    MM will not start
    32 Posts 3 Posters 8.8k Views 3 Watching
      bworch @sdetweil
      I thank you for sticking with me.
        sdetweil @bworch
        @bworch ok, I suggest you run my upgrade script
        see https://github.com/sdetweil/MagicMirror_scripts
        the upgrade script second pass with
        force
        instead of apply
          bworch @sdetweil
          @sdetweil which line
            bworch @sdetweil
            @sdetweil I accidently ran it as is, I then couldn’t find where to make the change. Sorry
              sdetweil @bworch
              @bworch
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                bworch @sdetweil
                @sdetweil My VNC terminal when Black, is that normal.
                  sdetweil @bworch
                  @bworch when? whouldn’t go black
                  i use SSH never VNC…
                    bworch @sdetweil
                    @sdetweil that command you gave me did a lot of stuff then went black, should I force a restart on the pi.
                      sdetweil @bworch
                      @bworch it just ends and says upgrade completed
                      I ‘guess’
                        bworch @sdetweil
                        @sdetweil I did a force restart on the pi, and it is working on the screen, but VNC terminal isn’t picking it up, it just shows the pi splash screen. at least the display is working. Not sure why it isn’t showing on the VNC terminal.
                          bworch @sdetweil
                          @sdetweil I guess it isn’t working I am getting a bunch of lines like this
                          If you have any other ideas, let me know. I need to stop now. thanks very much.
                          S B 2 Replies Last reply Reply Quote 0
                            sdetweil @bworch
                            @bworch that is a pm2 error, needs to me updated
                            see pm2 --help
                            for update
                              bworch @bworch
                              @bworch so I go another sm card build it again. I copied my config, modules, and CSS files over, and when I run an npm start MagicMorror I get the following. I guess we don’t use pm2 anymore. I get a black screen if it starts. I am also getting a commit or stash again. How do I commit or stash.
                              magicmirror@2.21.0 start
                              [15.10.2022 15:26.51.630] [LOG] Starting MagicMirror: v2.21.0
                              [15.10.2022 15:26.51.646] [LOG] Loading config …
                              [15.10.2022 15:26.51.664] [LOG] Loading module helpers …
                              [15.10.2022 15:26.51.671] [LOG] No helper found for module: alert.
                              [15.10.2022 15:26.51.730] [LOG] Initializing new module helper …
                              [15.10.2022 15:26.51.734] [LOG] Module helper loaded: updatenotification
                              [15.10.2022 15:26.51.739] [LOG] No helper found for module: clock.
                              [15.10.2022 15:26.51.743] [LOG] No helper found for module: currentweather.
                              [15.10.2022 15:26.51.749] [LOG] No helper found for module: weatherforecast.
                              [15.10.2022 15:26.52.581] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘async’
                              Require stack:
                              • /home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js
                              • /home/bworch/MagicMirror/js/app.js
                              • /home/bworch/MagicMirror/js/electron.js
                              • /home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                              [15.10.2022 15:26.52.605] [LOG] Loading module helpers …
                              [15.10.2022 15:26.52.609] [LOG] No helper found for module: alert.
                              [15.10.2022 15:26.52.612] [LOG] Initializing new module helper …
                              [15.10.2022 15:26.52.616] [LOG] Module helper loaded: updatenotification
                              [15.10.2022 15:26.52.619] [LOG] No helper found for module: clock.
                              [15.10.2022 15:26.52.621] [LOG] No helper found for module: currentweather.
                              [15.10.2022 15:26.52.624] [LOG] No helper found for module: weatherforecast.
                              [15.10.2022 15:26.52.629] [ERROR] App threw an error during load
                              [15.10.2022 15:26.52.634] [ERROR] Error: Cannot find module ‘async’
                              Require stack:
                              • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                                at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
                                at Module._resolveFilename (/home/bworch/MagicMirror/node_modules/module-alias/index.js:49:29)
                                at Module._load (node:internal/modules/cjs/loader:785:27)
                                at c._load (node:electron/js2c/asar_bundle:5:13343)
                                at Module.require (node:internal/modules/cjs/loader:1012:19)
                                at require (node:internal/modules/cjs/helpers:102:18)
                                at Object. (/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js:3:13)
                                at Module._compile (node:internal/modules/cjs/loader:1118:14)
                                at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
                                [15.10.2022 15:26.52.639] [ERROR] Whoops! There was an uncaught exception…
                                [15.10.2022 15:26.52.663] [ERROR] Error: Cannot find module ‘async’
                                Require stack:
                                at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {
                                code: ‘MODULE_NOT_FOUND’,
                                requireStack: [
                                ‘/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js’,
                                ‘/home/bworch/MagicMirror/js/app.js’,
                                ‘/home/bworch/MagicMirror/js/electron.js’,
                                ‘/home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                                undefined
                                [15.10.2022 15:26.52.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [15.10.2022 15:26.52.674] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                [15.10.2022 15:26.53.407] [LOG] Launching application.
                                [2177:1015/152654.435494:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                [2204:1015/152654.735310:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                [15.10.2022 15:27.30.480] [LOG] Shutting down server…
                                [15.10.2022 15:27.30.487] [LOG] Stopping module helper: updatenotification
                                [15.10.2022 15:27.30.490] [LOG] Stopping module helper: updatenotification
                                [15.10.2022 15:27.30.492] [ERROR] Whoops! There was an uncaught exception…
                                [15.10.2022 15:27.30.496] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
                                at App.stop (/home/bworch/MagicMirror/js/app.js:257:14)
                                at App. (/home/bworch/MagicMirror/js/electron.js:145:7)
                                at App.emit (node:events:526:28)
                                at appMethod (node:electron/js2c/browser_init:69:1830)
                                at Object.execute (node:electron/js2c/browser_init:69:5966)
                                at MenuItem.click (node:electron/js2c/browser_init:73:1862)
                                at a._executeCommand (node:electron/js2c/browser_init:81:2453)
                                [15.10.2022 15:27.30.499] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [15.10.2022 15:27.30.501] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                bworch@raspberrypi:~/MagicMirror $
                              not sure what to do. may have a bad config file. thanks
                                bworch @sdetweil
                                @sdetweil @bworch said in MM will not start:
                                Require stack:
                                Require stack:
                                Require stack:
                                requireStack: [
                                undefined
                                How do I do a commit or stash. not sure what to do. may have a bad config file. thanks
                                  bworch @sdetweil
                                  @sdetweil here is my config file.
                                  /* Magic Mirror Config Sample
                                  • MIT Licensed.
                                  • For more information how you can configurate this file
                                  • See https://github.com/MichMich/MagicMirror#configuration
                                  var config = {
                                  // - “”, “0.0.0.0”, “::” to listen on any interface
                                  // Default, when address config is left out, is “localhost”
                                  port: 8080,
                                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                                  language: "en",
                                  timeFormat: 12,
                                  units: "Imperial",
                                  	module: "alert",
                                  		module: "updatenotification",
                                  		position: "top_bar"
                                  		module: "clock",
                                  		position: "top_left"
                                  		module: "currentweather",
                                  			units: 'imperial',
                                  			degreeLabel: 'true',
                                  			roundtemp: 'true',
                                  			showHumidity: 'true',
                                  			locationID: "5545710",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  			appid: "8d5a2ba9f97fc5d"
                                  		module: "weatherforecast",
                                  		header: "Weather Forecast",
                                  			showRainAmount: 'true',
                                  			units: 'imperial',
                                  			roundtemp: 'true',
                                  			Fade: 'false',
                                  			maxNumberOfDays: '7',
                                  			colored: 'true',
                                  			appid:"95a2ba9f97fc5d"
                                  		module: "MMM-Stock",
                                  		companies: ["CRON", "ACB", "NXTD", "UBER"]
                                  	disabled: false,
                                  	module: "MMM-SunRiseSet",
                                  	lat: "38.772467",      // Your latitude (for the data)
                                  	lng: "-112.084094",     // Your longitude (for the data)
                                  	image: "world",          // "world" (animation), "map" (animation), "static" (graph)
                                  	imageOnly: "no",       // no = all data, yes = only animated world or map
                                  	dayOrNight: "night",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
                                  	useHeader: true,      // true if you want a header
                                  	header: "Sun Rise and sun set",      // useHeader must be true
                                  	maxWidth: "515px"
                                  	module: 'MMM-ImageSlideshow',
                                  	position: 'bottom_right',
                                  		imagePaths: ['/modules/MMM-ImageSlideShow/Pictures']
                                          	module: 'MMM-Carousel',
                                              transitionInterval: 10000,
                                              ignoreModules: ['clock','MMM-Fortnite','MMM-SunRiseSet','MMM-Stock','MMM-Coinbase','MMM-WeeklySchedule','updatenotification','currentweather','calendar','MMM-DailyBibleVerse'],
                                              mode: 'global'
                                          		module: 'MMM-CoinMarketCap',
                                          		header: "Cryptocurrencies",
                                  			apikey: 'd-846f-7848e2b4b6d3',
                                  			Currencies: ['bitcoin', 'ethereum','ethereum classic','litecoin','ZRX','bitcoin cash'],
                                              		percentChangeColored: true,
                                  			view: 'GraphWithChanges',
                                  			Showlongnames: 'true',
                                  			headers: ['change24hr', 'Change7d'],
                                  			graphsize: 'medium',
                                             			conversion: 'USD',
                                  		header: "My Calendar",
                                  			maximumNumberofDays: '3',
                                  					symbol: "calendar-check-o ",
                                  					url: "https://calendar.google.com/calendmail.com/public/basic.ics"
                                  		module: 'MMM-Fortnite',
                                  		header: 'Fortnite',
                                  		position: 'top_left',
                                  			showScore: false,
                                  			sortBy: 'kills',
                                  			userIDs: [ '4735ce9b40f79c', '3900c5958e4b86e03f8' ]
                                      module: 'internet-monitor',
                                          header: 'Internet Monitor',
                                          config:{
                                              type: '',
                                              maxTime: 20000,
                                              updateInterval: 0,
                                              verbose: false,
                                              displayStrength: true,
                                              displaySpeed: true,
                                              strengthIconSize: 80,
                                              maxGaugeScale: 25,
                                  	wifiSymbol:{
                                                  fullColor: '#3afc25'
                                   module: 'MMM-Remote-Control',
                                   position: 'bottom_left',
                                      customCommand: {},  // Optional, See "Using Custom Commands" below
                                      customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                      showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                      apiKey: ""         // Optional, See API/README.md for details
                                  module: "MMM-WeeklySchedule",
                                  header: "Jamie's Household Chores",
                                  showWeeklyinHeader: "true",
                                      schedule: {
                                          timeslots: [ "1", "2", "3", "4", "5", "6", "7" ],
                                          lessons: {
                                              mon: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                              tue: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                              wed: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load Dishwasher as required"],
                                              thu: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                              fri: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                              // no entries for saturday
                                              sun: [ "", "Quidditch Match", "Sunday Lunch" ]   // short day on sundays
                                      updateInterval: 1 * 60 * 60 * 1000, // every hour
                                      showNextDayAfter: "14:00"
                                  module: “MMM-WeeklySchedule”,
                                  position: “top_right”,
                                  header: “Joseph’s Household Chores”,
                                  showWeeklyinHeader: “true”,
                                  schedule: {
                                  timeslots: [ “1”, “2”, “3”, “4”, “5”, “6”, “7” ],
                                  lessons: {
                                  mon: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                                  tue: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                                  wed: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required”],
                                  thu: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                                  fri: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                                  sun: [ “”, “Quidditch Match”, “Sunday Lunch” ] // short day on sundays
                                  showNextDayAfter: “14:00”
                                  module: “MMM-Coinbase”,
                                  header: “Coinbase”,
                                  apiKey: “ZJx”,
                                  apiSecret: “Yshfe5VDCS5J”
                                  module: ‘MMM-DailyBibleVerse’,
                                  position: ‘bottom_bar’, // This can be any of the regions. Best result is in the bottom_bar as verses can take multiple lines in a day.
                                  version: ‘KJV’, // This can be changed to any version you want that is offered by Bible Gateway. For a list, go here: https://www.biblegateway.com/versions/,
                                  size: ‘Medium’ // default value is medium, but can be changed.
                                  if (typeof module !== “undefined”) {module.exports = config;}
                                  bugsounetB 1 Reply Last reply Reply Quote 0
                                    sdetweil @bworch
                                    I the MMM-Stock folder do
                                    npm install async
                                    • bugsounetB Offline
                                      bugsounet Banned @bworch
                                      @bworch Thanks for sharing your own personal API keys to ALL MagicMirror users !
                                      Happy use ;)
                                        sdetweil @bugsounet
                                        @bugsounet you could have sent him a private message
                                        I have edited them
