    Can't access per browser, whitelist?
    3 Posts 2 Posters 793 Views 2 Watching
    • D
      Dodo88
      Hi together!
      i installed the software per automatic install, it works well, the pi booted and the software open on the monitor.
      But i want have access from another device, and it doesn’t work.
      if i type http://localhost:8080 on my raspberry browser, i get the correct screen, if i type this url on my laptop, there comes only the message "Beim Verbinden mit 192.168.178.33 trat ein Fehler auf. "
      in config.js i set the whitelist to " ipWhitelist: []," but it doesn’t work =( can somebody help me pls?
      greets Dodo
        sdetweil @Dodo88
        @Dodo88 you also have to change address:
        to
        address:"0.0.0.0",
        as
        address:"localhost"
        means ONLY apps INSIDE the same machine can connect
        • D
          Dodo88 @sdetweil
          Thx that was it! Much thanks!
