                    @sdetweil Yes, you are right. The port forwarding is not needed.
                    • 3 / 3
