    MMM-Spotify having trouble with authentification
    7 Posts 5 Posters 2.2k Views 5 Watching
      Jack_Gregorski
      I am trying to install the MMM-Spotify module onto my magic mirror. I follow the steps on the github page and everything seems to be working up until the authentication stage. The Spotify popup opens after I run the node first_auth.js command in the terminal, but when I click allow in the new webpage I get an error, “This site can’t be reached localhost refused to connect.” Any ideas on how to fix this, any help would be appreciated.
      FoziF S 3 Replies Last reply Reply Quote 0
      • FoziF Offline
        Fozi Project Sponsor @Jack_Gregorski
        @Jack_Gregorski Are you using a free or premium account? The free account will not work. See https://github.com/skuethe/MMM-Spotify#restrictions
          sdetweil @Jack_Gregorski
          @Jack_Gregorski on the redirect url in the Spotify config did you use http://localhost:8888/callback
          as per the readme?
          that url should show on the error page
            @Jack_Gregorski ok, i see the same thing…
            workaround
            change Spotify.js
            from
            line 249-250
                let file = path.resolve(__dirname, this.config.TOKEN)
                let waitForFileTimeout = 0
            to
                let waitForFileTimeout = 60*1000
            basically the code sets up the server to listen for the callback, but doesn’t wait for you to interact with the web page
            opened issue
            https://github.com/skuethe/MMM-Spotify/issues/192
            • K Offline
              kinggiotai
              @Jack_Gregorski said in MMM-Spotify having trouble with authentification:
                sdetweil @kinggiotai
                @kinggiotai can you tell which module you are using
                git remote -v
                in the module folder will tell the source repository
                  @kinggiotai did you setup the spotify.config.json from the
                  auth callback example?
                        "USERNAME": "A_NAME_TO_IDENTIFY_YOUR_ACCOUNT",
                        "CLIENT_ID": "PUT_YOUR_SPOTIFY_APP_CLIENT_ID",
                        "CLIENT_SECRET": "PUT_YOUR_SPOTIFY_APP_CLIENT_SECRET",
                        "TOKEN": "./USERNAME_token.json",
                        "AUTH_DOMAIN": "http://YOUR_DEVICES_IP",
                        "AUTH_PORT": "8889"
                  I had to do that just now
                  the domain/port MUST match the callback address in the spotify app config
                  from my app config
                  callback
                  http://localhost:8100/callback
                  json file strings to match
                  domain is http://localhost
                  port is 8100
