    Help I need the MMM-MplayerRadio recipe for GA
    15 Posts 5 Posters 5.0k Views 4 Watching
      Ray @negrito
      @negrito I can give you a copy of mine if you like.
      I’m using Google assistant version 3
      • N Offline
        negrito Project Sponsor @Ray
        @Ray
        Yes please @Ray ,
        I will be very grateful if you give me a copy. Thank you very much in advance.
        Kind regards,
        Negrito
          Ray @negrito
          @negrito so are you looking to play your own music or actually radio stations.
          I have actually both. That worked pretty well
            Ray @negrito
            @negrito Here is my radio set up
            with my personal choices of radio stations.
            I only have a couple right now
            var recipe = {
              transcriptionHooks: {
                "80+103.7 iHeartRadio From:tuneIn.com": {
                  pattern: "Turn the radio on to 103",
                  command: "103"
                "Radio.net 106.9 KFRC": {
                  pattern: "Turn the radio on to 106",
                  command: "106"
                "Radio.net 107.7 FM KSAN": {
                  pattern: "Turn the radio on to 107",
                  command: "107"
                "radio1": {
                  pattern: "metti radio 1",
                  command: ""                   // command line.
                "radioanni90": {
                  pattern: "metti radio anni 90",
                  command: ""
                "radio105": {
                  pattern: "metti radio 105",
                  command: ""
                "rds": {
                  pattern: "metti rds",
                  command: ""
                "rtl1025": {
                  pattern: "metti rtl",
                  command: ""
                "radiodj": {
                  pattern: "metti radio dj",
                  command: ""
              commands: {
                "103": {
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://cdn-profiles.tunein.com/s33596/images/logod.jpg?t=162569",
                        link: "https://n24a-e2.revma.ihrhls.com/zc4342?TGT=TuneIn&maxServers"
                  soundExec: {
                    chime: "open"
               "106": {
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://www.radio.net/images/broadcasts/01/97/29350/c300.png",
                        link: "https://19803.live.streamtheworld.com/KFRCHD2.mp3"
                  soundExec: {
                    chime: "open"
               "107": {
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://www.radio.net/images/broadcasts/12/ce/29264/c300.png",
                        link: "https://15363.live.streamtheworld.com/KSANFM.mp3"
                  soundExec: {
                    chime: "open"
                "": {                    // This must match what's in the command line.
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://www.di-ma.info/radio/radio1.png",
                        link: "http://icestreaming.rai.it/1.mp3"
                  soundExec: {
                    chime: "open"
                  functionExec: {
                    exec: () => {
                      module.radioCommand({
                        img: "https://www.di-ma.info/radio/r90.jpg",
                        link: "http://mp3.hitradiort1.c.nmdn.net/rt190swl/livestream.mp3"
                  soundExec: {
                    chime: "open"
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://www.di-ma.info/radio/r105.jpg",
                        link: "http://icecast.unitedradio.it/Radio105.mp3"
                  soundExec: {
                    chime: "open"
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://www.di-ma.info/radio/rds.png",
                        link: "https://icstream.rds.radio/rds"
                  soundExec: {
                    chime: "open"
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://www.di-ma.info/radio/rtl1025.png",
                        link: "https://streamingv2.shoutcast.com/rtl-1025"
                  soundExec: {
                    chime: "open"
                  functionExec: {
                    exec: () => {
                      this.radioCommand({
                        img: "https://www.di-ma.info/radio/radiodj.png",
                        link: "http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/master.m3u8"
                  soundExec: {
                    chime: "open"
            exports.recipe = recipe
            Let me know if you want the other one that will play your personal music
            • N Offline
              @Ray
              @Ray Thank you very much I will give it a try
              Best rgards,
                Ray @negrito
                @negrito hope it works out for you. Happy to assist
                • N Offline
                  @Ray
                  Hello @Ray
                  Unfortunately this recipe doesn’t work, but thanks anyway.
                  R S 2 Replies Last reply Reply Quote 0
                    Ray @negrito
                    @negrito sorry to hear that you do have version 3 of Google assistant
                    is that right
                      sdetweil @negrito
                      @negrito as written the recipe takes a specific voice command
                      to tune a specific station…
                      did u modify the voice command and/or station info , or trying to use it as provided?
                      if as is, you have to say
                      assistant/jarvis/… “Turn the radio on to 103”
                      right?
                      • bugsounetB Offline
                        bugsounet Banned
                        Because I’m kind sometime…
                        I found this in archived GA repo
