    MM will not start
    32 Posts 3 Posters 8.3k Views 3 Watching
      bworch @sdetweil
      @sdetweil which line
        bworch @sdetweil
        @sdetweil I accidently ran it as is, I then couldn’t find where to make the change. Sorry
          sdetweil @bworch
          @bworch
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            bworch @sdetweil
            @sdetweil My VNC terminal when Black, is that normal.
              sdetweil @bworch
              @bworch when? whouldn’t go black
              i use SSH never VNC…
                bworch @sdetweil
                @sdetweil that command you gave me did a lot of stuff then went black, should I force a restart on the pi.
                  sdetweil @bworch
                  @bworch it just ends and says upgrade completed
                  I ‘guess’
                    bworch @sdetweil
                    @sdetweil I did a force restart on the pi, and it is working on the screen, but VNC terminal isn’t picking it up, it just shows the pi splash screen. at least the display is working. Not sure why it isn’t showing on the VNC terminal.
                      bworch @sdetweil
                      @sdetweil I guess it isn’t working I am getting a bunch of lines like this
                      If you have any other ideas, let me know. I need to stop now. thanks very much.
                      S B 2 Replies Last reply Reply Quote 0
                        sdetweil @bworch
                        @bworch that is a pm2 error, needs to me updated
                        see pm2 --help
                        for update
                          bworch @bworch
                          @bworch so I go another sm card build it again. I copied my config, modules, and CSS files over, and when I run an npm start MagicMorror I get the following. I guess we don’t use pm2 anymore. I get a black screen if it starts. I am also getting a commit or stash again. How do I commit or stash.
                          magicmirror@2.21.0 start
                          [15.10.2022 15:26.51.630] [LOG] Starting MagicMirror: v2.21.0
                          [15.10.2022 15:26.51.646] [LOG] Loading config …
                          [15.10.2022 15:26.51.664] [LOG] Loading module helpers …
                          [15.10.2022 15:26.51.671] [LOG] No helper found for module: alert.
                          [15.10.2022 15:26.51.730] [LOG] Initializing new module helper …
                          [15.10.2022 15:26.51.734] [LOG] Module helper loaded: updatenotification
                          [15.10.2022 15:26.51.739] [LOG] No helper found for module: clock.
                          [15.10.2022 15:26.51.743] [LOG] No helper found for module: currentweather.
                          [15.10.2022 15:26.51.749] [LOG] No helper found for module: weatherforecast.
                          [15.10.2022 15:26.52.581] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘async’
                          Require stack:
                          • /home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js
                          • /home/bworch/MagicMirror/js/app.js
                          • /home/bworch/MagicMirror/js/electron.js
                          • /home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                          [15.10.2022 15:26.52.605] [LOG] Loading module helpers …
                          [15.10.2022 15:26.52.609] [LOG] No helper found for module: alert.
                          [15.10.2022 15:26.52.612] [LOG] Initializing new module helper …
                          [15.10.2022 15:26.52.616] [LOG] Module helper loaded: updatenotification
                          [15.10.2022 15:26.52.619] [LOG] No helper found for module: clock.
                          [15.10.2022 15:26.52.621] [LOG] No helper found for module: currentweather.
                          [15.10.2022 15:26.52.624] [LOG] No helper found for module: weatherforecast.
                          [15.10.2022 15:26.52.629] [ERROR] App threw an error during load
                          [15.10.2022 15:26.52.634] [ERROR] Error: Cannot find module ‘async’
                          Require stack:
                          • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                            at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
                            at Module._resolveFilename (/home/bworch/MagicMirror/node_modules/module-alias/index.js:49:29)
                            at Module._load (node:internal/modules/cjs/loader:785:27)
                            at c._load (node:electron/js2c/asar_bundle:5:13343)
                            at Module.require (node:internal/modules/cjs/loader:1012:19)
                            at require (node:internal/modules/cjs/helpers:102:18)
                            at Object. (/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js:3:13)
                            at Module._compile (node:internal/modules/cjs/loader:1118:14)
                            at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
                            [15.10.2022 15:26.52.639] [ERROR] Whoops! There was an uncaught exception…
                            [15.10.2022 15:26.52.663] [ERROR] Error: Cannot find module ‘async’
                            Require stack:
                            at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {
                            code: ‘MODULE_NOT_FOUND’,
                            requireStack: [
                            ‘/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js’,
                            ‘/home/bworch/MagicMirror/js/app.js’,
                            ‘/home/bworch/MagicMirror/js/electron.js’,
                            ‘/home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                            undefined
                            [15.10.2022 15:26.52.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            [15.10.2022 15:26.52.674] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            [15.10.2022 15:26.53.407] [LOG] Launching application.
                            [2177:1015/152654.435494:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                            [2204:1015/152654.735310:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                            [15.10.2022 15:27.30.480] [LOG] Shutting down server…
                            [15.10.2022 15:27.30.487] [LOG] Stopping module helper: updatenotification
                            [15.10.2022 15:27.30.490] [LOG] Stopping module helper: updatenotification
                            [15.10.2022 15:27.30.492] [ERROR] Whoops! There was an uncaught exception…
                            [15.10.2022 15:27.30.496] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
                            at App.stop (/home/bworch/MagicMirror/js/app.js:257:14)
                            at App. (/home/bworch/MagicMirror/js/electron.js:145:7)
                            at App.emit (node:events:526:28)
                            at appMethod (node:electron/js2c/browser_init:69:1830)
                            at Object.execute (node:electron/js2c/browser_init:69:5966)
                            at MenuItem.click (node:electron/js2c/browser_init:73:1862)
                            at a._executeCommand (node:electron/js2c/browser_init:81:2453)
                            [15.10.2022 15:27.30.499] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            [15.10.2022 15:27.30.501] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            bworch@raspberrypi:~/MagicMirror $
                          not sure what to do. may have a bad config file. thanks
                            bworch @sdetweil
                            @sdetweil @bworch said in MM will not start:
                            Require stack:
                            Require stack:
                            Require stack:
                            requireStack: [
                            undefined
                            How do I do a commit or stash. not sure what to do. may have a bad config file. thanks
                              bworch @sdetweil
                              @sdetweil here is my config file.
                              /* Magic Mirror Config Sample
                              • MIT Licensed.
                              • For more information how you can configurate this file
                              • See https://github.com/MichMich/MagicMirror#configuration
                              var config = {
                              // - “”, “0.0.0.0”, “::” to listen on any interface
                              // Default, when address config is left out, is “localhost”
                              port: 8080,
                              ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                              language: "en",
                              timeFormat: 12,
                              units: "Imperial",
                              	module: "alert",
                              		module: "updatenotification",
                              		position: "top_bar"
                              		module: "clock",
                              		position: "top_left"
                              		module: "currentweather",
                              			units: 'imperial',
                              			degreeLabel: 'true',
                              			roundtemp: 'true',
                              			showHumidity: 'true',
                              			locationID: "5545710",  //ID from http://www.openweathermap.org/help/city_list.txt
                              			appid: "8d5a2ba9f97fc5d"
                              		module: "weatherforecast",
                              		header: "Weather Forecast",
                              			showRainAmount: 'true',
                              			units: 'imperial',
                              			roundtemp: 'true',
                              			Fade: 'false',
                              			maxNumberOfDays: '7',
                              			colored: 'true',
                              			appid:"95a2ba9f97fc5d"
                              		module: "MMM-Stock",
                              		companies: ["CRON", "ACB", "NXTD", "UBER"]
                              	disabled: false,
                              	module: "MMM-SunRiseSet",
                              	lat: "38.772467",      // Your latitude (for the data)
                              	lng: "-112.084094",     // Your longitude (for the data)
                              	image: "world",          // "world" (animation), "map" (animation), "static" (graph)
                              	imageOnly: "no",       // no = all data, yes = only animated world or map
                              	dayOrNight: "night",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
                              	useHeader: true,      // true if you want a header
                              	header: "Sun Rise and sun set",      // useHeader must be true
                              	maxWidth: "515px"
                              	module: 'MMM-ImageSlideshow',
                              	position: 'bottom_right',
                              		imagePaths: ['/modules/MMM-ImageSlideShow/Pictures']
                                      	module: 'MMM-Carousel',
                                          transitionInterval: 10000,
                                          ignoreModules: ['clock','MMM-Fortnite','MMM-SunRiseSet','MMM-Stock','MMM-Coinbase','MMM-WeeklySchedule','updatenotification','currentweather','calendar','MMM-DailyBibleVerse'],
                                          mode: 'global'
                                      		module: 'MMM-CoinMarketCap',
                                      		header: "Cryptocurrencies",
                              			apikey: 'd-846f-7848e2b4b6d3',
                              			Currencies: ['bitcoin', 'ethereum','ethereum classic','litecoin','ZRX','bitcoin cash'],
                                          		percentChangeColored: true,
                              			view: 'GraphWithChanges',
                              			Showlongnames: 'true',
                              			headers: ['change24hr', 'Change7d'],
                              			graphsize: 'medium',
                                         			conversion: 'USD',
                              		header: "My Calendar",
                              			maximumNumberofDays: '3',
                              					symbol: "calendar-check-o ",
                              					url: "https://calendar.google.com/calendmail.com/public/basic.ics"
                              		module: 'MMM-Fortnite',
                              		header: 'Fortnite',
                              		position: 'top_left',
                              			showScore: false,
                              			sortBy: 'kills',
                              			userIDs: [ '4735ce9b40f79c', '3900c5958e4b86e03f8' ]
                                  module: 'internet-monitor',
                                      header: 'Internet Monitor',
                                      config:{
                                          type: '',
                                          maxTime: 20000,
                                          updateInterval: 0,
                                          verbose: false,
                                          displayStrength: true,
                                          displaySpeed: true,
                                          strengthIconSize: 80,
                                          maxGaugeScale: 25,
                              	wifiSymbol:{
                                              fullColor: '#3afc25'
                               module: 'MMM-Remote-Control',
                               position: 'bottom_left',
                                  customCommand: {},  // Optional, See "Using Custom Commands" below
                                  customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                  showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                  apiKey: ""         // Optional, See API/README.md for details
                              module: "MMM-WeeklySchedule",
                              header: "Jamie's Household Chores",
                              showWeeklyinHeader: "true",
                                  schedule: {
                                      timeslots: [ "1", "2", "3", "4", "5", "6", "7" ],
                                      lessons: {
                                          mon: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                          tue: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                          wed: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load Dishwasher as required"],
                                          thu: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                          fri: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                                          // no entries for saturday
                                          sun: [ "", "Quidditch Match", "Sunday Lunch" ]   // short day on sundays
                                  updateInterval: 1 * 60 * 60 * 1000, // every hour
                                  showNextDayAfter: "14:00"
                              module: “MMM-WeeklySchedule”,
                              position: “top_right”,
                              header: “Joseph’s Household Chores”,
                              showWeeklyinHeader: “true”,
                              schedule: {
                              timeslots: [ “1”, “2”, “3”, “4”, “5”, “6”, “7” ],
                              lessons: {
                              mon: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                              tue: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                              wed: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required”],
                              thu: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                              fri: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
                              sun: [ “”, “Quidditch Match”, “Sunday Lunch” ] // short day on sundays
                              showNextDayAfter: “14:00”
                              module: “MMM-Coinbase”,
                              header: “Coinbase”,
                              apiKey: “ZJx”,
                              apiSecret: “Yshfe5VDCS5J”
                              module: ‘MMM-DailyBibleVerse’,
                              position: ‘bottom_bar’, // This can be any of the regions. Best result is in the bottom_bar as verses can take multiple lines in a day.
                              version: ‘KJV’, // This can be changed to any version you want that is offered by Bible Gateway. For a list, go here: https://www.biblegateway.com/versions/,
                              size: ‘Medium’ // default value is medium, but can be changed.
                              if (typeof module !== “undefined”) {module.exports = config;}
                              bugsounetB 1 Reply Last reply Reply Quote 0
                                sdetweil @bworch
                                I the MMM-Stock folder do
                                npm install async
                                • bugsounetB Offline
                                  bugsounet Banned @bworch
                                  @bworch Thanks for sharing your own personal API keys to ALL MagicMirror users !
                                  Happy use ;)
                                    sdetweil @bugsounet
                                    @bugsounet you could have sent him a private message
                                    I have edited them
