    MMM-GrafanaCharts and MMM-GrafanaGauges: Display you data with Charts and Gauges. Beautifully.
    29 Posts 13 Posters 30.0k Views 15 Watching
      planet4
      @teitlebot I am using Home Assistant as well but Grafana is not used as an add-in on Hassio. I have it on a separate docker container. However I gave up Grafana in the end. It was to much problems. Now I use MQTT to get all information I want from Home Assistant to my Mirror. Like this:
      http://www.planet4.se/magic-mirror-info-via-mqtt/
      • T
        teitlebot @planet4
        @planet4 What other problems did grafana give you? I am also using the mmm hass component to pull in sensor date but maybe I will switch to mmm mqtt. I really wanted to show some nice graph though. Also how did you build the total solar energy sensor saving in hass? I build it in graphana following someones tutorial,
        • A
          andreasm80
          edit reposted to be in same thread…
          Have been using this module for a couple of years now without any problems. Yesterday I upgraded my Grafana server and discovered they had implemented a security change where you had to allow_embedded=true. After doing this change I was back on track again, except that I can only see my GrafanaGauges when I point my browser to my MagicMirror IP, it does not show up on the MM screen itself. I see it takes it places and all modules around aligns perfectly around it, but the content onscreen is blank/black. Have been troubleshooting everything from both Grafana side and MagicMirror side. It will not show up on the screen only when I point my browser to the MM, then I see the screen with all content as it should…
          Now I am clueless… Not sure if this is module-specific or content from Grafana that does it. My next step to try som iFrame modules to show the same content…
          Any ideas?
          Regards
          • A
            andreasm80
            edit
            Case closed.
            With no errors what so ever from the MM side, everything seemed to work normal. Either MM or the modules I tried did not resolve FQDN names… ! (MM is configured with two local DNS servers) I think this should be reported in some of the logs on MM… Nothing.
            I figured it out when I did a lsof on my Grafana server and there were no connection from the MM there… Only my own pc… LOL
            Well, back in business again after some hours troubleshooting… Probably learnt a thing or two also along the way.
            I tried with another module capable of showing iframes. Same problem there. It refuses to show the content on the MM monitor only on a browser from another computer. There everythings shows up as normal.
            Even removed all other modules sharing the same position as this one.
            I am stuck…
            • I
              iorifly
              Hello, thanks for your module!
              I would use the bar graph? Both vertical and horizontal?
              it’s possible ? If not, do I want to add this function? Thanks so much again for the module!
              • I
                iorifly
                Does anyone know if anything happened to dev? I haven’t seen anything from him on the internet since 2018.
                Is this project dead?
                  Biebermann @iorifly
                  @iorifly
                  The project seems to be dead :(
                  • E
                    Egnos
                    Hello everyone,
                    I would like to set up a system that takes the data from the temperature/humidity sensors, the values ​​recorded in a database and with Grafana graphing the values ​​and then displaying everything on MM.
                    What other methods/modules are available to graph this information on MM?
                    From what I understand @SvenSommer modules don’t work anymore …
                    thgmirrorT 1 Reply Last reply Reply Quote 0
                    • thgmirrorT
                      thgmirror @Egnos
                      @Egnos You can use RDDTOOL, I described it here: https://forum.magicmirror.builders/topic/16575/cpu-temperature-as-a-graph-with-rrdtool?_=1666781012238
                      But instead of creating an extra html, you can use the output directly with MMM-EasyPix:
                      			disabled: false,
                      			module: "MMM-EasyPix",
                      			position: "top_center",
                      				picName: "cputemp.gif",
                      				maxWidth: "100%",
                      //				sounds: ["1.mp3", "me2.mp3"],
                      				updateInterval: 600000,
                      				animationSpeed: 1000,
                      • N
                        nkc @planet4
                        @planet4 Hi - I have seen your temperature module, it looks nice, I am not a developer, Would you be kind enough to share your Temperature module with me…the one with the gauge - Thank you.
