    OctoMirror - Not getting any updates on Info (shows only N/A)
    2 Posts 1 Posters 1.1k Views 1 Watching
      bigzolly
      Hi hello everybody!
      As for the start: I am trying to solve this for about a week now without any luck. I also searched in different forums (here as well) and all I can see is that a lot of ppl having still this same problem.
      Right now I have tried to contact @shbatm. Hope he will be answering soon :)
      However here is what I have got so far:
      • Everything updated to it’s latest version.
      • Tried to modify the original module, and I was able to use the passive login via POST with an api key. I also recived back a connected payload, sending me some data.
      • The problem is that I was not getting the “current” or “history” payload at all.
      • Tried to simulate the payloads, and if I do that then it is recieved and translated correctly.
      TLDR:
      Does any1 of you guys have any idea, where to look for the issue? Why OctoPrint is not sending any of these payloads anymore?
        bigzolly @bigzolly
        @bigzolly said in OctoMirror - Not getting any updates on Info (shows only N/A):
        Hi hello everybody!
        TLDR:
        UPDATE:
        I did figured it out finally. It works completely fine. Sorry @shbatm. Somehow the MMM-Alexacontrol module broke it. When I delete the AlexaControl, everything works as intended. Maybe some port related stuff?
        BTW Thanks for reading. Hope might help someone.
