    Problem with Google generated .ics link
    30 Posts 2 Posters 11.3k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @ankonaskiff17
      @ankonaskiff17 @sdetweil
      That Holiday calendar has a huge amount of garbage associated with it as an aside but if newest is at top its just a lot more of that null business.
      Scroll down you get to that error associated with google calendar that one time then a ton of garbage associated with the holiday calendar.
      S ankonaskiff17A 2 Replies Last reply Reply Quote 0
        sdetweil @ankonaskiff17
        @ankonaskiff17 weird… i don’t see that
          @sdetweil All that garbage associated with Holiday calendar is being pulled from the CalendarLabs site but since MM is loading it in list format it just gets lost in the ether?
            @ankonaskiff17 no idea, still debugging
              @ankonaskiff17 ok, can recreate… was testing on 2.18 … which didn’t fail…
              so that points to the node-ical lib which was changed for this release…
              ankonaskiff17A 1 Reply Last reply Reply Quote 0
                @sdetweil You have any thoughts/ideas about what is going on?
                EST5EDT looks like some sort of mash up of Eastern Standard Time and Eastern Daylight Time and your node-ical comment look like a more complex issue. Are they intertwined?
                Neither of the two would be in my control in just dropping a Google generated URL in the config file.
                  @ankonaskiff17 can u look at the entry in google calendar and see what the timezone setting is?
                  how did u create that entry? phone, tablet, computer???
                    @sdetweil Per Google the only way to get the links is via the PC/Laptop Google Calendar. In their help links they spell that out pretty explicitly and that is how I did it and have always done it. The url generated on settings page is pretty straightforward with only possible error being if you choose public or private url.
                    As far as time zone, I’ve attached an image but in screen capture the top Primary was and is correct just as shown. The secondary was some oddball city with time being GMT - 7 hours vs primary being GMT -4 so I changed secondary to be another GMT-4 city.
                    I looked last night, but on phone, and it showed correct time.
                    Is the 5 in EST5EDT what happens when toggling between EST & EDT & GMT? I dont have any idea if EU has an equivalent to daylight savings timeTime Zone .jpg
                      @ankonaskiff17 said in Problem with Google generated .ics link:
                      yes, other countries have DST/STD time shifts…
                      typically the TZID is specified like this
                      TZID=America/Barbados
                      or
                      TZID=America/Chicago
                      I see that your ICS has a special definition of the TZID EST5DST
                      BEGIN:VTIMEZONE
                      TZID:EST5EDT
                      X-LIC-LOCATION:EST5EDT
                      BEGIN:DAYLIGHT
                      TZOFFSETFROM:-0500
                      TZOFFSETTO:-0400
                      TZNAME:EDT
                      DTSTART:19700308T020000
                      RRULE:FREQ=YEARLY;BYMONTH=3;BYDAY=2SU
                      END:DAYLIGHT
                      BEGIN:STANDARD
                      TZOFFSETFROM:-0400
                      TZOFFSETTO:-0500
                      TZNAME:EST
                      DTSTART:19701101T020000
                      RRULE:FREQ=YEARLY;BYMONTH=11;BYDAY=1SU
                      END:STANDARD
                      END:VTIMEZONE
                      none of the code we have or use processes the TZ definitions. so that may be the issue…
                      everything uses the IANA tz definitions.
                      https://www.iana.org/time-zones
                      i wrote the mapping code for special MS definitions to IANA definitions used in node-ical and mm calendar
                      (from this table https://secure.jadeworld.com/JADETech/JADE2020/OnlineDocumentation/content/resources/encyclosys2/jadetimezone_class/ianawindowstimezonemapping.htm)
                      but nothing accepts the EST5DST format,and neither read the timezone definitions in the ICS file.
                        @sdetweil Sent you an email
