    Default Weather module still not displaying
    39 Posts 6 Posters 13.1k Views 6 Watching
      Blackeye @sdetweil
      @sdetweil Moin, line 159 of weather-js looks like this:
      currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,
      The pm2 error log shows:
      /home/<myusername>/.pm2/logs/MagicMirror-error.log last 50 lines:
      1|MagicMir | failed to load swrast driver
      1|MagicMir | [06.08.2022 09:46.00.374] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/lookyhere/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
      1|MagicMir | was compiled against a different Node.js version using
      1|MagicMir | NODE_MODULE_VERSION 73. This version of Node.js requires
      1|MagicMir | NODE_MODULE_VERSION 107. Please try re-compiling or re-installing
      1|MagicMir | the module (for instance, using `npm rebuild` or `npm install`).
      Looks like I should re-install. Which is the best method, in your opinion?
      Many thanks for your help - I want to get this thing on the wall soon!
        sdetweil @Blackeye
        @Blackeye see
        https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
          Blackeye @sdetweil
          @sdetweil Hi Sam, Many thanks for the suggestion - I followed your advice on that page. Here’s what happened halfway through:
          from ../src/epoll.cc:11:
          /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:45: error: ‘is_lvalue_reference_v’ is not a member of ‘std’; did you mean ‘is_lvalue_                                     reference’?
            106 |   template <class U, std::enable_if_t<!std::is_lvalue_reference_v<U>>*>
                |                                             is_lvalue_reference
          /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:66: warning: logical not is only applied to the left hand side of comparison [-Wlogic                                     al-not-parentheses]
          /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:67: error: template argument 1 is invalid
          /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:71: error: expected unqualified-id before ‘>’ token
          /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:123:43: error: ‘is_lvalue_reference_v’ is not a member of ‘std’; did you mean ‘is_lvalue_                                     reference’?
            123 | template <class T, std::enable_if_t<!std::is_lvalue_reference_v<T>>* = nullptr>
          and finally:
          ✖ MagicMirror Rebuild Failed
          An unhandled error occurred inside electron-rebuild
          node-gyp failed to rebuild '/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epo                                     ll'.
          Error: `make` failed with exit code: 2
          This will all mean a lot more to you than it does for me.
            Blackeye @Blackeye
            @sdetweil And this is the final part of the error message, in bright red:
             at ModuleRebuilder.rebuildNodeGypModule (/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor                                     /node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
                at processTicksAndRejections (node:internal/process/task_queues:96:5)
                at async Rebuilder.rebuildModuleAt (/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node                                     _modules/magicmirror-rebuild/build/rebuild.js:180:9)
                at async Rebuilder.rebuild (/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules                                     /magicmirror-rebuild/build/rebuild.js:143:17)
                at async /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuil                                     d/build/cli.js:141:9
              sdetweil @Blackeye
              @Blackeye hm. 1st time I’ve seen his tools fail…
              @bugsounet any guidance
              bugsounetB 1 Reply Last reply Reply Quote 0
              • bugsounetB Offline
                bugsounet Banned @sdetweil
                @sdetweil yes
                epoll/20.0.1 means it uses electron v20.0.1 for MagicMirror instead of v19.x that why it crash.
                I’ll leave it up to you to explain it :)
                  sdetweil @Blackeye
                  @Blackeye ok, heres a way around the problem
                  fix MM install to have one new tool
                  cd ~/MagicMirror
                  npm install electron-rebuild
                  fix MMM-PIR-Sensor
                  cd ~/MagicMirror/modules/MMM-PIR-Sensor
                  nano package.json
                  scroll down to
                    "scripts": {
                      "postinstall": "node_modules/.bin/electron-rebuild -e ../../node_modules/electron"
                  change the postinstall line so it looks like this
                    "scripts": {
                      "postinstall": "~/MagicMirror/node_modules/.bin/electron-rebuild -e ../../node_modules/electron"
                  ctrl-o to save the updated package.json
                  ctrl-x to exit the editor
                  then
                  npm install
                  should work correctly now
                  I just tested this on my MM 2.20 version, on both my linux machine and my pi4 with bullseye
                    Blackeye @sdetweil
                    @sdetweil said in Default Weather module still not displaying:
                    ~/MagicMirror/node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
                    Yes! It installed correctly this time, so that change in the path did the trick. I did get some warnings however:
                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain cir                                 cumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    So it is not quite a perfect solution, but it works!
                    Many thanks for the suggestions and the solution!
                      sdetweil @Blackeye
                      @Blackeye ignore the warnings, nothing we can do about them.
                      the ‘problem’ here is that the compiler needs to know what version of electron to build for, but can’t figure it out.
                      using electron-rebuild from the mm libs solves that
                      • 4 / 4
