    MMM-Fuel black screen
    20 Posts 4 Posters 3.6k Views 4 Watching
    • ArzegA Offline
      Arzeg
      Hey guys,
      after updating to MM version 2.21.0 I had a black screen. I have previously saved the config.js file as well as the module folder and the main.css file and reinstalled after the update. The logs then showed that the module “MMM-Fuel” apparently makes problems, when I removed the inclusion from the config.js, it ran again. I then reinstalled the MMM-Fuel module, but the error remains.
      Logs:
      0|mm     | [02.10.2022 16:21.50.820] [ERROR]
      0|mm     | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'fs/promises'
      0|mm     | Require stack:
      0|mm     | - /home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js
      0|mm     | - /home/pi/MagicMirror/js/app.js
      0|mm     | - /home/pi/MagicMirror/js/electron.js
      0|mm     | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      0|mm     | -
      0|mm     | [02.10.2022 16:21.50.823] [LOG]   Loading module helpers ...
      0|mm     | [02.10.2022 16:21.50.827] [LOG]   No helper found for module: alert.
      0|mm     | [02.10.2022 16:21.50.831] [LOG]   Initializing new module helper ...
      0|mm     | [02.10.2022 16:21.50.834] [LOG]   Module helper loaded: updatenotification
      0|mm     | [02.10.2022 16:21.50.838] [LOG]   No helper found for module: clock.
      0|mm     | [02.10.2022 16:21.50.842] [LOG]   No helper found for module: weather.
      0|mm     | [02.10.2022 16:21.50.845] [LOG]   Initializing new module helper ...
      0|mm     | [02.10.2022 16:21.50.848] [LOG]   Module helper loaded: newsfeed
      0|mm     | [02.10.2022 16:21.50.857] [ERROR]
      0|mm     | App threw an error during load
      0|mm     | [02.10.2022 16:21.50.861] [ERROR] Error: Cannot find module 'fs/promises'
      0|mm     | -
      0|mm     |     at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
      0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
      0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|mm     |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
      0|mm     |     at Module.require (internal/modules/cjs/loader.js:685:19)
      0|mm     |     at require (internal/modules/cjs/helpers.js:16:16)
      0|mm     |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js:26:12)
      0|mm     |     at Module._compile (internal/modules/cjs/loader.js:786:30)
      0|mm     |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
      0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32)
      0|mm     | [02.10.2022 16:21.50.869] [ERROR]
      0|mm     | Whoops! There was an uncaught exception...
      0|mm     | [02.10.2022 16:21.50.901] [ERROR]
      0|mm     | Error: Cannot find module 'fs/promises'
      0|mm     | -
      0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32) {
      0|mm     |   code: 'MODULE_NOT_FOUND',
      0|mm     |   requireStack: [
      0|mm     |     '/home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js',
      0|mm     |     '/home/pi/MagicMirror/js/app.js',
      0|mm     |     '/home/pi/MagicMirror/js/electron.js',
      0|mm     |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      0|mm     |     undefined
      0|mm     |   ]
      0|mm     | }
      0|mm     | [02.10.2022 16:21.50.906] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm     | [02.10.2022 16:21.50.909] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm     | [02.10.2022 16:21.51.317] [LOG]
      0|mm     | Launching application.
      0|mm     | [29573:1002/162153.771840:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
      what am i missing?
        sdetweil @Arzeg
        @Arzeg how did u upgrade?
        can u tell me the output of
        node -v
        npm -v
        an ‘attempt’ at a work around
        edit the module node_helper.js
        change the line
         const fs = require('fs/promises')
        to
         const fs = require('fs').promises
        I opened this issue on module github
        https://github.com/fewieden/MMM-Fuel/issues/99
        ArzegA 1 Reply Last reply Reply Quote 1
        • ArzegA Offline
          Arzeg @sdetweil
          Thanks for the fast reply.
          node version: 16.15.1
          npm version: 8.11.0
          Changed the line in the node_helper.js file.
          looks good now, but i need to Update my API key.
          What confuses me a bit is that the other modules are not affected, since I have the node_helper.js file in each module.
          Oh and thank you for opening the issue on github
            sdetweil @Arzeg
            @Arzeg I don’t know why either … the author is very careful and quite proficient
            glad the workaround worked…
              sdetweil @Arzeg
              @Arzeg also, the particular library is not used in many modules, so would not affect more than 2 or 3 out of hundreds
              ArzegA 1 Reply Last reply Reply Quote 0
              • ArzegA Offline
                Arzeg @sdetweil
                @sdetweil Okay.
                Unfortunately, there is still an error with the workaround. I have requested a new API key (which works by calling it from the address bar of a browser) but now I get an error message from the module that the API key has expired.
                0|mm     | MMM-Fuel: Failed to retrieve prices FetchError: request to https://creativecommons.tankerkoenig.de/json/list.php?lat=51.40488&lng=8.06148&rad=5&type=all&apikey=xxxxxx-xxxxx-xxxxx-xxxxx&sort=dist failed, reason: certificate has expired
                0|mm     |     at ClientRequest.<anonymous> (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/node-fetch/lib/index.js:1491:11)
                0|mm     |     at ClientRequest.emit (events.js:200:13)
                0|mm     |     at TLSSocket.socketErrorListener (_http_client.js:402:9)
                0|mm     |     at TLSSocket.emit (events.js:200:13)
                0|mm     |     at emitErrorNT (internal/streams/destroy.js:91:8)
                0|mm     |     at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                0|mm     |     at processTicksAndRejections (internal/process/task_queues.js:84:9) {
                0|mm     |   message: 'request to ' +
                0|mm     |     'https://creativecommons.tankerkoenig.de/json/list.php?lat=51.40488&lng=8.06148&rad=5&type=all&apikey=xxxxxxx-xxxxx-xxxxx-xxxxx-xxxxx&sort=dist ' +
                0|mm     |     'failed, reason: certificate has expired',
                0|mm     |   type: 'system',
                0|mm     |   errno: 'CERT_HAS_EXPIRED',
                0|mm     |   code: 'CERT_HAS_EXPIRED'
                0|mm     | }
                  sdetweil @Arzeg
                  @Arzeg said in MMM-Fuel black screen:
                  i don’t know how to fix that one
                  that is the server side certificate required to make https: work
                  there was a bug at one time (4 releases ago) where the runtime(electron) mis handled certificates, but we put a fix in for that
                  I opened this issue
                  https://github.com/fewieden/MMM-Fuel/issues/100
                  also opened on in MM
                  https://github.com/MichMich/MagicMirror/issues/2924
                  • ArzegA Offline
                    Arzeg @sdetweil
                    @sdetweil Thanks for your help. How can I check if electron is up to date. Possibly that is where the problem lies
                      sdetweil @Arzeg
                      @Arzeg we use version 19 in this release
                      at the commandline do
                      grep  version ~/MagicMirror/node_modules/electron/package.json
                      • ArzegA Offline
                        Arzeg @sdetweil
                        @sdetweil My version is: 6.1.12 how can i update this?
                          sdetweil @Arzeg
                          @Arzeg eh?
                          can’t be
                          should be this
                            "version": "19.0.15",
                          the release upgrade moved us from 17 to 19 (I am incorrect here, see later posts)
                          hm… how did u upgrade?
                          manual or my script?
                          lets check the package.json requested version
                          grep \"electron\": ~/MagicMirror/package.json
                          		"electron": "^19.0.15"
                          • karsten13K Offline
                            karsten13
                            @sdetweil said in MMM-Fuel black screen:
                            no, we were already on v19 with release v2.20.0, now we are on v19.1.0 (not v19.0.15)
                            • ArzegA Offline
                              Arzeg @sdetweil
                              @sdetweil ehm … i copied your command:
                                "version": "6.1.12",
                              But that’s weird, I completely rebuilt the mirror about half a year ago. I can’t imagine that in that time the versions have moved from 6 to 19.
                                sdetweil @Arzeg
                                @Arzeg weird try this updated
                                grep  version /home/pi/MagicMirror/node_modules/electron/package.json
                                "electron": "^6.1.12"
                                please advise how you upgraded
                                manual (git pull & npm install )
                                or automated (my script)
                                • ArzegA Offline
                                  Arzeg @sdetweil
                                  @sdetweil manual with pull and npm install
                                    sdetweil @Arzeg
                                    @Arzeg starting to look like it failed
                                    can u do this
                                    run my script
                                    see https://github.com/sdetweil/MagicMirror_scripts
                                    two passes
                                    with no parameter, I want to see what it says
                                    then with force (instead of the documented apply)
                                    as u have 2.21 installed already and it would normally abort…
                                    then I want to see
                                    ~/MagicMirror/installers/upgrade.log
                                    It may be too big to post here
                                    you could attach it to the cert issue I opened
                                    or email it to me
                                    my same userid at gmail (the userid I posted this message under)
                                    • ArzegA Offline
                                      Arzeg @sdetweil
                                      with no params:
                                      install log being saved to /home/pi/install.log
                                      Installing helper tools ...
                                      Updating packages ...
                                      Check current Node installation ...
                                      Node currently installed. Checking version number.
                                      Minimum Node version: v16.9.1
                                      Installed Node version: v16.15.1
                                      No Node.js upgrade necessary.
                                      Check current NPM installation ...
                                      NPM currently installed. Checking version number.
                                      Minimum npm version: V7.11.2
                                      Installed npm version: V8.11.0
                                      No npm upgrade necessary.
                                      It seems like MagicMirror is already installed.
                                      To prevent overwriting, the installer will be aborted.
                                      Please rename the ~/MagicMirror folder and try again.
                                      with force:
                                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                      No LSB modules are available.
                                      doing test run = false
                                      update log will be in /home/pi/MagicMirror/installers/upgrade.log
                                      upgrading from version 2.21.0 to 2.21.0
                                      fetching latest revisions
                                      updating MagicMirror runtime, please wait
                                      npm WARN invalid config omit="dev --no-audit --no-fund --no-update-notifier" set in command line options
                                      npm WARN invalid config Must be one or more of: dev, optional, peer
                                      > magicmirror@2.21.0 postinstall
                                      > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                                      > magicmirror@2.21.0 install-vendor
                                      > echo "Installing vendor files ...
                                      > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                      up to date in 2s
                                      > magicmirror@2.21.0 install-fonts
                                      > echo "Installing fonts ...
                                      > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                      up to date in 2s
                                      > magicmirror@2.21.0 prepare
                                      > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                                      husky - Git hooks installed
                                      up to date, audited 754 packages in 58s
                                      91 packages are looking for funding
                                        run `npm fund` for details
                                      3 moderate severity vulnerabilities
                                      To address all issues (including breaking changes), run:
                                        npm audit fix --force
                                      Run `npm audit` for details.
                                      Checking for modules with removed libraries
                                               require for request in module MMM-Reddit not found in package.json package.json for module MMM-Reddit
                                      installing request for module MMM-Reddit
                                      npm WARN old lockfile
                                      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                      npm WARN old lockfile This is a one-time fix-up, please be patient...
                                      npm ERR! code ENOTEMPTY
                                      npm ERR! syscall rename
                                      npm ERR! path /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/ajv
                                      npm ERR! dest /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/.ajv-s6Phgkfd
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/ajv' -> '/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/.ajv-s6Phgkfd'
                                      npm ERR!     /home/pi/.npm/_logs/2022-10-02T16_46_07_715Z-debug-0.log
                                      processing dependency changes for active modules with package.json files
                                      processing for module MMM-Fuel please wait
                                      npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
                                      added 537 packages, and audited 538 packages in 3m
                                      89 packages are looking for funding
                                      found 0 vulnerabilities
                                      processing complete for module MMM-Fuel
                                      processing for module MMM-Strava please wait
                                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                      npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforked package instead: postcss-markdown
                                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                      added 441 packages, and audited 442 packages in 3m
                                      81 packages are looking for funding
                                      2 moderate severity vulnerabilities
                                      processing complete for module MMM-Strava
                                      processing for module MMM-Todoist please wait
                                      added 50 packages, and audited 51 packages in 19s
                                      3 packages are looking for funding
                                      processing complete for module MMM-Todoist
                                      This was the second time i run the command with force, because at the first time, it stuck for about 30 minutes at the same point
                                      ⠸ reify:lodash: timing reify:audit Completed in 125567ms
                                      so i decided to restart the script with force.
                                      I restartet the mm and it works now! Thanks!
                                      Do you still want to see the upgrade.log?
                                        sdetweil @Arzeg
                                        @Arzeg rerun with force again. I JUST uploaded a fix to the parameter order on npm i stall
                                        • ArzegA Offline
                                          Arzeg @sdetweil
                                          @sdetweil Still works ;-)
                                          (23) Failed writing body
                                          up to date in 2s
                                          up to date in 2s
                                          up to date, audited 754 packages in 55s
                                          npm ERR! errno -39
                                          npm ERR!     /home/pi/.npm/_logs/2022-10-02T17_33_12_018Z-debug-0.log
                                          added 537 packages, and audited 538 packages in 2m
                                          added 441 packages, and audited 442 packages in 2m
                                          added 50 packages, and audited 51 packages in 16s
                                          oh, and electron is also now on version 19.1.0
                                          • strawberry 3.141S Offline
                                            strawberry 3.141 Project Sponsor Module Developer @Arzeg
                                            @Arzeg I looked into your issue with Error: Cannot find module 'fs/promises'.
                                            I installed the same node version as you 16.15.1 and did a fresh install of MagicMirror and MMM-Fuel.
                                            The problem does not appear, the module is already available since node 14, see the documentation. https://nodejs.org/dist/latest-v16.x/docs/api/fs.html#promises-api
                                            How did you install nodejs, which versions had you before on this system? How do you run the mirror? I currently assume that you might run the mirror in a way that it picks an older installation of nodejs on your system.
