    MM will not start
    32 Posts 3 Posters 7.4k Views 3 Watching
      sdetweil @bworch
      @bworch when? whouldn’t go black
      i use SSH never VNC…
        bworch @sdetweil
        @sdetweil that command you gave me did a lot of stuff then went black, should I force a restart on the pi.
          sdetweil @bworch
          @bworch it just ends and says upgrade completed
          I ‘guess’
          B 2 Replies Last reply Reply Quote 0
            bworch @sdetweil
            @sdetweil I did a force restart on the pi, and it is working on the screen, but VNC terminal isn’t picking it up, it just shows the pi splash screen. at least the display is working. Not sure why it isn’t showing on the VNC terminal.
              bworch @sdetweil
              @sdetweil I guess it isn’t working I am getting a bunch of lines like this
              If you have any other ideas, let me know. I need to stop now. thanks very much.
              S B 2 Replies Last reply Reply Quote 0
                sdetweil @bworch
                @bworch that is a pm2 error, needs to me updated
                see pm2 --help
                for update
                  bworch @bworch
                  @bworch so I go another sm card build it again. I copied my config, modules, and CSS files over, and when I run an npm start MagicMorror I get the following. I guess we don’t use pm2 anymore. I get a black screen if it starts. I am also getting a commit or stash again. How do I commit or stash.
                  magicmirror@2.21.0 start
                  DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                  [15.10.2022 15:26.51.630] [LOG] Starting MagicMirror: v2.21.0
                  [15.10.2022 15:26.51.646] [LOG] Loading config …
                  [15.10.2022 15:26.51.664] [LOG] Loading module helpers …
                  [15.10.2022 15:26.51.671] [LOG] No helper found for module: alert.
                  [15.10.2022 15:26.51.730] [LOG] Initializing new module helper …
                  [15.10.2022 15:26.51.734] [LOG] Module helper loaded: updatenotification
                  [15.10.2022 15:26.51.739] [LOG] No helper found for module: clock.
                  [15.10.2022 15:26.51.743] [LOG] No helper found for module: currentweather.
                  [15.10.2022 15:26.51.749] [LOG] No helper found for module: weatherforecast.
                  [15.10.2022 15:26.52.581] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘async’
                  Require stack:
                  • /home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js
                  • /home/bworch/MagicMirror/js/app.js
                  • /home/bworch/MagicMirror/js/electron.js
                  • /home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                  [15.10.2022 15:26.52.605] [LOG] Loading module helpers …
                  [15.10.2022 15:26.52.609] [LOG] No helper found for module: alert.
                  [15.10.2022 15:26.52.612] [LOG] Initializing new module helper …
                  [15.10.2022 15:26.52.616] [LOG] Module helper loaded: updatenotification
                  [15.10.2022 15:26.52.619] [LOG] No helper found for module: clock.
                  [15.10.2022 15:26.52.621] [LOG] No helper found for module: currentweather.
                  [15.10.2022 15:26.52.624] [LOG] No helper found for module: weatherforecast.
                  [15.10.2022 15:26.52.629] [ERROR] App threw an error during load
                  [15.10.2022 15:26.52.634] [ERROR] Error: Cannot find module ‘async’
                  Require stack:
                  • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                    at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
                    at Module._resolveFilename (/home/bworch/MagicMirror/node_modules/module-alias/index.js:49:29)
                    at Module._load (node:internal/modules/cjs/loader:785:27)
                    at c._load (node:electron/js2c/asar_bundle:5:13343)
                    at Module.require (node:internal/modules/cjs/loader:1012:19)
                    at require (node:internal/modules/cjs/helpers:102:18)
                    at Object. (/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js:3:13)
                    at Module._compile (node:internal/modules/cjs/loader:1118:14)
                    at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
                    [15.10.2022 15:26.52.639] [ERROR] Whoops! There was an uncaught exception…
                    [15.10.2022 15:26.52.663] [ERROR] Error: Cannot find module ‘async’
                    Require stack:
                    at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {
                    code: ‘MODULE_NOT_FOUND’,
                    requireStack: [
                    ‘/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js’,
                    ‘/home/bworch/MagicMirror/js/app.js’,
                    ‘/home/bworch/MagicMirror/js/electron.js’,
                    ‘/home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                    undefined
                    [15.10.2022 15:26.52.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [15.10.2022 15:26.52.674] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [15.10.2022 15:26.53.407] [LOG] Launching application.
                    [2177:1015/152654.435494:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                    [2204:1015/152654.735310:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                    [15.10.2022 15:27.30.480] [LOG] Shutting down server…
                    [15.10.2022 15:27.30.487] [LOG] Stopping module helper: updatenotification
                    [15.10.2022 15:27.30.490] [LOG] Stopping module helper: updatenotification
                    [15.10.2022 15:27.30.492] [ERROR] Whoops! There was an uncaught exception…
                    [15.10.2022 15:27.30.496] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
                    at App.stop (/home/bworch/MagicMirror/js/app.js:257:14)
                    at App. (/home/bworch/MagicMirror/js/electron.js:145:7)
                    at App.emit (node:events:526:28)
                    at appMethod (node:electron/js2c/browser_init:69:1830)
                    at Object.execute (node:electron/js2c/browser_init:69:5966)
                    at MenuItem.click (node:electron/js2c/browser_init:73:1862)
                    at a._executeCommand (node:electron/js2c/browser_init:81:2453)
                    [15.10.2022 15:27.30.499] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [15.10.2022 15:27.30.501] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    bworch@raspberrypi:~/MagicMirror $
                  not sure what to do. may have a bad config file. thanks
                    bworch @sdetweil
                    @sdetweil @bworch said in MM will not start:
                    Require stack:
                    Require stack:
                    Require stack:
                    requireStack: [
                    undefined
                    How do I do a commit or stash. not sure what to do. may have a bad config file. thanks
                      bworch @sdetweil
                      @sdetweil here is my config file.
                      /* Magic Mirror Config Sample
                      • By Michael Teeuw http://michaelteeuw.nl
                      • MIT Licensed.
                      • For more information how you can configurate this file
                      • See https://github.com/MichMich/MagicMirror#configuration
                      var config = {
                      address: “localhost”, // Address to listen on, can be:
                      // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
                      // - “”, “0.0.0.0”, “::” to listen on any interface
                      // Default, when address config is left out, is “localhost”
                      port: 8080,
                      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                      language: "en",
                      timeFormat: 12,
                      units: "Imperial",
                      	module: "alert",
                      		module: "updatenotification",
                      		position: "top_bar"
                      		module: "clock",
                      		position: "top_left"
                      		module: "currentweather",
                      			units: 'imperial',
                      			degreeLabel: 'true',
                      			roundtemp: 'true',
                      			showHumidity: 'true',
                      			locationID: "5545710",  //ID from http://www.openweathermap.org/help/city_list.txt
                      			appid: "8d5a2ba9f97fc5d"
                      		module: "weatherforecast",
                      		header: "Weather Forecast",
                      			showRainAmount: 'true',
                      			units: 'imperial',
                      			roundtemp: 'true',
                      			Fade: 'false',
                      			maxNumberOfDays: '7',
                      			colored: 'true',
                      			appid:"95a2ba9f97fc5d"
                      		module: "MMM-Stock",
                      		companies: ["CRON", "ACB", "NXTD", "UBER"]
                      	disabled: false,
                      	module: "MMM-SunRiseSet",
                      	lat: "38.772467",      // Your latitude (for the data)
                      	lng: "-112.084094",     // Your longitude (for the data)
                      	image: "world",          // "world" (animation), "map" (animation), "static" (graph)
                      	imageOnly: "no",       // no = all data, yes = only animated world or map
                      	dayOrNight: "night",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
                      	useHeader: true,      // true if you want a header
                      	header: "Sun Rise and sun set",      // useHeader must be true
                      	maxWidth: "515px"
                      	module: 'MMM-ImageSlideshow',
                      	position: 'bottom_right',
                      		imagePaths: ['/modules/MMM-ImageSlideShow/Pictures']
                              	module: 'MMM-Carousel',
                                  transitionInterval: 10000,
                                  ignoreModules: ['clock','MMM-Fortnite','MMM-SunRiseSet','MMM-Stock','MMM-Coinbase','MMM-WeeklySchedule','updatenotification','currentweather','calendar','MMM-DailyBibleVerse'],
                                  mode: 'global'
                              		module: 'MMM-CoinMarketCap',
                              		header: "Cryptocurrencies",
                      			apikey: 'd-846f-7848e2b4b6d3',
                      			Currencies: ['bitcoin', 'ethereum','ethereum classic','litecoin','ZRX','bitcoin cash'],
                                  		percentChangeColored: true,
                      			view: 'GraphWithChanges',
                      			Showlongnames: 'true',
                      			headers: ['change24hr', 'Change7d'],
                      			graphsize: 'medium',
                                 			conversion: 'USD',
                      		header: "My Calendar",
                      			maximumNumberofDays: '3',
                      					symbol: "calendar-check-o ",
                      					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                      					url: "https://calendar.google.com/calendmail.com/public/basic.ics"
                      		module: 'MMM-Fortnite',
                      		header: 'Fortnite',
                      		position: 'top_left',
                      			showScore: false,
                      			sortBy: 'kills',
                      			userIDs: [ '4735ce9b40f79c', '3900c5958e4b86e03f8' ]
                          module: 'internet-monitor',
                              header: 'Internet Monitor',
                              config:{
                                  type: '',
                                  maxTime: 20000,
                                  updateInterval: 0,
                                  verbose: false,
                                  displayStrength: true,
                                  displaySpeed: true,
                                  strengthIconSize: 80,
                                  maxGaugeScale: 25,
                      	wifiSymbol:{
                                      fullColor: '#3afc25'
                       module: 'MMM-Remote-Control',
                       // uncomment the following line to show the URL of the remote control on the mirror
                       position: 'bottom_left',
                       // you can hide this module afterwards from the remote control itself
                          customCommand: {},  // Optional, See "Using Custom Commands" below
                          customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                          showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                          apiKey: ""         // Optional, See API/README.md for details
                      module: "MMM-WeeklySchedule",
                      header: "Jamie's Household Chores",
                      showWeeklyinHeader: "true",
                          schedule: {
                              timeslots: [ "1", "2", "3", "4", "5", "6", "7" ],
                              lessons: {
                                  mon: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                  tue: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                  wed: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load Dishwasher as required"],
                                  thu: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                  fri: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                  // no entries for saturday
                                  sun: [ "", "Quidditch Match", "Sunday Lunch" ]   // short day on sundays
                          updateInterval: 1 * 60 * 60 * 1000, // every hour
                          showNextDayAfter: "14:00"
                      module: “MMM-WeeklySchedule”,
                      position: “top_right”,
                      header: “Joseph’s Household Chores”,
                      showWeeklyinHeader: “true”,
                      schedule: {
                      timeslots: [ “1”, “2”, “3”, “4”, “5”, “6”, “7” ],
                      lessons: {
                      mon: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                      tue: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                      wed: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required”],
                      thu: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                      fri: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                      sun: [ “”, “Quidditch Match”, “Sunday Lunch” ] // short day on sundays
                      showNextDayAfter: “14:00”
                      module: “MMM-Coinbase”,
                      header: “Coinbase”,
                      apiKey: “ZJx”,
                      apiSecret: “Yshfe5VDCS5J”
                      module: ‘MMM-DailyBibleVerse’,
                      position: ‘bottom_bar’, // This can be any of the regions. Best result is in the bottom_bar as verses can take multiple lines in a day.
                      version: ‘KJV’, // This can be changed to any version you want that is offered by Bible Gateway. For a list, go here: https://www.biblegateway.com/versions/,
                      size: ‘Medium’ // default value is medium, but can be changed.
                      if (typeof module !== “undefined”) {module.exports = config;}
                      bugsounetB 1 Reply Last reply Reply Quote 0
                        sdetweil @bworch
                        I the MMM-Stock folder do
                        npm install async
                        • 3 / 4
