    Help I need the MMM-MplayerRadio recipe for GA
    15 Posts 5 Posters 5.9k Views 4 Watching
    • N
      negrito Project Sponsor
      I would like to use MMM-GoogleAssistant to command MMM-MplayerRadio,.
      Does anyone happen to have a recipe for GoogleAssistant?
      Thanks you in advance.
      • swvalentiS
        swvalenti Project Sponsor
        https://forum.bugsounet.fr/category/135/mmm-googleassistant
        • N
          negrito Project Sponsor @swvalenti
          @swvalenti
          I’ve been busy making something like that, using the recipe.template.js. But I’m not a programmer. This is what I made. The MMM-MPlayerRadio module works fine with controls from the screen, but I want to call it with GA. for example: Jarvis “play radio latina”, Jarvis…“play next”, Jarvis…“stop radio”, Jarvis…“previous radio”. Put the recipe in the GA recipe folder and added it to the config.js at GA recipe. But I need help with this? :downcast_face_with_sweat:
          /**  GoogleAssistant for MMM-MplayerRadio  **/
          /**  recipe.template.js  **/
          /**  @negrito  **/
          var recipe = {
            transcriptionHooks: {
              /* EN Language */
              "START_RADIO" : {
                pattern : "music play",
                command: "RADIO_PLAY"
              "STOP_RADIO" : {
                pattern : "radio stop",
                command: "RADIO_STOP"
              "RADIO_PAUSE" : {
                pattern: "radio pause",
                command: "RADIO_PAUSE"
              "RADIO_NEXT" : {
                pattern: "radio next",
                command: "RADIO_NEXT"
              "RADIO_PREVIOUS": {
                pattern: "radio previous",
                command: "RADIO_PREVIOUS"
            commands: {
              "START_RADIO": {
                notificationExec: {
                  notification: "MMM_RADIO-PLAY"
                soundExec: {
                  chime: "open"
              "STOP_RADIO": {
                notificationExec: {
                  notification: "MMM_RADIO-STOP"
                soundExec: {
                  chime: "close"
              "PAUSE_RADIO": {
                notificationExec: {
                  notification: "MMM_RADIO-PAUSE"
              "NEXT_RADIO": {
                notificationExec: {
                  notification: "MMM_RADIO-NEXT"
              "PREVIOUS_RADIO": {
                notificationExec: {
                  notification: "MMM_RADIO-PREVIOUS"
          exports.recipe = recipe
          S R 2 Replies Last reply Reply Quote 0
            sdetweil @negrito
            @negrito you’ve sorta got the voice/command/notification upsidedown
            the notification is “RADIO_PLAY”
            not “MM_RADIO_PLAY”
            so the ‘command’ should be MM_RADIO_PLAY
            which is referenced from the transcription section
            same for all the others
            • R
              Ray @negrito
              @negrito I can give you a copy of mine if you like.
              I’m using Google assistant version 3
              • N
                negrito Project Sponsor @Ray
                @Ray
                Yes please @Ray ,
                I will be very grateful if you give me a copy. Thank you very much in advance.
                Kind regards,
                Negrito
                • R
                  Ray @negrito
                  @negrito so are you looking to play your own music or actually radio stations.
                  I have actually both. That worked pretty well
                  • R
                    Ray @negrito
                    @negrito Here is my radio set up
                    with my personal choices of radio stations.
                    I only have a couple right now
                    var recipe = {
                        "80+103.7 iHeartRadio From:tuneIn.com": {
                          pattern: "Turn the radio on to 103",
                          command: "103"
                        "Radio.net 106.9 KFRC": {
                          pattern: "Turn the radio on to 106",
                          command: "106"
                        "Radio.net 107.7 FM KSAN": {
                          pattern: "Turn the radio on to 107",
                          command: "107"
                        "radio1": {
                          pattern: "metti radio 1",
                          command: ""                   // command line.
                        "radioanni90": {
                          pattern: "metti radio anni 90",
                          command: ""
                        "radio105": {
                          pattern: "metti radio 105",
                          command: ""
                        "rds": {
                          pattern: "metti rds",
                          command: ""
                        "rtl1025": {
                          pattern: "metti rtl",
                          command: ""
                        "radiodj": {
                          pattern: "metti radio dj",
                          command: ""
                      commands: {
                        "103": {
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://cdn-profiles.tunein.com/s33596/images/logod.jpg?t=162569",
                                link: "https://n24a-e2.revma.ihrhls.com/zc4342?TGT=TuneIn&maxServers"
                          soundExec: {
                            chime: "open"
                       "106": {
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://www.radio.net/images/broadcasts/01/97/29350/c300.png",
                                link: "https://19803.live.streamtheworld.com/KFRCHD2.mp3"
                          soundExec: {
                            chime: "open"
                       "107": {
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://www.radio.net/images/broadcasts/12/ce/29264/c300.png",
                                link: "https://15363.live.streamtheworld.com/KSANFM.mp3"
                          soundExec: {
                            chime: "open"
                        "": {                    // This must match what's in the command line.
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://www.di-ma.info/radio/radio1.png",
                                link: "http://icestreaming.rai.it/1.mp3"
                          soundExec: {
                            chime: "open"
                          functionExec: {
                            exec: () => {
                              module.radioCommand({
                                img: "https://www.di-ma.info/radio/r90.jpg",
                                link: "http://mp3.hitradiort1.c.nmdn.net/rt190swl/livestream.mp3"
                          soundExec: {
                            chime: "open"
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://www.di-ma.info/radio/r105.jpg",
                                link: "http://icecast.unitedradio.it/Radio105.mp3"
                          soundExec: {
                            chime: "open"
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://www.di-ma.info/radio/rds.png",
                                link: "https://icstream.rds.radio/rds"
                          soundExec: {
                            chime: "open"
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://www.di-ma.info/radio/rtl1025.png",
                                link: "https://streamingv2.shoutcast.com/rtl-1025"
                          soundExec: {
                            chime: "open"
                          functionExec: {
                            exec: () => {
                              this.radioCommand({
                                img: "https://www.di-ma.info/radio/radiodj.png",
                                link: "http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/master.m3u8"
                          soundExec: {
                            chime: "open"
                    Let me know if you want the other one that will play your personal music
                    • N
                      @Ray
                      @Ray Thank you very much I will give it a try
                      Best rgards,
                      • R
                        Ray @negrito
                        @negrito hope it works out for you. Happy to assist
                        • N
                          @Ray
                          Hello @Ray
                          Unfortunately this recipe doesn’t work, but thanks anyway.
                          R S 2 Replies Last reply Reply Quote 0
                          • R
                            Ray @negrito
                            @negrito sorry to hear that you do have version 3 of Google assistant
                            is that right
                              sdetweil @negrito
                              @negrito as written the recipe takes a specific voice command
                              to tune a specific station…
                              did u modify the voice command and/or station info , or trying to use it as provided?
                              if as is, you have to say
                              assistant/jarvis/… “Turn the radio on to 103”
                              right?
                              • bugsounetB
                                bugsounet Banned
                                Because I’m kind sometime…
                                I found this in archived GA repo
                                • R
                                  Ray @sdetweil
                                  @sdetweil sorry it took so long to reply back. I’ve been kinda busy.
                                  So yes, if you want to listen to the radio station 103 you would say
                                  Jarvis Turn the radio on to 103
