    GooglePhotos
    4 Posts 2 Posters 988 Views 2 Watching
    • P Offline
      pat59
      good evening
      after the execution of node generate_token . here is the error message thank you for your help.
      [GPHOTOS:CORE] TypeError: Cannot read property ‘0’ of undefined
      /home/patrick/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:133
      throw e
      at new Auth (/home/patrick/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:35:91)
      at GPhotos.onAuthReady (/home/patrick/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:130:14)
      at GPhotos.generateToken (/home/patrick/MagicMirror/modules/MMM-GooglePhotos/GPhotos.js:141:10)
      at Object. (/home/patrick/MagicMirror/modules/MMM-GooglePhotos/generate_token.js:10:9)
      at Module._compile (internal/modules/cjs/loader.js:999:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:1027:10)
      at Module.load (internal/modules/cjs/loader.js:863:32)
      at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
      at internal/main/run_main_module.js:17:47
        sdetweil @pat59
        @pat59 I believe that means u picked the wrong app type in the credentials step.
        • P Offline
          pat59 @sdetweil
          @sdetweil Hello thank you
          this supposes erasing everything and redoing the installation of the GooglePhotos module or this is due to the installation of the operating system cordially
            sdetweil @pat59
            @pat59 no, it’s the Google developers console credentials setup. nothing changes on the pi, except the new downloaded credentials file
