    Default Weather module still not displaying
    39 Posts 6 Posters 20.4k Views 6 Watching
      sdetweil @Jarhead96097
      @Jarhead96097 ah, one other question, what is the current node level
      node --version
      Jarhead96097J B 2 Replies Last reply
      • Jarhead96097J
        Jarhead96097 @sdetweil
        @sdetweil sorry, already using your installation script (but no “npm audit fix” this time around).
        Jarhead96097
          Blackeye @sdetweil
          @sdetweil On my RPi4 it’s 16.16.0, and I’m getting the same problems as Jarhead. After an upgrade there’s now just no reaction to starting mm.
            sdetweil @Blackeye
            @Blackeye can u show the output of the npm start or, if using pm2 , then
            pm2 logs --lines=50
            how did u do the upgrade?
            S B 2 Replies Last reply
              @Blackeye also, can u show me the contents of line 159 from
              ~/MagicMirror/modules/default/weather/weather.js
              Jarhead96097J 1 Reply Last reply
              • Jarhead96097J
                Jarhead96097 @OldSunGuy
                @OldSunGuy I use the MMM-ModuleScheduler 3rd party module to control when my MM turns off everything except the clock and dims the display at night. “daytime_scheduler” is the class I used to turn off those modules at night.
                Jarhead96097
                • Jarhead96097J
                  @sdetweil here is what my weather.js (newly rebuilt, but not yet configured) has on lines 148 to 166:
                  	// What to do when the weather provider has new information available?
                  	updateAvailable: function () {
                  		Log.log("New weather information available.");
                  		this.updateDom(0);
                  		this.scheduleUpdate();
                  		if (this.weatherProvider.currentWeather()) {
                  			this.sendNotification("CURRENTWEATHER_TYPE", { type: this.weatherProvider.currentWeather().weatherType.replace("-", "_") });
                  		const notificationPayload = {
                  			currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,
                  			forecastArray: this.weatherProvider?.weatherForecastArray?.map((ar) => ar.simpleClone()) ?? [],
                  			hourlyArray: this.weatherProvider?.weatherHourlyArray?.map((ar) => ar.simpleClone()) ?? [],
                  			locationName: this.weatherProvider?.fetchedLocationName,
                  			providerName: this.weatherProvider.providerName
                  		this.sendNotification("WEATHER_UPDATED", notificationPayload);
                  Jarhead96097
                  Jarhead96097J S 2 Replies Last reply
                  • Jarhead96097J
                    Jarhead96097 @Jarhead96097
                    @sdetweil Sam, thanks for all of your help. I’ve finished rebuilding without running ‘npm audit fix’ and everything is working as it should! I used your installation script and everything worked fine. I also took the opportunity to move things around and try a couple of new 3rd party modules… everything is back to normal!
                    Thanks again,
                    Jarhead96097
                    Jarhead96097
                      @Jarhead96097 said in Default Weather module still not displaying:
                      thats line 158 and159.
                      the only thing i can think of is the ?. (optional chaining) operator…
                      but its been long supported… and it works on my 16.9.1 node version
                      see item 2 in the list here
                      https://www.freecodecamp.org/news/how-the-question-mark-works-in-javascript/
                        @Jarhead96097 great news!!!
                          Blackeye @sdetweil
                          @sdetweil Moin, line 159 of weather-js looks like this:
                          The pm2 error log shows:
                          /home/<myusername>/.pm2/logs/MagicMirror-error.log last 50 lines:
                          1|MagicMir | failed to load swrast driver
                          1|MagicMir | [06.08.2022 09:46.00.374] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/lookyhere/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                          1|MagicMir | was compiled against a different Node.js version using
                          1|MagicMir | NODE_MODULE_VERSION 73. This version of Node.js requires
                          1|MagicMir | NODE_MODULE_VERSION 107. Please try re-compiling or re-installing
                          1|MagicMir | the module (for instance, using `npm rebuild` or `npm install`).
                          Looks like I should re-install. Which is the best method, in your opinion?
                          Many thanks for your help - I want to get this thing on the wall soon!
                            sdetweil @Blackeye
                            @Blackeye see
                            https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
                            B 1 Reply Last reply
                              Blackeye @sdetweil
                              @sdetweil Hi Sam, Many thanks for the suggestion - I followed your advice on that page. Here’s what happened halfway through:
                              from ../src/epoll.cc:11:
                              /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:45: error: ‘is_lvalue_reference_v’ is not a member of ‘std’; did you mean ‘is_lvalue_                                     reference’?
                                106 |   template <class U, std::enable_if_t<!std::is_lvalue_reference_v<U>>*>
                                    |                                             is_lvalue_reference
                              /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:66: warning: logical not is only applied to the left hand side of comparison [-Wlogic                                     al-not-parentheses]
                              /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:67: error: template argument 1 is invalid
                              /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:106:71: error: expected unqualified-id before ‘>’ token
                              /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/20.0.1/include/node/v8-ma                                     ybe.h:123:43: error: ‘is_lvalue_reference_v’ is not a member of ‘std’; did you mean ‘is_lvalue_                                     reference’?
                                123 | template <class T, std::enable_if_t<!std::is_lvalue_reference_v<T>>* = nullptr>
                              and finally:
                              ✖ MagicMirror Rebuild Failed
                              An unhandled error occurred inside electron-rebuild
                              node-gyp failed to rebuild '/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epo                                     ll'.
                              Error: `make` failed with exit code: 2
                              This will all mean a lot more to you than it does for me.
                                Blackeye @Blackeye
                                @sdetweil And this is the final part of the error message, in bright red:
                                 at ModuleRebuilder.rebuildNodeGypModule (/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor                                     /node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
                                    at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                    at async Rebuilder.rebuildModuleAt (/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node                                     _modules/magicmirror-rebuild/build/rebuild.js:180:9)
                                    at async Rebuilder.rebuild (/home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules                                     /magicmirror-rebuild/build/rebuild.js:143:17)
                                    at async /home/<myusername>/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuil                                     d/build/cli.js:141:9
                                  sdetweil @Blackeye
                                  @Blackeye hm. 1st time I’ve seen his tools fail…
                                  @bugsounet any guidance
                                  bugsounetB 1 Reply Last reply
                                  • bugsounetB
                                    bugsounet Banned @sdetweil
                                    @sdetweil yes
                                    epoll/20.0.1 means it uses electron v20.0.1 for MagicMirror instead of v19.x that why it crash.
                                    I’ll leave it up to you to explain it :)
                                      sdetweil @Blackeye
                                      @Blackeye ok, heres a way around the problem
                                      fix MM install to have one new tool
                                      npm install electron-rebuild
                                      fix MMM-PIR-Sensor
                                      cd ~/MagicMirror/modules/MMM-PIR-Sensor
                                      nano package.json
                                      scroll down to
                                        "scripts": {
                                          "postinstall": "node_modules/.bin/electron-rebuild -e ../../node_modules/electron"
                                      change the postinstall line so it looks like this
                                        "scripts": {
                                          "postinstall": "~/MagicMirror/node_modules/.bin/electron-rebuild -e ../../node_modules/electron"
                                      ctrl-o to save the updated package.json
                                      ctrl-x to exit the editor
                                      then
                                      npm install
                                      should work correctly now
                                      I just tested this on my MM 2.20 version, on both my linux machine and my pi4 with bullseye
                                        Blackeye @sdetweil
                                        @sdetweil said in Default Weather module still not displaying:
                                        ~/MagicMirror/node_modules/.bin/electron-rebuild -e …/…/node_modules/electron
                                        Yes! It installed correctly this time, so that change in the path did the trick. I did get some warnings however:
                                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain cir                                 cumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                        So it is not quite a perfect solution, but it works!
                                        Many thanks for the suggestions and the solution!
                                          sdetweil @Blackeye
                                          @Blackeye ignore the warnings, nothing we can do about them.
                                          the ‘problem’ here is that the compiler needs to know what version of electron to build for, but can’t figure it out.
                                          using electron-rebuild from the mm libs solves that
