    Calendar Heading Changes
    22 Posts 5 Posters 15.9k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @ooom416354
      @ooom416354 put it right above the calendar module in the config with the same position
              module: 'helloworld',
              position: 'top_left',
                  text: '<div>John</div><div>Jane</div>'
      EDIT it wont let me do adding styling add style=“color: blue;” for John example behind the open div tag
      ooom416354O B 3 Replies Last reply Reply Quote 0
      • ooom416354O Offline
        ooom416354 @strawberry 3.141
        @strawberry-3.141 perfect, I will do that. thanks again!
          @strawberry-3.141 I see that, is it possible to just add 5 separate helloworld modules each stacked on top of each other, each with a different color?
          strawberry 3.141S brobergB 2 Replies Last reply Reply Quote 0
            @ooom416354 you could do that but each module has a margin around which takes up more space than adding all in one
            ooom416354O 1 Reply Last reply Reply Quote 0
              @strawberry-3.141 Yea, I saw that, I guess I could modify the module itself to shrink the margin but that would cause a problem with pulling latest updates, right?
                billp100 @strawberry 3.141
                @strawberry-3.141 I am said friend that @ooom416354 is helping. I appreciate the help, I will be able to do some testing of my own tonight and tomorrow with the impending storm coming.
                My ideal setup is to have the 5 members in my family share 1 calendar module, each using a separate icon. For my wife and I it’s fairly easy, because there is a male icon and female. For the kids, there is no way do differentiate them.
                My other question would be, rather than using a font-awesome symbol, could I just use a letter or name in place of that?
                • brobergB Offline
                  broberg Project Sponsor @ooom416354
                  @ooom416354
                  If you want it all in a row above the calender then use < span >, < div > usually stacks on top of each other.
                  < span style="color: blue">Dude, < /span>
                  < span style="color: pink">Dudette, < /span>
                  < span style="color: green">Tiny dude, < /span>
                  < span style="color: yellow">Tiny dudette, < /span>
                  < span style="color: purple">Tiniest thingymajigg< /span>
                  That should give you “Dude, Dudette, Tiny dude, Tiny dudette, Tiniest thingymajigg”
                  ooom416354O 1 Reply Last reply Reply Quote 1
                    ooom416354 @broberg
                    @broberg Yes, that makes sense but would that be added as part of the helloworld module which @strawberry-3-141 mentioned to use above?
                    • brobergB Offline
                      @ooom416354 Yes, if you put that inside the text: ' ... ' it should work nicely,
                      But since the module doesn’t have any width constraints it could stretch the top_left area, but that depends on number of characters and font-size ofc.
                        ooom416354 @broberg
                        @broberg perfect, got it, thanks.
                        @billp100 this should work but may need some formatting with the margins to get it to look good.
                        • 2 / 3
