    Change Folder of Logs of PM2 and NPM
    11 Posts 2 Posters 5.8k Views 2 Watching
    • thgmirrorT Offline
      thgmirror
      Does anybody know how to change the location of the above mentioned folders? I would like to move them to var/log/
      Thank you in advance
      Thomas
        sdetweil @thgmirror
        @thgmirror you could make a linked folder from their orignal place to /var/log
        see the ln command
        thgmirrorT 1 Reply Last reply Reply Quote 0
          thgmirror @sdetweil
          @sdetweil Thank you for your reply, but I prefer to store the log-files physically at var/log.
          I currently use var/log as a RAMDisk, because I normally don’t need log-files. So I avoid a lot of write access to the SD-card, it is faster and safer for the SD…and after a reboot, everything is fine:-)
          My attempt is, to do this for npm and PM2-logs, too.
          As far as I know, I can start PM2 with parameters -o and -e and the new foldernames, but they destroyed my installation. Btw., how do you start PM2 in your script? I would like to add the parameters so it is automatically connected after reboot.
          Thomas
            sdetweil @thgmirror
            @thgmirror no… you misunsderstand the point
            make a folder in /var/log where u want them to BE
            then in the users home folder create a ‘fake’ .pm2 folder for the pm2 stuff
            which points to the /var/log folder using the ln command
            the pm2 app will be happy and NEVER know that the REAL location is /var/log
            thgmirrorT 1 Reply Last reply Reply Quote 1
              thgmirror @sdetweil
              @sdetweil Ah, OK, I will give it a try:-)
                sdetweil @thgmirror
                @thgmirror in the users home foder
                # get into the users home folder
                cd ~
                # move the .pm2 folder to /var/log, pick a name
                mv .pm2 /var/log/pm2.real
                # make a link to it from users home folder
                ln -s  /var/log/pm2.real .pm2
                oops, edited ln…
                target <- link
                from /var/log
                drwxrwxr-x 5 sam sam 4096 Apr 9 10:29 .pm2/
                then in home folder
                ls .pm2 will show files
                ls -laF
                will show that .pm2 is a link (and where to)
                lrwxrwxrwx 1 sam sam 13 Apr 9 10:31 .pm2 -> /var/log/.pm2/
                  thgmirror @sdetweil
                  @sdetweil but you know, a RAMDisk is volatile, I can’t copy something to a RAMDisk in forehand…it is gone after a reboot.
                    sdetweil @thgmirror
                    @thgmirror then u will have to create target folder on boot…
                    note that pm2 stores config info in there too(the jobs it manages) … so it MUST be persistent
                    but you could just link the logs folder from the users real .pm2 folder (the stuff that is volatile…)
                    well, logs are useful but…
                      thgmirror @sdetweil
                      @sdetweil and where is the PM2 start?
                      Of course it must be persistant, but I don’t want to change the location of the PM2-configuration.
                        sdetweil @thgmirror
                        @thgmirror someplace in the .pm2 folder… no idea myself…
                        the .pm2/logs folder I know
                        never examined the others
                          sdetweil @thgmirror
                          @thgmirror and there is a $HOME/.npm folder for npm, but I have no idea what all is stored there, and what needs to be persistent and not
