Graph module
@planet4 The tutorial explaines how to enable authentication via http to access influxdb without login.
You’re changing parts of the configuration file/etc/influxdb/influxdb.conf[http] enabled = true bind-address = ":8086" # change to a specific interface if needed auth-enabled = true # will enforce authentication ...To access your Grafana graphs remotely, you can use the share option to get a public accessible link. The same url uses MMM-GrafanaChart to show the graph on the mirror.
Let me know if you ran in any problems…
@planet4 if you want to see Grafana’s charts without login\password, you should turn on anonymous access.
Edit /etc/grafana/grafana.ini
[auth.anonymous] enabled = true org_name = FeedParakeet org_role = ViewerThen you should go to Grafana’s GUI - Profile settings and set the “Name” field equal to the “org_name” value.
Your graphs will be visible to anyone. But it wil be impossible to change anything without loging in.
@feedparakeet
I think there is even a better way. You can share each panel individually.
http://docs.grafana.org/reference/sharing/ -
@SvenSommer wow, it works even easier, thanks
Ok, Almost there. The gauge shows perfect on my mirror. Influx and Grafana is setup. I get the data from this sensor. http://aeotec.com/z-wave-sensor.
However I still get the grey/brown background on the mirror. Tried to set it to transperant and also modified the css files as described in a post before here. It is just not black. Any smart ideas?
@planet4 I’m glad to hear, everything worked out as expected.
If you want to do me a favor. Please let others know in the module teaser thread, you were able to use the module. So maybe other lose their fear. ;)
I had a look at changing the background color by inverting the colors of the “white” theme. Didn’t worked out, cause it’s no real white neither.
