    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 18.4k Views 3 Watching
      sdetweil @ember1205
      @ember1205 said in Autostarts but doesn't run, will run on restart:
      0|mm | + xprop -root
      0|mm | xprop: unable to open display ‘:0’
      thanks… x not up yet…
      weird, never seen this on any other system pi otherwise…
      I have 3 pi3, 2 pi4, pi 0w and pi02w and jetson nano, odroid, chromebox, plus desktops…
      i’ll add another environment variable check
      u add it to the mm.sh used to launch…
      let me test it…
      thanks for your help
      • E Offline
        ember1205 @sdetweil
        Happy to have broken it. Again. lol
          sdetweil @ember1205
          @ember1205 ok, do this
          cd ~/MagicMirror
          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/test/run-start.sh >run-start.sh
          edit the MagicMirror/installers/mm.sh
          add a line before the npm start
          export wait_for_x=1
          (or true, or ANYTHING)
          the value can be anything
          edit the run-start.sh and add the -x on the 1st line again
          do the pm2 flush
          pm2 restart
          just to test
          then do the reboot test
          • E Offline
            ember1205 @sdetweil
            @sdetweil said in Autostarts but doesn't run, will run on restart:
            export wait_for_x=1
            That isn’t the mm.sh that my system launches from, though… Mine is ~/mm.sh
            Does the one you’re referencing get called from one of the other scripts?
              sdetweil @ember1205
              @ember1205 whatever script…
              if you used my setup script it uses the one already in installers
              • E Offline
                ember1205 @sdetweil
                Ok… Modified the ~/mm.sh script
                pm2 restart mm failed to start Chromium correctly - landed on the Chrome Desktop.
                Purged the config directory and started mm without issue.
                Restarted the mirror and everything came up clean multiple times, but there is clearly still something weird happening with Chromium in that I have to continue wiping the config directory before it will start up correctly.
                  sdetweil @ember1205
                  @ember1205 the new script wipes the config folder already
                  E 2 Replies Last reply Reply Quote 0
                  • E Offline
                    ember1205 @sdetweil
                    Whatever it’s doing, it isn’t doing it correctly. “pm2 restart mm” lands me on the Chrome Desktop every time. I have to wipe the config folder by hand.
                    • E Offline
                      ember1205 @sdetweil
                      Its trying to wipe a non-existent directory
                      0|mm  | + rm -rf /home/pi/.config/chromium-browser
                        sdetweil @ember1205
                        @ember1205 ah. I ‘assumed’ folder name matched executable…doah…
                        • 4 / 5
