    MMM-Fuel black screen
    20 Posts 4 Posters 2.6k Views 4 Watching
      sdetweil @Arzeg
      @Arzeg eh?
      can’t be
      should be this
      grep  version ~/MagicMirror/node_modules/electron/package.json
        "version": "19.0.15",
      the release upgrade moved us from 17 to 19 (I am incorrect here, see later posts)
      hm… how did u upgrade?
      manual or my script?
      lets check the package.json requested version
      grep \"electron\": ~/MagicMirror/package.json
      		"electron": "^19.0.15"
      ArzegA 1 Reply Last reply Reply Quote 0
      • karsten13K Offline
        karsten13
        @sdetweil said in MMM-Fuel black screen:
        no, we were already on v19 with release v2.20.0, now we are on v19.1.0 (not v19.0.15)
        • ArzegA Offline
          Arzeg @sdetweil
          @sdetweil ehm … i copied your command:
            "version": "6.1.12",
          But that’s weird, I completely rebuilt the mirror about half a year ago. I can’t imagine that in that time the versions have moved from 6 to 19.
            sdetweil @Arzeg
            @Arzeg weird try this updated
            grep  version /home/pi/MagicMirror/node_modules/electron/package.json
            "electron": "^6.1.12"
            please advise how you upgraded
            manual (git pull & npm install )
            or automated (my script)
            • ArzegA Offline
              Arzeg @sdetweil
              @sdetweil manual with pull and npm install
                sdetweil @Arzeg
                @Arzeg starting to look like it failed
                can u do this
                run my script
                see https://github.com/sdetweil/MagicMirror_scripts
                two passes
                with no parameter, I want to see what it says
                then with force (instead of the documented apply)
                as u have 2.21 installed already and it would normally abort…
                then I want to see
                ~/MagicMirror/installers/upgrade.log
                It may be too big to post here
                you could attach it to the cert issue I opened
                or email it to me
                my same userid at gmail (the userid I posted this message under)
                ArzegA 1 Reply Last reply Reply Quote 1
                • ArzegA Offline
                  Arzeg @sdetweil
                  with no params:
                  install log being saved to /home/pi/install.log
                  Installing helper tools ...
                  Updating packages ...
                  Check current Node installation ...
                  Node currently installed. Checking version number.
                  Minimum Node version: v16.9.1
                  Installed Node version: v16.15.1
                  No Node.js upgrade necessary.
                  Check current NPM installation ...
                  NPM currently installed. Checking version number.
                  Minimum npm version: V7.11.2
                  Installed npm version: V8.11.0
                  No npm upgrade necessary.
                  It seems like MagicMirror is already installed.
                  To prevent overwriting, the installer will be aborted.
                  Please rename the ~/MagicMirror folder and try again.
                  with force:
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  No LSB modules are available.
                  doing test run = false
                  update log will be in /home/pi/MagicMirror/installers/upgrade.log
                  upgrading from version 2.21.0 to 2.21.0
                  fetching latest revisions
                  updating MagicMirror runtime, please wait
                  npm WARN invalid config omit="dev --no-audit --no-fund --no-update-notifier" set in command line options
                  npm WARN invalid config Must be one or more of: dev, optional, peer
                  > magicmirror@2.21.0 postinstall
                  > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                  > magicmirror@2.21.0 install-vendor
                  > echo "Installing vendor files ...
                  > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  up to date in 2s
                  > magicmirror@2.21.0 install-fonts
                  > echo "Installing fonts ...
                  > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                  up to date in 2s
                  > magicmirror@2.21.0 prepare
                  > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                  husky - Git hooks installed
                  up to date, audited 754 packages in 58s
                  91 packages are looking for funding
                    run `npm fund` for details
                  3 moderate severity vulnerabilities
                  To address all issues (including breaking changes), run:
                    npm audit fix --force
                  Run `npm audit` for details.
                  Checking for modules with removed libraries
                           require for request in module MMM-Reddit not found in package.json package.json for module MMM-Reddit
                  installing request for module MMM-Reddit
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                  npm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/ajv
                  npm ERR! dest /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/.ajv-s6Phgkfd
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/ajv' -> '/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/.ajv-s6Phgkfd'
                  npm ERR!     /home/pi/.npm/_logs/2022-10-02T16_46_07_715Z-debug-0.log
                  processing dependency changes for active modules with package.json files
                  processing for module MMM-Fuel please wait
                  npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
                  added 537 packages, and audited 538 packages in 3m
                  89 packages are looking for funding
                  found 0 vulnerabilities
                  processing complete for module MMM-Fuel
                  processing for module MMM-Strava please wait
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                  npm WARN deprecated @stylelint/postcss-markdown@0.36.2: Use the original unforked package instead: postcss-markdown
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  added 441 packages, and audited 442 packages in 3m
                  81 packages are looking for funding
                  2 moderate severity vulnerabilities
                  processing complete for module MMM-Strava
                  processing for module MMM-Todoist please wait
                  added 50 packages, and audited 51 packages in 19s
                  3 packages are looking for funding
                  processing complete for module MMM-Todoist
                  This was the second time i run the command with force, because at the first time, it stuck for about 30 minutes at the same point
                  ⠸ reify:lodash: timing reify:audit Completed in 125567ms
                  so i decided to restart the script with force.
                  I restartet the mm and it works now! Thanks!
                  Do you still want to see the upgrade.log?
                    sdetweil @Arzeg
                    @Arzeg rerun with force again. I JUST uploaded a fix to the parameter order on npm i stall
                    • ArzegA Offline
                      Arzeg @sdetweil
                      @sdetweil Still works ;-)
                      (23) Failed writing body
                      up to date in 2s
                      up to date in 2s
                      up to date, audited 754 packages in 55s
                      npm ERR! errno -39
                      npm ERR!     /home/pi/.npm/_logs/2022-10-02T17_33_12_018Z-debug-0.log
                      added 537 packages, and audited 538 packages in 2m
                      added 441 packages, and audited 442 packages in 2m
                      added 50 packages, and audited 51 packages in 16s
                      oh, and electron is also now on version 19.1.0
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @Arzeg
                        @Arzeg I looked into your issue with Error: Cannot find module 'fs/promises'.
                        I installed the same node version as you 16.15.1 and did a fresh install of MagicMirror and MMM-Fuel.
                        The problem does not appear, the module is already available since node 14, see the documentation. https://nodejs.org/dist/latest-v16.x/docs/api/fs.html#promises-api
                        How did you install nodejs, which versions had you before on this system? How do you run the mirror? I currently assume that you might run the mirror in a way that it picks an older installation of nodejs on your system.
