    Updated MM2 - Local Host Refused Connection Error
    6 Posts 2 Posters 1.2k Views 2 Watching
      BD0G
      Re: Should I update?
      I just updated and I get a “Connection Refused message” when I launch MM2 .
      Here is the output from when I use npm start.
      pi@MagicMirror:~/MagicMirror/config $ npm start
      magicmirror@2.21.0 start
      ./run-start.sh $1
      node:internal/modules/cjs/loader:959
      throw err;
      Error: Cannot find module ‘module-alias/register’
      Require stack:
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/serveronly/index.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        at Module.require (node:internal/modules/cjs/loader:1028:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object. (/home/pi/MagicMirror/js/app.js:9:1)
        at Module._compile (node:internal/modules/cjs/loader:1126:14)
        at Object.Module._extensions…js (node:internal/modules/cjs/loader:1180:10)
        at Module.load (node:internal/modules/cjs/loader:1004:32)
        at Function.Module._load (node:internal/modules/cjs/loader:839:12)
        at Module.require (node:internal/modules/cjs/loader:1028:19) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/pi/MagicMirror/js/app.js’,
        ‘/home/pi/MagicMirror/serveronly/index.js’
        Starting chromium browser now, have patience, it takes a minute
        –disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
        BD0G @BD0G
        @BD0G said in Updated and MM2 no longer launches:
        I used this update process https://github.com/sdetweil/MagicMirror_scripts
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
        Also updated npm to latest version
          sdetweil @BD0G
          @BD0G can u show me the MagicMirror/installers/upgrade.log
          you installed npm?
          the script would have upgraded npm if needed
          is this a pi 0w? (as it is usuing run-start)
            BD0G @sdetweil
            @sdetweil Thank you Very Much for the reply.
            You have always been helpful with issues!
            I ended up running git pull && npm install --only=prod --omit=dev
            From https://docs.magicmirror.builders/getting-started/upgrade-guide.html
            It allows MM to launch. Appears to be reloading / relaunching periodically though.
              sdetweil @BD0G
              @BD0G
              I would still like to see the upgrade.log to fix the problem
              send it to my email, same userid as here, at gmail.com
              restarting
              need to see the output of
              pm2 logs --lines=100
                BD0G @sdetweil
                @sdetweil Thanks I’ll get right on it!
                Sent …
