    Electricity Bill Module Development
    19 Posts 3 Posters 4.6k Views 3 Watching
      sdetweil @SopaMaruchan
      @SopaMaruchan and {foo} is unnecessary
      you could just use
      res.body
      it’s the same stuff, why waste memory w a new pointer only being used once
      (same w info there too)
        SopaMaruchan @sdetweil
        @sdetweil Hahahaha true that!
        Kinda fixed it guided by your recommendations but the thing is that I’m still getting the same output: 098fca99-2a82-4ccd-8758-b81dcaedc3b6-image.png
        Here the code:
          @SopaMaruchan hm…
          sample from one of my modules
          self.sendSocketNotification("SLEEP_HIDE")
            hmm, actually it does help. I’ll be testing around and tell you when I get it to work!
            Anyways your help was a huge pilar to keep myself going with this, much thanks brother💝
              SopaMaruchan @SopaMaruchan
              Does it help if I tell you that I got everything on my onstart function of the node_helper file?
              S S 2 Replies Last reply Reply Quote 0
                @SopaMaruchan never done it in start.
                I usually wait til the module sends it’s 1st request
                  @SopaMaruchan I’m realizing that my my receiveSocketNotification is not being triggered on my MM-Module file:
                  I logged some text after calling receiveSocketNotification function but there’s no output on console.
                  node_helper:
                  S mumblebajM 4 Replies Last reply Reply Quote 0
                    @SopaMaruchan if the send fails like that, not sent
                      @SopaMaruchan
                      let self=this
                      has to be inside the getBill() function
                      otherwise it could be set wrong…
                        @SopaMaruchan maybe for debug
                        inside the request() callback function,
                        do a
                        console.log(JSON.stringify(self, null,2))
                        to see what ‘this’ was pointing to
