    MMM-Tronity - multi-manufacturer EV data via Tronity Platform
    2 Posts 2 Posters 692 Views 2 Watching
      robotfish
      This module uses Tronity Platform to display data on your EV’s charge state and range. It can also optionally display a map of your vehicle’s location - probably only useful if, like me, you live in an apartment and park in a large lot.
      You’ll need an active Tronity subscription (paid) to use this module, as well as a Mapbox API key (free) if you want to use the optional map feature.
      The circular charge indicator displays in blue when charging, green when disconnected and above 80%, yellow betwen 30% and 80%, and red under 40%. The range display on the left can be configured for either miles or kilometres. The lightning bolt on the right lights up when plugged in, and the charging speed in kW will be displayed under it.
      As this is my first module I’m sure there will be bugs and weirdness - let me know if you find any!
      C 1 Reply Last reply Reply Quote 2
      • C Offline
        corvankruchten @robotfish
        @robotfish Nice module, if I could get it working. The module stays in the ‘initialisation’-stage. Why?
