    MMM-GrafanaCharts and MMM-GrafanaGauges: Display you data with Charts and Gauges. Beautifully.
    29 Posts 13 Posters 27.9k Views 15 Watching
    • SvenSommerS Offline
      SvenSommer
      Description:
      Two little modules for the Magic Mirror to include beautiful graphics generated with grafana.
      MMM-GrafanaCharts
      It’s for your graphs! The data that’s currently displayed on my mirror using the MMM-GrafanaCharts is a weather forecast for the next two days.
      If you’re interested in building you own weather chart, check out my blog post Programming your personal weather chart.
      MMM-GrafanaGauges
      Gauges are extremely helpful to monitor individual values ​​and their deviations from the nominal value. With the MMM-GrafanaGauges vital values of my plants are displayed on the mirror.
      Screenshots:
      with graph behind
      alt text
      Download
      [card:SvenSommer/MMM-GrafanaChart]
      [card:SvenSommer/MMM-GrafanaGauges]
      MMM-GrafanaChart- Version 1
      • Initial release
      • Showing charts provided by grafana
      MMM-GrafanaGauges- Version 1
      • Initial release
      • Showing gauges in a row provided by grafana
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
      1 Reply Last reply Reply Quote 4
      • P Offline
        planet4
        Tried this and it works fine. The simple way to show temperatures is this:
        alt text
        The more complicated but more fun way is this:
        alt text
        I have tried to use Grafana before but had problems with headers etc. Thanks to this module most problems are solved.
        I get the data from my z Wave sensor http://aeotec.com/z-wave-sensor. This is connected to a raspberry running home assistant. On another raspberry I use influxdb and grafana. Home assistant is sending influx data to this PI. On the thirs Raspberry i run Magic mirror and the result is displayed. The only issue is that in dark light you can see the border and background in the graph even if it is set to black. Maybe this is just a feuture of the mm and the screen.
        I also tried to use the same module to display if the door is locked or unlocked. I also get the data from home assistant.
        N 1 Reply Last reply Reply Quote 1
        • P Offline
          planet4
          Regarding the black background I think it is solved. Maybe there was some kind of cache problem. After chaning the css files it looks perfect.
          SvenSommerS H 2 Replies Last reply Reply Quote 0
            SvenSommer @planet4
            @planet4 good news!
            Can you please share which CSS file, and what you edited?
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
            • foxF Offline
              fox
              Can i also show there other temperatures?
              Like temperatures from 1-wire Dallas sensor or from a http site?
              SvenSommerS 1 Reply Last reply Reply Quote 0
                SvenSommer @fox
                @fox
                Short answer: No, not the direct way.
                Long answer: You need to write your temperature data into a database which is connected with Grafana. Then you can use this module to display your graph created by grafana.
                One possible solution: This tutorial shows an example, on how to store weather data from an external source in a local influxdb database, which is connected to grafana.
                You could reuse the example code an edit it, to get your data stored in a influxdb database.
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                foxF 1 Reply Last reply Reply Quote 1
                • foxF Offline
                  fox @SvenSommer
                  @SvenSommer said in MMM-GrafanaCharts and MMM-GrafanaGauges: Display you data with Charts and Gauges. Beautifully.:
                  @fox
                  i will try your possible solution :) Thank you
                  edit:
                  thanks for sharing the link.
                  I installed influxDB and grafana as written on your page.
                  I also added the datasource to grafana.
                  You mean i have to update this script?
                  importForecast.js
                    SvenSommer @fox
                    @fox Yes, this script is responsible for getting the data into the database.
                    If you would like to show other data with Grafana, you need to save the data you get from your sensor.
                    Modules released:
                    MMM-GoogleAnalytics
                    MMM-GrafanaChart
                    MMM-GrafanaGauges
                      sceletus
                      How do you manage credential to get access to grafana?
                      Thanks in advance.
                      • Y Offline
                        yours.mukul
                        How to install Grafana? Does that debian work fine on rpi? I am confused since the architecture is different and I think the packages should be different as well.
                        I know its a very stupid question, but please help
                          SvenSommer @yours.mukul
                          @yours.mukul
                          Yes just follow these instructions:
                          http://docs.grafana.org/installation/debian/
                          Modules released:
                          MMM-GoogleAnalytics
                          MMM-GrafanaChart
                          MMM-GrafanaGauges
                            SvenSommer @sceletus
                            @sceletus
                            Enable authentication in the [http] section of the configuration file /etc/influxdb/influxdb.conf :
                            [http] enabled = true bind-address = ":8086" # change to a specific interface if needed auth-enabled = true # will enforce authentication
                            everything is described in the tutorial on http://robstechlog.com/2017/06/30/personal-weather-chart-module/
                            Modules released:
                            MMM-GoogleAnalytics
                            MMM-GrafanaChart
                            MMM-GrafanaGauges
                            • H Offline
                              hunty1980 @planet4
                              @planet4 Are you able to provide steps on how you managed to update the CSS file to match the black background of the MM?
                              • P Offline
                                planet4 @hunty1980
                                @hunty1980 I used this guide https://forum.magicmirror.builders/topic/1675/graph-module/18
                                • P Offline
                                  planet4
                                  @SvenSommer Have not used this module for a while but have now reinstalled Grafana and would like to try it again. However I can not remember how to solve the login to Grafana. I think I opened it up as public the last time but is not an option now. At the moment the mirror just shows erroe as it can not login to the Grafana dashboard. Please advise.
                                  • P Offline
                                    planet4
                                    I was able to solve the login issues but now its just black. Maybe this module does not work with the new version of Grafana?
                                      SvenSommer @planet4
                                      @planet4 Hey, I just tried it with the actual Grafana v6.0.1 (commit: 0c44a04)
                                      It worked for me without any adjustments.
                                      Maybe I can support you, to set it up.
                                      Modules released:
                                      MMM-GoogleAnalytics
                                      MMM-GrafanaChart
                                      MMM-GrafanaGauges
                                      • P Offline
                                        planet4 @SvenSommer
                                        @SvenSommer Thanks for replying. I was actually able to solve it but with version 6 of Grafana black background is more of a trouble. Wrote a short post about this as well.
                                        http://www.planet4.se/grafana-in-magic-mirror/
                                        I am now able to show my Solar production on my mirror. 0,36kW. Will post this in the show my mirror as well. Thanks.
                                        • T Offline
                                          teitlebot @planet4
                                          @planet4 thanks
                                          your post helped me half way
                                          im using home assistant to host grafana so i needed to create an org called home assistant.
                                          • P Offline
                                            planet4
                                            @teitlebot I am using Home Assistant as well but Grafana is not used as an add-in on Hassio. I have it on a separate docker container. However I gave up Grafana in the end. It was to much problems. Now I use MQTT to get all information I want from Home Assistant to my Mirror. Like this:
                                            http://www.planet4.se/magic-mirror-info-via-mqtt/
