Default Weather module still not displaying
39 Posts 6 Posters 13.8k Views 6 Watching
    sdetweil @Jarhead96097
    @Jarhead96097 ah, one other question, what is the current node level
    node --version
    J B 2 Replies Last reply Aug 5, 2022, 8:11 PM Reply Quote 1
      Jarhead96097 @sdetweil
      @sdetweil sorry, already using your installation script (but no “npm audit fix” this time around).
      Jarhead96097
        Blackeye @sdetweil
        @sdetweil On my RPi4 it’s 16.16.0, and I’m getting the same problems as Jarhead. After an upgrade there’s now just no reaction to starting mm.
        S 1 Reply Last reply Aug 5, 2022, 8:34 PM Reply Quote 0
          sdetweil @Blackeye
          @Blackeye can u show the output of the npm start or, if using pm2 , then
          pm2 logs --lines=50
          how did u do the upgrade?
          S B 2 Replies Last reply Aug 5, 2022, 8:43 PM Reply Quote 0
            @Blackeye also, can u show me the contents of line 159 from
            ~/MagicMirror/modules/default/weather/weather.js
            J 1 Reply Last reply Aug 5, 2022, 9:48 PM Reply Quote 0
              Jarhead96097 @OldSunGuy
              @OldSunGuy I use the MMM-ModuleScheduler 3rd party module to control when my MM turns off everything except the clock and dims the display at night. “daytime_scheduler” is the class I used to turn off those modules at night.
              Jarhead96097
                @sdetweil here is what my weather.js (newly rebuilt, but not yet configured) has on lines 148 to 166:
                	// What to do when the weather provider has new information available?
                	updateAvailable: function () {
                		Log.log("New weather information available.");
                		this.updateDom(0);
                		this.scheduleUpdate();
                		if (this.weatherProvider.currentWeather()) {
                			this.sendNotification("CURRENTWEATHER_TYPE", { type: this.weatherProvider.currentWeather().weatherType.replace("-", "_") });
                		const notificationPayload = {
                			currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,
                			forecastArray: this.weatherProvider?.weatherForecastArray?.map((ar) => ar.simpleClone()) ?? [],
                			hourlyArray: this.weatherProvider?.weatherHourlyArray?.map((ar) => ar.simpleClone()) ?? [],
                			locationName: this.weatherProvider?.fetchedLocationName,
                			providerName: this.weatherProvider.providerName
                		this.sendNotification("WEATHER_UPDATED", notificationPayload);
                Jarhead96097
                J S 2 Replies Last reply Aug 5, 2022, 10:57 PM Reply Quote 0
                  Jarhead96097 @Jarhead96097
                  @sdetweil Sam, thanks for all of your help. I’ve finished rebuilding without running ‘npm audit fix’ and everything is working as it should! I used your installation script and everything worked fine. I also took the opportunity to move things around and try a couple of new 3rd party modules… everything is back to normal!
                  Thanks again,
                  Jarhead96097
                  Jarhead96097
                  S 1 Reply Last reply Aug 5, 2022, 11:10 PM Reply Quote 1
                    @Jarhead96097 said in Default Weather module still not displaying:
                    thats line 158 and159.
                    the only thing i can think of is the ?. (optional chaining) operator…
                    but its been long supported… and it works on my 16.9.1 node version
                    see item 2 in the list here
                    https://www.freecodecamp.org/news/how-the-question-mark-works-in-javascript/
                      @Jarhead96097 great news!!!
                      • 3 / 4
                      3 / 4
