    MMM-Fuel black screen
    20 Posts 4 Posters 4.7k Views 4 Watching
    • ArzegA
      Arzeg @sdetweil
      @sdetweil Okay.
      Unfortunately, there is still an error with the workaround. I have requested a new API key (which works by calling it from the address bar of a browser) but now I get an error message from the module that the API key has expired.
      0|mm     | MMM-Fuel: Failed to retrieve prices FetchError: request to https://creativecommons.tankerkoenig.de/json/list.php?lat=51.40488&lng=8.06148&rad=5&type=all&apikey=xxxxxx-xxxxx-xxxxx-xxxxx&sort=dist failed, reason: certificate has expired
      0|mm     |     at ClientRequest.<anonymous> (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/node-fetch/lib/index.js:1491:11)
      0|mm     |     at ClientRequest.emit (events.js:200:13)
      0|mm     |     at TLSSocket.socketErrorListener (_http_client.js:402:9)
      0|mm     |     at TLSSocket.emit (events.js:200:13)
      0|mm     |     at emitErrorNT (internal/streams/destroy.js:91:8)
      0|mm     |     at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
      0|mm     |     at processTicksAndRejections (internal/process/task_queues.js:84:9) {
      0|mm     |   message: 'request to ' +
      0|mm     |     'https://creativecommons.tankerkoenig.de/json/list.php?lat=51.40488&lng=8.06148&rad=5&type=all&apikey=xxxxxxx-xxxxx-xxxxx-xxxxx-xxxxx&sort=dist ' +
      0|mm     |     'failed, reason: certificate has expired',
      0|mm     |   type: 'system',
      0|mm     |   errno: 'CERT_HAS_EXPIRED',
      0|mm     |   code: 'CERT_HAS_EXPIRED'
      0|mm     | }
        sdetweil @Arzeg
        @Arzeg said in MMM-Fuel black screen:
        i don’t know how to fix that one
        that is the server side certificate required to make https: work
        there was a bug at one time (4 releases ago) where the runtime(electron) mis handled certificates, but we put a fix in for that
        I opened this issue
        https://github.com/fewieden/MMM-Fuel/issues/100
        also opened on in MM
        https://github.com/MichMich/MagicMirror/issues/2924
        ArzegA 1 Reply Last reply
        • ArzegA
          Arzeg @sdetweil
          @sdetweil Thanks for your help. How can I check if electron is up to date. Possibly that is where the problem lies
            sdetweil @Arzeg
            @Arzeg we use version 19 in this release
            at the commandline do
            grep  version ~/MagicMirror/node_modules/electron/package.json
            • ArzegA
              Arzeg @sdetweil
              @sdetweil My version is: 6.1.12 how can i update this?
                sdetweil @Arzeg
                @Arzeg eh?
                can’t be
                should be this
                  "version": "19.0.15",
                the release upgrade moved us from 17 to 19 (I am incorrect here, see later posts)
                hm… how did u upgrade?
                manual or my script?
                lets check the package.json requested version
                grep \"electron\": ~/MagicMirror/package.json
                		"electron": "^19.0.15"
                • karsten13K
                  karsten13
                  @sdetweil said in MMM-Fuel black screen:
                  no, we were already on v19 with release v2.20.0, now we are on v19.1.0 (not v19.0.15)
                  • ArzegA
                    Arzeg @sdetweil
                    @sdetweil ehm … i copied your command:
                      "version": "6.1.12",
                    But that’s weird, I completely rebuilt the mirror about half a year ago. I can’t imagine that in that time the versions have moved from 6 to 19.
                      sdetweil @Arzeg
                      @Arzeg weird try this updated
                      grep  version /home/pi/MagicMirror/node_modules/electron/package.json
                      "electron": "^6.1.12"
                      please advise how you upgraded
                      manual (git pull & npm install )
                      or automated (my script)
                      • ArzegA
                        Arzeg @sdetweil
                        @sdetweil manual with pull and npm install
                          sdetweil @Arzeg
                          @Arzeg starting to look like it failed
                          can u do this
                          run my script
                          see https://github.com/sdetweil/MagicMirror_scripts
                          two passes
                          with no parameter, I want to see what it says
                          then with force (instead of the documented apply)
                          as u have 2.21 installed already and it would normally abort…
                          then I want to see
                          ~/MagicMirror/installers/upgrade.log
                          It may be too big to post here
                          you could attach it to the cert issue I opened
                          or email it to me
                          my same userid at gmail (the userid I posted this message under)
                          • ArzegA
                            Arzeg @sdetweil
                            with no params:
                            install log being saved to /home/pi/install.log
                            Installing helper tools ...
                            Updating packages ...
                            Minimum Node version: v16.9.1
                            Installed Node version: v16.15.1
                            No Node.js upgrade necessary.
                            Minimum npm version: V7.11.2
                            Installed npm version: V8.11.0
                            No npm upgrade necessary.
                            It seems like MagicMirror is already installed.
                            To prevent overwriting, the installer will be aborted.
                            Please rename the ~/MagicMirror folder and try again.
                            with force:
                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                            No LSB modules are available.
                            doing test run = false
                            upgrading from version 2.21.0 to 2.21.0
                            fetching latest revisions
                            npm WARN invalid config omit="dev --no-audit --no-fund --no-update-notifier" set in command line options
                            npm WARN invalid config Must be one or more of: dev, optional, peer
                            > magicmirror@2.21.0 postinstall
                            > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                            > magicmirror@2.21.0 install-vendor
                            > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                            up to date in 2s
                            > magicmirror@2.21.0 install-fonts
                            > echo "Installing fonts ...
                            > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                            up to date in 2s
                            > magicmirror@2.21.0 prepare
                            > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                            husky - Git hooks installed
                            up to date, audited 754 packages in 58s
                            91 packages are looking for funding
                              run `npm fund` for details
                            3 moderate severity vulnerabilities
                            To address all issues (including breaking changes), run:
                              npm audit fix --force
                            Run `npm audit` for details.
                                     require for request in module MMM-Reddit not found in package.json package.json for module MMM-Reddit
                            installing request for module MMM-Reddit
                            npm WARN old lockfile
                            npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                            npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                            npm WARN old lockfile This is a one-time fix-up, please be patient...
                            npm ERR! code ENOTEMPTY
                            npm ERR! syscall rename
                            npm ERR! path /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/ajv
                            npm ERR! dest /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/.ajv-s6Phgkfd
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/ajv' -> '/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/.ajv-s6Phgkfd'
                            npm ERR!     /home/pi/.npm/_logs/2022-10-02T16_46_07_715Z-debug-0.log
                            processing for module MMM-Fuel please wait
                            npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
                            added 537 packages, and audited 538 packages in 3m
                            89 packages are looking for funding
                            found 0 vulnerabilities
                            processing complete for module MMM-Fuel
                            processing for module MMM-Strava please wait
                            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforked package instead: postcss-markdown
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            added 441 packages, and audited 442 packages in 3m
                            81 packages are looking for funding
                            2 moderate severity vulnerabilities
                            processing complete for module MMM-Strava
                            processing for module MMM-Todoist please wait
                            added 50 packages, and audited 51 packages in 19s
                            3 packages are looking for funding
                            processing complete for module MMM-Todoist
                            This was the second time i run the command with force, because at the first time, it stuck for about 30 minutes at the same point
                            ⠸ reify:lodash: timing reify:audit Completed in 125567ms
                            so i decided to restart the script with force.
                            I restartet the mm and it works now! Thanks!
                            Do you still want to see the upgrade.log?
                              sdetweil @Arzeg
                              @Arzeg rerun with force again. I JUST uploaded a fix to the parameter order on npm i stall
                              • ArzegA
                                Arzeg @sdetweil
                                @sdetweil Still works ;-)
                                (23) Failed writing body
                                up to date in 2s
                                up to date in 2s
                                up to date, audited 754 packages in 55s
                                npm ERR! errno -39
                                npm ERR!     /home/pi/.npm/_logs/2022-10-02T17_33_12_018Z-debug-0.log
                                added 537 packages, and audited 538 packages in 2m
                                added 441 packages, and audited 442 packages in 2m
                                added 50 packages, and audited 51 packages in 16s
                                oh, and electron is also now on version 19.1.0
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @Arzeg
                                  @Arzeg I looked into your issue with Error: Cannot find module 'fs/promises'.
                                  I installed the same node version as you 16.15.1 and did a fresh install of MagicMirror and MMM-Fuel.
                                  The problem does not appear, the module is already available since node 14, see the documentation. https://nodejs.org/dist/latest-v16.x/docs/api/fs.html#promises-api
                                  How did you install nodejs, which versions had you before on this system? How do you run the mirror? I currently assume that you might run the mirror in a way that it picks an older installation of nodejs on your system.
