    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 18.3k Views 3 Watching
    • E Offline
      ember1205 @sdetweil
      I’m seeing a discrepancy where on boot it’s collecting xorg= blank versus xorg=755 on a stop/start after boot.
        sdetweil @ember1205
        @ember1205 yes… I see that too…
        • E Offline
          ember1205 @sdetweil
          It almost seems like the X desktop isn’t fully initialized when the pgrep command executes and it isn’t collecting info on the process as a result. The restart NEVER happens until X is fully initialized which means that it -can- collect info on the process from a restart or stop/start.
            sdetweil @ember1205
            @ember1205 yes. I am looking for a resolution…
            • E Offline
              ember1205 @sdetweil
              I just edited the run-start.sh script and inserted a ten second sleep before the pgrep command. It’s a bit “extreme”, but should hopefully demonstrate if that’s the issue.
              WIthout the sleep, not detecting X simply moves on to a different test instead of trying again at least once before moving on.
                sdetweil @ember1205
                @ember1205 yes, adding a sleep would ‘fix’ it
                if only we knew how LONG to sleep… working on it…
                if X is not running then we just launch serveronly and don’t look at its output
                  @sdetweil try 1 second… sleep 1
                  • E Offline
                    ember1205 @sdetweil
                    Sleep 10 allows the browser to correctly launch. I will drop to 1 second and validate that it will work or not (if not, I will tweak and tune).
                    Even with the sleep function ensuring that it allows X to finish initializing, chromium does not start correctly unless I wipe the ~/.config/chromium directory when I shut down.
                      sdetweil @ember1205
                      @ember1205 people are constantly fiddling with stuff, you never know what you’re gonna get anymore.
                      • E Offline
                        ember1205 @sdetweil
                        Would there be more value in coding in a check for to see if it’s Raspbian or possibly even bullseye and adding a two second sleep if there is?
                        raspberry_pi=$(grep ID /etc/os-release | cut -f2 -d=)
                        if [ "$raspberry_pi." == "raspbian" ] ; then
                           sleep 2
                        fi
                        xorg=$(pgrep Xorg)
                        Maybe there’s a better string to search for, but it might be a stop-gap that would help?
                        • 2 / 5
