    MMM-MyDutchWeather
    4 Posts 2 Posters 1.1k Views 2 Watching
    • L Offline
      lodevries
      I installed the module as mentioned in the instructions.
      I created a api key with Weerlive.
      When I run the MagicMirror, I get a black screen.
      When I delete the code in the config file, the MagicMirror software runs without problems and I see the newsfeed, the calendar and so on.
      So I suppose I do something wrong.
      I attach a screenshot from the location on the MMM-MyDutchWeather
      This is the config file (I deleted some modules in the text so make it shorter):
      /* MagicMirror² Config Sample
      • By Michael Teeuw https://michaelteeuw.nl
      • MIT Licensed.
      • For more information on how you can configure this file
      • see https://docs.magicmirror.builders/configuration/introduction.html
      • and https://docs.magicmirror.builders/modules/configuration.html
        let config = {
        address: “localhost”, // Address to listen on, can be:
        // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
        // - “0.0.0.0”, “::” to listen on any interface
        // Default, when address config is left out or empty, is “localhost”
        port: 8080,
        basePath: “/”, // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
        // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
        // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
        useHttps: false, // Support HTTPS or not, default “false” will use HTTP
        httpsPrivateKey: “”, // HTTPS private key path, only require when useHttps is true
        httpsCertificate: “”, // HTTPS Certificate path, only require when useHttps is true
        language: “nl”,
        locale: “en-US”,
        logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”], // Add “DEBUG” for even more logging
        timeFormat: 24,
        units: “metric”,
        // serverOnly: true/false/“local” ,
        // starts serveronly and then starts chrome browser
        // true, force serveronly mode, because you want to… no UI on this device
        module: “alert”,
        module: “updatenotification”,
        position: “top_bar”
        module: “clock”,
        position: “top_left”
         	module: 'MMM-MyDutchWeather',
         	position: 'top_right',
           		header: "Nederlands weerbericht test",
         		latitude: 52.26583,
         		longitude: 6.79306,
         		apiKey: "c15c476376",
         		showIcons: true,
         		showExtra: false,
         		maxWidth: "500px"
         	module: "newsfeed",
         	position: "bottom_bar",
         		feeds: [
         				title: "NOS Nieuws",
         				url: "http://feeds.nos.nl/nosnieuwsvideo"
         	showSourceTitle: true,
         	showPublishDate: true,
         	broadcastNewsFeeds: true,
         	broadcastNewsUpdates: true
         	 module: "newsfeed",
         		 feeds: [
         				title: "Nos Nieuws algemeen",
         				url: "http://feeds.nos.nl/nosnieuwsalgemeen"
      if (typeof module !== “undefined”) {module.exports = config;}
      I hope somebody is able to help me.
      Thank you in advance.
      Yvonne
        sdetweil @lodevries
        @lodevries black screen see
        • L Offline
          lodevries @sdetweil
          @sdetweil I did what you suggested.
          I moved the folder to the MagicMirror/modules folder.
          In the MagicMirror/config folder I have added the configuration as mentioned before. When I run nom run config: check there are no errors in my config file.
          If I delete this module in the config file and I run npm then the Magic Mirror is running fine. With this module I get a black screen.
          I have made an image of a part of the message on the screen.
          Maybe this is an indication.
          I hope you are willing and able to give me some hint.
            sdetweil @lodevries
