    MMM-GrafanaCharts and MMM-GrafanaGauges: Display you data with Charts and Gauges. Beautifully.
    28 Posts 12 Posters 24.9k Views 14 Watching
    • SvenSommerS Offline
      SvenSommer @yours.mukul
      @yours.mukul
      Yes just follow these instructions:
      http://docs.grafana.org/installation/debian/
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
        SvenSommer @sceletus
        @sceletus
        Enable authentication in the [http] section of the configuration file /etc/influxdb/influxdb.conf :
        [http] enabled = true bind-address = ":8086" # change to a specific interface if needed auth-enabled = true # will enforce authentication
        everything is described in the tutorial on http://robstechlog.com/2017/06/30/personal-weather-chart-module/
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
        • H Offline
          hunty1980 @planet4
          @planet4 Are you able to provide steps on how you managed to update the CSS file to match the black background of the MM?
          • P Offline
            planet4 @hunty1980
            @hunty1980 I used this guide https://forum.magicmirror.builders/topic/1675/graph-module/18
            • P Offline
              planet4
              @SvenSommer Have not used this module for a while but have now reinstalled Grafana and would like to try it again. However I can not remember how to solve the login to Grafana. I think I opened it up as public the last time but is not an option now. At the moment the mirror just shows erroe as it can not login to the Grafana dashboard. Please advise.
              • P Offline
                planet4
                I was able to solve the login issues but now its just black. Maybe this module does not work with the new version of Grafana?
                SvenSommerS 1 Reply Last reply Reply Quote 0
                  SvenSommer @planet4
                  @planet4 Hey, I just tried it with the actual Grafana v6.0.1 (commit: 0c44a04)
                  It worked for me without any adjustments.
                  Maybe I can support you, to set it up.
                  Modules released:
                  MMM-GoogleAnalytics
                  MMM-GrafanaChart
                  MMM-GrafanaGauges
                  • P Offline
                    planet4 @SvenSommer
                    @SvenSommer Thanks for replying. I was actually able to solve it but with version 6 of Grafana black background is more of a trouble. Wrote a short post about this as well.
                    http://www.planet4.se/grafana-in-magic-mirror/
                    I am now able to show my Solar production on my mirror. 0,36kW. Will post this in the show my mirror as well. Thanks.
                    • T Offline
                      teitlebot @planet4
                      @planet4 thanks
                      your post helped me half way
                      im using home assistant to host grafana so i needed to create an org called home assistant.
                      • P Offline
                        planet4
                        @teitlebot I am using Home Assistant as well but Grafana is not used as an add-in on Hassio. I have it on a separate docker container. However I gave up Grafana in the end. It was to much problems. Now I use MQTT to get all information I want from Home Assistant to my Mirror. Like this:
                        http://www.planet4.se/magic-mirror-info-via-mqtt/
                        • 2 / 3
