    Should I update?
    16 Posts 3 Posters 4.9k Views 4 Watching
    • P Offline
      Peter
      Hi MM builders.
      A long time ago (december 2017) I built my MM and it had been running without major issues since.
      It must be far behind with updates (master branch and modules).
      Should I update (and if so, how?)
      Of just leave it running as it does now?
      Greetings,
      Peter
        sdetweil @Peter
        @peter lots of changes since then
        I would use my upgrade script
        see
        two pass
        1st time is test and tell you about any potential issues i u need to fix (fix and run again til u are comfortable)
        then u can do with apply to actually upgrade?
        u can also do my backup script
        see https://github.com/sdetweil/MagicMirror-backup-restore
        (have to clone this one)
        saves config.js and github links to all the installed modules…
        • P Offline
          Peter @sdetweil
          @sdetweil thanks!
          I noticed your script, but was wondering if it would work because I am so much behind.
          I think I still run MM 1.x
          And I love my MM.
          Peter
            sdetweil @Peter
            @peter make a backup of the MM folder before starting
            the script will work, or I will fix it…
            P 2 Replies Last reply Reply Quote 0
            • P Offline
              Peter @sdetweil
              @sdetweil great!
              Peter
                MyMirror
                Hi Sam,
                I have a similar problem.
                My memory card is defective and I had to revert to an older backup.
                Unfortunately, I have been a little lax with the backup, as I always have to get the mirror off the wall a bit awkwardly to back up the SD card.
                I am with the mirror still on Jessie.
                When I stop the MagicMirror with “pm2 stop mm” and also stop node with killall node, I get a message from your scipt (test mode) that node and npm need to be updated.
                How do I get them to the latest version?
                I am rather beginner in Linux - so have understanding for simple queries.
                Can you help me?
                BR
                Jens
                  sdetweil @MyMirror
                  @mymirror jessie is very old
                  4 releases back now. almost nothing will support running there now
                  I would also suggest some of the mechanisms to backup over the local network
                  https://raspberrypi.stackexchange.com/questions/125137/how-to-backup-entire-raspberry-pi-sd-card-over-network
                    MyMirror
                    Hi Sam,
                    yes i know :-( … very old.
                    in the meantime I got the system on “Stretch” and wanted to take the next step to “Buster”.
                    But I get the following error (on german):
                    PGP error: http://ftp.de.debian.org/debian buster InRelease: The following signatures could not be verified because their public key is not available …
                    How can I adjust/correct this?
                    Thanks a lot
                      sdetweil @MyMirror
                      @mymirror i do not know… buster is also not current
                      • P Offline
                        Peter @sdetweil
                        @sdetweil finally I tried the update: MM will not start anymore.
                        I am on stretch by the way.
                        Peter
                          sdetweil @Peter
                          @peter show me the messages… fromn npm start
                          stretch is WAY downlevel…
                          need to get to buster(legacy) or bullseye…
                          the internet keeps changing things every week… stetch is 4 years old now
                          • P Offline
                            Peter
                            Is it possible to update without having to start all over?
                            Peter
                              sdetweil @Peter
                              @peter maybe… as i said, stretch is really old…
                              I do not know if you can upgrade OS in place from stretch
                              pretty sure u need to upgrade node and npm too
                              node -v
                              npm -v
                              what pi is this ?
                              uname -a
                              • P Offline
                                Peter @sdetweil
                                @sdetweil I think it is a Pi2b.
                                In 2017 I built this MM and it has been running well since.
                                So, that is my question: update of not.
                                It took me very long to build, and I do not want to start all over again.
                                Peter
                                  sdetweil @Peter
                                  @peter do not update
                                  • P Offline
                                    Peter @sdetweil
                                    @sdetweil 😁
                                    Saves a lot of work!
                                    Maybe I start a fresh install some day.
                                    Thanks for your help.
                                    Peter
