    Need some help installing on Win10
    12 Posts 2 Posters 5.6k Views 2 Watching
    • C
      CheapDad
      I’m in the process of installing the MM software on my daughter’s laptop as an interim solution until I can build her a proper mirror.
      I followed the following instructions:
      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
      I completed the npm install step and then ran npm start. I then got this error:
      > magicmirror@2.20.0 start
      'DISPLAY' is not recognized as an internal or external command, operable program or batch file.
      Based upon the guidance in this thread:
      https://forum.magicmirror.builders/topic/12543/installing-magic-mirror-on-windows-10?lang=en-US&page=1
      I edited out the “DISPLAY” entries. I re-ran npm start and got this:
      'node_modules' is not recognized as an internal or external command,
      I’m stuck. Can anyone help?
        sdetweil @CheapDad
        @CheapDad yes npm screwed it up for windows.
        change each / to \\
        on the start clause unedited the display off of
        • C
          CheapDad @sdetweil
          @sdetweil Sam, add the display entries back in? Otherwise, is this correct?
          	"start": "node_modules\\.bin/electron js\\electron.js",
          		"start:dev": "node_modules\\.bin/electron js\\electron.js dev",
            sdetweil @CheapDad
            @CheapDad said in Need some help installing on Win10:
            “start”: “node_modules\\.bin/electron js\\electron.js”,
            all of the \
            u missed the bin/electron
            • C
              CheapDad @sdetweil
              @sdetweil Sam, I made those corrections and edited the config.js. I commented out all of the modules except the clock. (My intent is to only have one module, not yet installed, running.)
              When I did an npm start with only the sample config.js present, I got a black screen. I could press “alt” to get to the “File” menu and close MM.
              When I ran MM from Git BASH, I got another black screen, except this time “alt” did not do anything. “alt” and “esc” would minimize MM, but that’s it. Here’s what GIT BASH displays when I ran npm start with my edited config.js:
              $ npm start
              npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
              > node_modules\.bin\electron js\electron.js
              [09.08.2022 20:50.32.077] [LOG]   Starting MagicMirror: v2.20.0
              [09.08.2022 20:50.32.082] [LOG]   Loading config ...
              [09.08.2022 20:50.32.091] [LOG]   Loading module helpers ...
              [09.08.2022 20:50.32.092] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading 'split')
              [09.08.2022 20:50.32.093] [LOG]   Loading module helpers ...
              [09.08.2022 20:50.32.094] [ERROR] App threw an error during load
              [09.08.2022 20:50.32.095] [ERROR] TypeError: Cannot read properties of undefined (reading 'split')
                  at loadModule (C:\Users\Hannah\magicmirror\js\app.js:108:27)
                  at loadNextModule (C:\Users\Hannah\magicmirror\js\app.js:165:5)
                  at loadModules (C:\Users\Hannah\magicmirror\js\app.js:176:3)
                  at C:\Users\Hannah\magicmirror\js\app.js:225:4
                  at loadConfig (C:\Users\Hannah\magicmirror\js\app.js:81:4)
                  at App.start (C:\Users\Hannah\magicmirror\js\app.js:212:3)
                  at Object.<anonymous> (C:\Users\Hannah\magicmirror\js\electron.js:159:7)
                  at Module._compile (node:internal/modules/cjs/loader:1118:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
                  at Module.load (node:internal/modules/cjs/loader:988:32)
              [09.08.2022 20:50.32.097] [ERROR] Whoops! There was an uncaught exception...
              [09.08.2022 20:50.32.101] [ERROR] TypeError: Cannot read properties of undefined (reading 'split')
              [09.08.2022 20:50.32.103] [ERROR] MagicMirror┬▓ will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [09.08.2022 20:50.32.104] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              [09.08.2022 20:50.32.201] [LOG]   Launching application.
              [11036:0809/205232.493:ERROR:gpu_init.cc(481)] Passthrough is not supported, GL is disabled, ANGLE is
                sdetweil @CheapDad
                @CheapDad usually this is a bad position string
                • C
                  CheapDad @sdetweil
                  @sdetweil said in Need some help installing on Win10:
                  Sam, my apologies but I have no idea what this means. A google search didn’t reveal anything that appeared to be on point either.
                    sdetweil @CheapDad
                    @CheapDad
                            module: ",,,,,,",
                            position: "xxx_yyy",   <----- that thing  (the 'position' string
                    or mis-spelling ‘position’
                    • C
                      CheapDad @sdetweil
                      @sdetweil Thank you! Two other questions:
                      1. I assume that since this latest black screen occurred after I used my edited config.js, that’s where I need to look for the error. Correct?
                      2. Once that correction is made, should I then see the MM running in a window? I ask because I had received a black screen previously using the sample config.js
                        sdetweil @CheapDad
                        @CheapDad you did the two extra steps to install in fonts and vendor , right?
                        the sample config should work unchanged
                        it should be the same as on linux… full screen…
                        • C
                          CheapDad @sdetweil
                          @sdetweil I didn’t do the extra steps. I was hoping to get the confirmation that I needed a working config.js that the walkthrough speaks about. I’ll run those extra steps.
                            sdetweil @CheapDad
                            @CheapDad see
                            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
