    MM will not start
    32 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @bworch
      @bworch that is a pm2 error, needs to me updated
      see pm2 --help
      for update
        bworch @bworch
        @bworch so I go another sm card build it again. I copied my config, modules, and CSS files over, and when I run an npm start MagicMorror I get the following. I guess we don’t use pm2 anymore. I get a black screen if it starts. I am also getting a commit or stash again. How do I commit or stash.
        magicmirror@2.21.0 start
        [15.10.2022 15:26.51.630] [LOG] Starting MagicMirror: v2.21.0
        [15.10.2022 15:26.51.646] [LOG] Loading config …
        [15.10.2022 15:26.51.664] [LOG] Loading module helpers …
        [15.10.2022 15:26.51.671] [LOG] No helper found for module: alert.
        [15.10.2022 15:26.51.730] [LOG] Initializing new module helper …
        [15.10.2022 15:26.51.734] [LOG] Module helper loaded: updatenotification
        [15.10.2022 15:26.51.739] [LOG] No helper found for module: clock.
        [15.10.2022 15:26.51.743] [LOG] No helper found for module: currentweather.
        [15.10.2022 15:26.51.749] [LOG] No helper found for module: weatherforecast.
        [15.10.2022 15:26.52.581] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘async’
        Require stack:
        • /home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js
        • /home/bworch/MagicMirror/js/app.js
        • /home/bworch/MagicMirror/js/electron.js
        • /home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        [15.10.2022 15:26.52.605] [LOG] Loading module helpers …
        [15.10.2022 15:26.52.609] [LOG] No helper found for module: alert.
        [15.10.2022 15:26.52.612] [LOG] Initializing new module helper …
        [15.10.2022 15:26.52.616] [LOG] Module helper loaded: updatenotification
        [15.10.2022 15:26.52.619] [LOG] No helper found for module: clock.
        [15.10.2022 15:26.52.621] [LOG] No helper found for module: currentweather.
        [15.10.2022 15:26.52.624] [LOG] No helper found for module: weatherforecast.
        [15.10.2022 15:26.52.629] [ERROR] App threw an error during load
        [15.10.2022 15:26.52.634] [ERROR] Error: Cannot find module ‘async’
        Require stack:
        • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
          at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
          at Module._resolveFilename (/home/bworch/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:785:27)
          at c._load (node:electron/js2c/asar_bundle:5:13343)
          at Module.require (node:internal/modules/cjs/loader:1012:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object. (/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js:3:13)
          at Module._compile (node:internal/modules/cjs/loader:1118:14)
          at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
          [15.10.2022 15:26.52.639] [ERROR] Whoops! There was an uncaught exception…
          [15.10.2022 15:26.52.663] [ERROR] Error: Cannot find module ‘async’
          Require stack:
          at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {
          code: ‘MODULE_NOT_FOUND’,
          requireStack: [
          ‘/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js’,
          ‘/home/bworch/MagicMirror/js/app.js’,
          ‘/home/bworch/MagicMirror/js/electron.js’,
          ‘/home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
          undefined
          [15.10.2022 15:26.52.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [15.10.2022 15:26.52.674] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [15.10.2022 15:26.53.407] [LOG] Launching application.
          [2177:1015/152654.435494:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          [2204:1015/152654.735310:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          [15.10.2022 15:27.30.480] [LOG] Shutting down server…
          [15.10.2022 15:27.30.487] [LOG] Stopping module helper: updatenotification
          [15.10.2022 15:27.30.490] [LOG] Stopping module helper: updatenotification
          [15.10.2022 15:27.30.492] [ERROR] Whoops! There was an uncaught exception…
          [15.10.2022 15:27.30.496] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
          at App.stop (/home/bworch/MagicMirror/js/app.js:257:14)
          at App. (/home/bworch/MagicMirror/js/electron.js:145:7)
          at App.emit (node:events:526:28)
          at appMethod (node:electron/js2c/browser_init:69:1830)
          at Object.execute (node:electron/js2c/browser_init:69:5966)
          at MenuItem.click (node:electron/js2c/browser_init:73:1862)
          at a._executeCommand (node:electron/js2c/browser_init:81:2453)
          [15.10.2022 15:27.30.499] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [15.10.2022 15:27.30.501] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          bworch@raspberrypi:~/MagicMirror $
        not sure what to do. may have a bad config file. thanks
          bworch @sdetweil
          @sdetweil @bworch said in MM will not start:
          Require stack:
          Require stack:
          Require stack:
          requireStack: [
          undefined
          How do I do a commit or stash. not sure what to do. may have a bad config file. thanks
            bworch @sdetweil
            @sdetweil here is my config file.
            /* Magic Mirror Config Sample
            • MIT Licensed.
            • For more information how you can configurate this file
            • See https://github.com/MichMich/MagicMirror#configuration
            var config = {
            // - “”, “0.0.0.0”, “::” to listen on any interface
            // Default, when address config is left out, is “localhost”
            port: 8080,
            ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
            language: "en",
            timeFormat: 12,
            units: "Imperial",
            	module: "alert",
            		module: "updatenotification",
            		position: "top_bar"
            		module: "clock",
            		position: "top_left"
            		module: "currentweather",
            			units: 'imperial',
            			degreeLabel: 'true',
            			roundtemp: 'true',
            			showHumidity: 'true',
            			locationID: "5545710",  //ID from http://www.openweathermap.org/help/city_list.txt
            			appid: "8d5a2ba9f97fc5d"
            		module: "weatherforecast",
            		header: "Weather Forecast",
            			showRainAmount: 'true',
            			units: 'imperial',
            			roundtemp: 'true',
            			Fade: 'false',
            			maxNumberOfDays: '7',
            			colored: 'true',
            			appid:"95a2ba9f97fc5d"
            		module: "MMM-Stock",
            		companies: ["CRON", "ACB", "NXTD", "UBER"]
            	disabled: false,
            	module: "MMM-SunRiseSet",
            	lat: "38.772467",      // Your latitude (for the data)
            	lng: "-112.084094",     // Your longitude (for the data)
            	image: "world",          // "world" (animation), "map" (animation), "static" (graph)
            	imageOnly: "no",       // no = all data, yes = only animated world or map
            	dayOrNight: "night",   // "night" approaching, "day" approaching (imageOnly: must be "yes", image: must be "world")
            	useHeader: true,      // true if you want a header
            	header: "Sun Rise and sun set",      // useHeader must be true
            	maxWidth: "515px"
            	module: 'MMM-ImageSlideshow',
            	position: 'bottom_right',
            		imagePaths: ['/modules/MMM-ImageSlideShow/Pictures']
                    	module: 'MMM-Carousel',
                        transitionInterval: 10000,
                        ignoreModules: ['clock','MMM-Fortnite','MMM-SunRiseSet','MMM-Stock','MMM-Coinbase','MMM-WeeklySchedule','updatenotification','currentweather','calendar','MMM-DailyBibleVerse'],
                        mode: 'global'
                    		module: 'MMM-CoinMarketCap',
                    		header: "Cryptocurrencies",
            			apikey: 'd-846f-7848e2b4b6d3',
            			Currencies: ['bitcoin', 'ethereum','ethereum classic','litecoin','ZRX','bitcoin cash'],
                        		percentChangeColored: true,
            			view: 'GraphWithChanges',
            			Showlongnames: 'true',
            			headers: ['change24hr', 'Change7d'],
            			graphsize: 'medium',
                       			conversion: 'USD',
            		header: "My Calendar",
            			maximumNumberofDays: '3',
            					symbol: "calendar-check-o ",
            					url: "https://calendar.google.com/calendmail.com/public/basic.ics"
            		module: 'MMM-Fortnite',
            		header: 'Fortnite',
            		position: 'top_left',
            			showScore: false,
            			sortBy: 'kills',
            			userIDs: [ '4735ce9b40f79c', '3900c5958e4b86e03f8' ]
                module: 'internet-monitor',
                    header: 'Internet Monitor',
                    config:{
                        type: '',
                        maxTime: 20000,
                        updateInterval: 0,
                        verbose: false,
                        displayStrength: true,
                        displaySpeed: true,
                        strengthIconSize: 80,
                        maxGaugeScale: 25,
            	wifiSymbol:{
                            fullColor: '#3afc25'
             module: 'MMM-Remote-Control',
             position: 'bottom_left',
                customCommand: {},  // Optional, See "Using Custom Commands" below
                customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                apiKey: ""         // Optional, See API/README.md for details
            module: "MMM-WeeklySchedule",
            header: "Jamie's Household Chores",
            showWeeklyinHeader: "true",
                schedule: {
                    timeslots: [ "1", "2", "3", "4", "5", "6", "7" ],
                    lessons: {
                        mon: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                        tue: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                        wed: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load Dishwasher as required"],
                        thu: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                        fri: [ "Eat Breakfast", "Brush Teeth", "Get Dressed", "Feed the Cats and Dog", "Do School Work", "Load DishWasher as required" ],
                        // no entries for saturday
                        sun: [ "", "Quidditch Match", "Sunday Lunch" ]   // short day on sundays
                updateInterval: 1 * 60 * 60 * 1000, // every hour
                showNextDayAfter: "14:00"
            module: “MMM-WeeklySchedule”,
            position: “top_right”,
            header: “Joseph’s Household Chores”,
            showWeeklyinHeader: “true”,
            schedule: {
            timeslots: [ “1”, “2”, “3”, “4”, “5”, “6”, “7” ],
            lessons: {
            mon: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
            tue: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
            wed: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required”],
            thu: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
            fri: [ “Eat Breakfast”, “Brush Teeth”, “Get Dressed”, “Feed the horse”, “Do School Work”, “Empty DishWasher as required” ],
            sun: [ “”, “Quidditch Match”, “Sunday Lunch” ] // short day on sundays
            showNextDayAfter: “14:00”
            module: “MMM-Coinbase”,
            header: “Coinbase”,
            apiKey: “ZJx”,
            apiSecret: “Yshfe5VDCS5J”
            module: ‘MMM-DailyBibleVerse’,
            position: ‘bottom_bar’, // This can be any of the regions. Best result is in the bottom_bar as verses can take multiple lines in a day.
            version: ‘KJV’, // This can be changed to any version you want that is offered by Bible Gateway. For a list, go here: https://www.biblegateway.com/versions/,
            size: ‘Medium’ // default value is medium, but can be changed.
            if (typeof module !== “undefined”) {module.exports = config;}
            bugsounetB 1 Reply Last reply Reply Quote 0
              sdetweil @bworch
              I the MMM-Stock folder do
              npm install async
              • bugsounetB Offline
                bugsounet Banned @bworch
                @bworch Thanks for sharing your own personal API keys to ALL MagicMirror users !
                Happy use ;)
                  sdetweil @bugsounet
                  @bugsounet you could have sent him a private message
                  I have edited them
                  • 3 / 4
