    RPI 3B keeps going to blank screen (cursor showing)
    27 Posts 5 Posters 12.7k Views 5 Watching
    • B
      BigTJ @sdetweil
      I’ll give that a go in the next few days.
      • BKeyportB
        @sdetweil Course, now begs the question… “What if there’s no npm start line?”
        run-start.sh is used. :)
          sdetweil @BKeyport
          @BKeyport do it the same. run-start does npm run server
          but at that point, there is no electron…
          B 1 Reply Last reply
          • B
            BigTJ @sdetweil
            Thanks for all your efforts and assistance. After many reloads of the OS and the MM software I still have the same issue. After searching for similar Pi problems outside of MM it appears that this can happen due to hardware failure. I am now going to purchase a new pi and start from the beginning. Will report back on success or failure in due course. Thanks to everyone that has offered help and assistance.
            BigTJ
            C 1 Reply Last reply
            • C
              costascontis @BigTJ
              i have the same “problem” i think…New installation mirror works just fine for hours or even a day or two,then black screen with cursor.No network,so i cant restart it properly.I did disable gpu so no error massage anymore and i did the " npm init -y" thing inside every module folder.No solution yet…
              • B
                BigTJ
                Finally resolved my black screen issue!
                After replacing the Pi 3B, the SD card, the OS, using the latest MM software, much internet searching and a great deal of help through this forum it appears the problem is being caused by the jpg photos being added to the wallpaper module. Changing the photos from large tif files into jpg files using Adobe lightroom creates a highly compressed jpg file that the wallpaper module cannot deal with properly.
                Reducing the resolution of the files during the conversion seems to create a less compressed jpg file that the Wallpaper module can deal with.
                Hope this helps others with the same issue.
                Reply Quote 1
                  sdetweil @BigTJ
                  @BigTJ very cool detective work! glad you found a resolution!!
