    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 22.4k Views 3 Watching
    • E Offline
      ember1205
      If I boot up my RPi, it auto-launches the desktop but nothing loads for MM. If I check the status (pm2 status mm), it shows as running since boot.
      If I restart MM (pm2 restart mm), all is well.
      Where do I even begin to try and understand what’s going on?
        sdetweil @ember1205
        @ember1205 do the curl again
          sdetweil @ember1205
          @ember1205 pm2 logs --lines=100
          to dump out the logs
          may want to pm2 flush to empty, and then reboot to get current info
          • E Offline
            ember1205
            Thanks - I had dug into them and found nothing of any use. Still, I went ahead and purged the logs and tried again.
            I’m getting VERY weird behavior with zero consistency. I booted the mirror yesterday a half dozen different times and I was getting a split between not launching the browser and launching the browser but landing on “Web Store” and “Magic Mirror” icons in the center with no content.
            First boot attempt today resulted in the browser not only launching but correctly bring up my configured mirror and content. Today’s logs show no indication of a PM2 daemon being started, but this WAS being shown in the logs yesterday (very strange).
            Executed a powerdown of the Pi, powered it off, waited about ten minutes, powered it back on. Made it all the way to bringing up the desktop and then … nothing. No entry in the log that it was starting Chromium. Executing “pm2 restart mm” brought the browser up but it landed again on the “Magic Mirror” and “Web Store”.
            This is frustrating.
              sdetweil @ember1205
              @ember1205 yes, that chromium desktop thing is a problem…
              I posted an issue on MM github back in january.
              stop MM…
              then
              cd ~
              rm -rf .config/chromium
              rm -rf .config/electron
              note the dot in front of config…
              (one of those commands might fail with not found)
              then restart mm
              another user also cannot get rid of that. he went to midori.
              I added midori support for the run-start.sh script…
              i haven’t seen this except on armv6l devices… (pi0w/pi1)
              E 2 Replies Last reply Reply Quote 0
              • E Offline
                ember1205 @sdetweil
                What’s the goal?
                I have .config/chromium and .config/Electron with the latter being two years old and the former having a current date (I switched to Chromium because Electron was a ton of trouble).
                This is all on Bullseye which I upgraded to (yeah, yeah, I know… don’t upgrade, fresh install, not supported, etc.). Up to that point, it was on Buster and ran fine.
                Incidentally… I have an automated routine to bring the RPi down gracefully based on a virtual switch setting on a home automation controller. Here’s the gist:
                • Set the virtual switch to “on”
                • Every five minutes, the RPi queries the status of the switch
                • If the switch is set to “1” (on), it launches a script with sudo
                The script does the following:
                • Using cec-client, it puts the Soundbar into Standby (off)
                • Using cec-client, it puts the TV into standby (off)
                • Sets the status of the virtual switch to “1” (on) to ensure that any other items that trigger of the state change of that switch will run as well
                • Sets the status of the virtual switch to “0” (off)
                • Sends an IFTTT message using WebHooks / curl
                • Does a “shutdown now”
                If I comment out the cec commands, it starts up incorrectly. If I manually just do a “shutdown now” and boot it back up, it starts up incorrectly.
                  sdetweil @ember1205
                  @ember1205 what pi?
                  if armv6l, use the legacy buster image… do NOT upgrade to bullseye
                  uname -a will show u
                  the deletes were to wipe out any saved config data for the browser so it would come up clean…
                  (not desktop.) supposedly
                  • E Offline
                    ember1205 @sdetweil
                    armv71
                    I’ve modified my shutdown control to stop MM, wipe the .config/chromium directory, and then power off. This allows chromium to load the correct information when it does finally launch.
                    There still remains an issue, however, with the run-start.sh script actually launching the chromium browser on boot. The log file basically ends with “0|mm | Ready to go! Please point your browser to: http://0.0.0.0:8080” on boot up. “pm2 restart mm” correctly brings everything up every time.
                    Here’s what the log looks like when it boots:
                    0|mm       | > magicmirror@2.13.0 start
                    0|mm       | > ./run-start.sh
                    0|mm       |
                    0|mm       | [2022-05-10 14:30:59.191] [LOG]    Starting MagicMirror: v2.13.0
                    0|mm       | [2022-05-10 14:30:59.207] [LOG]    Loading config ...
                    0|mm       | [2022-05-10 14:30:59.222] [LOG]    Loading module helpers ...
                    0|mm       | [2022-05-10 14:31:00.614] [LOG]    Initializing new module helper ...
                    0|mm       | [2022-05-10 14:31:00.617] [LOG]    Module helper loaded: MMM-ImagesPhotos
                    0|mm       | [2022-05-10 14:31:00.625] [LOG]    No helper found for module: alert.
                    0|mm       | [2022-05-10 14:31:00.733] [LOG]    Initializing new module helper ...
                    0|mm       | [2022-05-10 14:31:00.735] [LOG]    Module helper loaded: updatenotification
                    0|mm       | [2022-05-10 14:31:00.741] [LOG]    No helper found for module: clock.
                    0|mm       | [2022-05-10 14:31:01.058] [LOG]    Initializing new module helper ...
                    0|mm       | [2022-05-10 14:31:01.060] [LOG]    Module helper loaded: calendar
                    0|mm       | [2022-05-10 14:31:01.068] [LOG]    No helper found for module: currentweather.
                    0|mm       | [2022-05-10 14:31:01.072] [LOG]    No helper found for module: weatherforecast.
                    0|mm       | [2022-05-10 14:31:01.074] [LOG]    All module helpers loaded.
                    0|mm       | [2022-05-10 14:31:02.616] [LOG]    Starting server on port 8080 ...
                    0|mm       | [2022-05-10 14:31:02.665] [LOG]    Server started ...
                    0|mm       | [2022-05-10 14:31:02.680] [LOG]    Connecting socket for: MMM-ImagesPhotos
                    0|mm       | [2022-05-10 14:31:02.683] [LOG]    Starting node helper for: MMM-ImagesPhotos
                    0|mm       | [2022-05-10 14:31:02.685] [LOG]    Connecting socket for: updatenotification
                    0|mm       | [2022-05-10 14:31:02.693] [LOG]    Connecting socket for: calendar
                    0|mm       | [2022-05-10 14:31:02.700] [LOG]    Starting node helper for: calendar
                    0|mm       | [2022-05-10 14:31:02.702] [LOG]    Sockets connected & modules started ...
                    0|mm       | [2022-05-10 14:31:02.704] [LOG]
                      sdetweil @ember1205
                      @ember1205 ok,
                      lets edit run-start.sh t- enable some more debugging
                      in the 1st line add -x to the change the 1st line to
                      #!/bin/bash -x
                      then pm2 flush
                      then do the reboot which causes mm not to come up.
                      then pm2 logs --lines=100
                      the debug output will come out in the error listing of the two listings displayed
                      E 3 Replies Last reply Reply Quote 0
                      • E Offline
                        ember1205 @sdetweil
                        Full logs…
                        [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
                        /home/pi/.pm2/pm2.log last 100 lines:
                        PM2        | 2022-05-10T15:00:25: PM2 log: PM2 successfully stopped
                        PM2        | 2022-05-10T15:00:44: PM2 log: ===============================================================================
                        PM2        | 2022-05-10T15:00:44: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                        PM2        | 2022-05-10T15:00:44: PM2 log: Time                 : Tue May 10 2022 15:00:44 GMT-0400 (Eastern Daylight Time)
                        PM2        | 2022-05-10T15:00:44: PM2 log: PM2 version          : 4.4.1
                        PM2        | 2022-05-10T15:00:44: PM2 log: Node.js version      : 16.15.0
                        PM2        | 2022-05-10T15:00:44: PM2 log: Current arch         : arm
                        PM2        | 2022-05-10T15:00:44: PM2 log: PM2 home             : /home/pi/.pm2
                        PM2        | 2022-05-10T15:00:44: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                        PM2        | 2022-05-10T15:00:44: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                        PM2        | 2022-05-10T15:00:44: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                        PM2        | 2022-05-10T15:00:44: PM2 log: Application log path : /home/pi/.pm2/logs
                        PM2        | 2022-05-10T15:00:44: PM2 log: Worker Interval      : 30000
                        PM2        | 2022-05-10T15:00:44: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                        PM2        | 2022-05-10T15:00:44: PM2 log: Concurrent actions   : 2
                        PM2        | 2022-05-10T15:00:44: PM2 log: SIGTERM timeout      : 1600
                        PM2        | 2022-05-10T15:00:45: PM2 log: App [mm:0] starting in -fork mode-
                        PM2        | 2022-05-10T15:00:45: PM2 log: App [mm:0] online
                        /home/pi/.pm2/logs/mm-error.log last 100 lines:
                        0|mm       | + '[' -f ./untrack-css.sh ']'
                        0|mm       | + grep docker /proc/1/cgroup -qa
                        0|mm       | + '[' -z :0 ']'
                        0|mm       | ++ uname -m
                        0|mm       | + arch=armv7l
                        0|mm       | + false=false
                        0|mm       | ++ grep -v '^[[:blank:]]*//' config/config.js
                        0|mm       | ++ grep -i serveronly:
                        0|mm       | ++ awk -F: '{print tolower($2)}'
                        0|mm       | ++ sed -e 's/^[[:space:]]*//'
                        0|mm       | ++ tr -d ',"'\''\r'
                        0|mm       | + serveronly=local
                        0|mm       | ++ pgrep Xorg
                        0|mm       | + xorg=
                        0|mm       | + '[' . == . ']'
                        0|mm       | ++ pgrep X
                        0|mm       | + xorg=
                        0|mm       | ++ uname
                        0|mm       | + mac=Linux
                        0|mm       | + '[' local. '!=' false. -o armv7l == armv6l ']'
                        0|mm       | + '[' local. == true. ']'
                        0|mm       | + '[' . == . -a Linux '!=' Darwin ']'
                        0|mm       | + node serveronly
                        /home/pi/.pm2/logs/mm-out.log last 100 lines:
                        0|mm       |
                        0|mm       |
                        0|mm       | [2022-05-10 15:00:55.768] [LOG]    Starting MagicMirror: v2.13.0
                        0|mm       | [2022-05-10 15:00:55.790] [LOG]    Loading config ...
                        0|mm       | [2022-05-10 15:00:55.804] [LOG]    Loading module helpers ...
                        0|mm       | [2022-05-10 15:00:57.248] [LOG]    Initializing new module helper ...
                        0|mm       | [2022-05-10 15:00:57.252] [LOG]    Module helper loaded: MMM-ImagesPhotos
                        0|mm       | [2022-05-10 15:00:57.264] [LOG]    No helper found for module: alert.
                        0|mm       | [2022-05-10 15:00:57.385] [LOG]    Initializing new module helper ...
                        0|mm       | [2022-05-10 15:00:57.387] [LOG]    Module helper loaded: updatenotification
                        0|mm       | [2022-05-10 15:00:57.391] [LOG]    No helper found for module: clock.
                        0|mm       | [2022-05-10 15:00:57.686] [LOG]    Initializing new module helper ...
                        0|mm       | [2022-05-10 15:00:57.689] [LOG]    Module helper loaded: calendar
                        0|mm       | [2022-05-10 15:00:57.692] [LOG]    No helper found for module: currentweather.
                        0|mm       | [2022-05-10 15:00:57.696] [LOG]    No helper found for module: weatherforecast.
                        0|mm       | [2022-05-10 15:00:57.698] [LOG]    All module helpers loaded.
                        0|mm       | [2022-05-10 15:01:00.465] [LOG]    Starting server on port 8080 ...
                        0|mm       | [2022-05-10 15:01:00.504] [LOG]    Server started ...
                        0|mm       | [2022-05-10 15:01:00.507] [LOG]    Connecting socket for: MMM-ImagesPhotos
                        0|mm       | [2022-05-10 15:01:00.509] [LOG]    Starting node helper for: MMM-ImagesPhotos
                        0|mm       | [2022-05-10 15:01:00.511] [LOG]    Connecting socket for: updatenotification
                        0|mm       | [2022-05-10 15:01:00.514] [LOG]    Connecting socket for: calendar
                        0|mm       | [2022-05-10 15:01:00.516] [LOG]    Starting node helper for: calendar
                        0|mm       | [2022-05-10 15:01:00.517] [LOG]    Sockets connected & modules started ...
                        0|mm       | [2022-05-10 15:01:00.519] [LOG]
                        • E Offline
                          ember1205 @sdetweil
                          Here’s a portion of the log when doing a stop and a start (without reboot):
                          0|mm       | + xorg=755
                          0|mm       | + '[' 755. == . ']'
                          0|mm       | ++ uname
                          0|mm       | + mac=Linux
                          0|mm       | + '[' 755. == . -a Linux '!=' Darwin ']'
                          0|mm       | + exec
                          0|mm       | + read line
                          0|mm       | ++ node serveronly
                          0|mm       | + case "$line" in
                          0|mm       | + echo '[2022-05-10' '15:14:59.203]' '[LOG]' Starting MagicMirror: v2.13.0
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:14:59.220]' '[LOG]' Loading config ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:14:59.231]' '[LOG]' Loading module helpers ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:14:59.936]' '[LOG]' Initializing new module helper ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:14:59.938]' '[LOG]' Module helper loaded: MMM-ImagesPhotos
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:14:59.943]' '[LOG]' No helper found for module: alert.
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.042]' '[LOG]' Initializing new module helper ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.050]' '[LOG]' Module helper loaded: updatenotification
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.059]' '[LOG]' No helper found for module: clock.
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.274]' '[LOG]' Initializing new module helper ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.278]' '[LOG]' Module helper loaded: calendar
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.280]' '[LOG]' No helper found for module: currentweather.
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.282]' '[LOG]' No helper found for module: weatherforecast.
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.284]' '[LOG]' All module helpers loaded.
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.471]' '[LOG]' Starting server on port 8080 ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.496]' '[LOG]' Server started ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.498]' '[LOG]' Connecting socket for: MMM-ImagesPhotos
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.500]' '[LOG]' Starting node helper for: MMM-ImagesPhotos
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.502]' '[LOG]' Connecting socket for: updatenotification
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.504]' '[LOG]' Connecting socket for: calendar
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.505]' '[LOG]' Starting node helper for: calendar
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.506]' '[LOG]' Sockets connected '&' modules started ...
                          0|mm       | + read line
                          0|mm       | + echo '[2022-05-10' '15:15:00.507]' '[LOG]'
                          0|mm       | + read line
                          0|mm       | + echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                          0|mm       | + break
                          0|mm       | ++ echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080
                          0|mm       | ++ awk -F: '{print $4}'
                          0|mm       | + port=8080
                          0|mm       | + echo 'Starting chromium browser now, have patience, it takes a minute'
                          0|mm       | + '[' Linux '!=' Darwin ']'
                          0|mm       | + tee
                          0|mm       | ++ which chromium-browser
                          0|mm       | + '[' /usr/bin/chromium-browser '!=' '' ']'
                          0|mm       | + chromium-browser -noerrdialogs -kiosk -start_maximized --disable-infobars --app=http://localhost:8080 --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors
                          • E Offline
                            ember1205 @sdetweil
                            I’m seeing a discrepancy where on boot it’s collecting xorg= blank versus xorg=755 on a stop/start after boot.
                              sdetweil @ember1205
                              @ember1205 yes… I see that too…
                              • E Offline
                                ember1205 @sdetweil
                                It almost seems like the X desktop isn’t fully initialized when the pgrep command executes and it isn’t collecting info on the process as a result. The restart NEVER happens until X is fully initialized which means that it -can- collect info on the process from a restart or stop/start.
                                  sdetweil @ember1205
                                  @ember1205 yes. I am looking for a resolution…
                                  • E Offline
                                    ember1205 @sdetweil
                                    I just edited the run-start.sh script and inserted a ten second sleep before the pgrep command. It’s a bit “extreme”, but should hopefully demonstrate if that’s the issue.
                                    WIthout the sleep, not detecting X simply moves on to a different test instead of trying again at least once before moving on.
                                      sdetweil @ember1205
                                      @ember1205 yes, adding a sleep would ‘fix’ it
                                      if only we knew how LONG to sleep… working on it…
                                      if X is not running then we just launch serveronly and don’t look at its output
                                        @sdetweil try 1 second… sleep 1
                                        • E Offline
                                          ember1205 @sdetweil
                                          Sleep 10 allows the browser to correctly launch. I will drop to 1 second and validate that it will work or not (if not, I will tweak and tune).
                                          Even with the sleep function ensuring that it allows X to finish initializing, chromium does not start correctly unless I wipe the ~/.config/chromium directory when I shut down.
                                            sdetweil @ember1205
                                            @ember1205 people are constantly fiddling with stuff, you never know what you’re gonna get anymore.
                                            • E Offline
                                              ember1205 @sdetweil
                                              Would there be more value in coding in a check for to see if it’s Raspbian or possibly even bullseye and adding a two second sleep if there is?
                                              raspberry_pi=$(grep ID /etc/os-release | cut -f2 -d=)
                                              if [ "$raspberry_pi." == "raspbian" ] ; then
                                                 sleep 2
                                              fi
                                              xorg=$(pgrep Xorg)
                                              Maybe there’s a better string to search for, but it might be a stop-gap that would help?
                                              • 1 / 3
