    Notion Integration
    Scheduled Pinned Locked Moved Unsolved Development
    2 Posts 2 Posters 1.1k Views 2 Watching
    • A
      Amit5001
      Hi, I’m trying to make integration between my Notion To-do list to the MM.
      I wrote a code using Notion API to get all the data I need from my database but I can’t figure out how to write it as a module and add it to the mirror. I want to display the list like the calendar module work.
      The code I have right now is:
      My database is:
      Can someone help me write it as a module?
      Thanks in advance!
        sdetweil @Amit5001
        @Amit5001 so, you will need to write a module.
        mm runs inside a browser, electron, chrome, Firefox, … it displays one web page
        each module gets data from somewhere and builds a small blob of html, or dom content, and gives that to mm, which places it in the browser DOM in the position you configured
        the spec is here
        https://docs.magicmirror.builders/development/introduction.html
        you can use my SampleModule as a starting place, it’s got all the parts
        https://github.com/sdetweil/SampleModule
        something to do before that, is to figure out how u want it displayed and build the html to do that, it’s just text. you can test that output in any browser.
        a module is split into 2 parts.
        the part that runs in the browser and does all the display work
        I call it modulename.js cause it’s filename matches the module name. it’s the part that interfaces to mm
        but a browser cannot read files (incl database) or touch hardware directly. for security. browser cannot import or require to load libraries.
        so if u need to do that, you use the helper, called node_helper.js. there is a small communication mechanism between the two parts.
        modulename.js sends a message, send socket notification
        and the helper receives them, receiveSocketNotification
        when done the exact same calls are used in the other direction. helper sends module name.js receives. this is a private channel between this module and it’s helper.
