    Graph module
    26 Posts 9 Posters 24.4k Views 9 Watching
    • SvenSommerS
      SvenSommer @planet4
      @planet4 The tutorial explaines how to enable authentication via http to access influxdb without login.
      You’re changing parts of the configuration file /etc/influxdb/influxdb.conf
      [http]
      enabled = true bind-address = ":8086" # change to a specific interface if needed
      auth-enabled = true # will enforce authentication
      To access your Grafana graphs remotely, you can use the share option to get a public accessible link. The same url uses MMM-GrafanaChart to show the graph on the mirror.
      Let me know if you ran in any problems…
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
      • F
        feedparakeet @planet4
        @planet4 if you want to see Grafana’s charts without login\password, you should turn on anonymous access.
        Edit /etc/grafana/grafana.ini
        [auth.anonymous]
        enabled = true
        org_name = FeedParakeet
        org_role = Viewer
        Then you should go to Grafana’s GUI - Profile settings and set the “Name” field equal to the “org_name” value.
        Your graphs will be visible to anyone. But it wil be impossible to change anything without loging in.
        SvenSommerS 1 Reply Last reply Reply Quote 1
        • SvenSommerS
          SvenSommer @feedparakeet
          @feedparakeet
          I think there is even a better way. You can share each panel individually.
          http://docs.grafana.org/reference/sharing/
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
          F 1 Reply Last reply Reply Quote 1
          • F
            feedparakeet @SvenSommer
            @SvenSommer wow, it works even easier, thanks
            • P
              planet4
              Ok, Almost there. The gauge shows perfect on my mirror. Influx and Grafana is setup. I get the data from this sensor. http://aeotec.com/z-wave-sensor.
              However I still get the grey/brown background on the mirror. Tried to set it to transperant and also modified the css files as described in a post before here. It is just not black. Any smart ideas?
              • SvenSommerS
                SvenSommer
                @planet4 I’m glad to hear, everything worked out as expected.
                • If you want to do me a favor. Please let others know in the module teaser thread, you were able to use the module. So maybe other lose their fear. ;)
                • I had a look at changing the background color by inverting the colors of the “white” theme. Didn’t worked out, cause it’s no real white neither.
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
