    MagicMirror install on proxmox LXC Container?
    37 Posts 3 Posters 10.3k Views 3 Watching
      sdetweil @kusselin
      @kusselin and typically you would setup the container to run MM inside without user intervention… so none of those commands would be needed
      kusselinK 1 Reply Last reply Reply Quote 0
      • kusselinK Offline
        kusselin @wishmaster270
        @wishmaster270 said in MagicMirror install on proxmox LXC Container?:
        npm run server
        have today what changed at the mirror udn had to make reboot… now it no longer works :-(
        After I executed the commands like :
        screen -S MM (MM is the Name)
        then
        npm run server
        and when i close the terminal the MMis stopping:-(
        and the same when i going to cd /MagicMirror
        and then i take this:
        npm run server &
        when i close the terminal MM is stopping…
        what is my problem guys?
        • kusselinK Offline
          kusselin @sdetweil
          @sdetweil said in MagicMirror install on proxmox LXC Container?:
          Hi sam, unfortunately I have not yet understood why the server always stops when closing putty???
          With the command npm run server I start the server… why does the container stop again?
            sdetweil @kusselin
            @kusselin because that is the way it works. when the terminal window closes, any running app also is forced closed. it’s a security thing
            during development I would not close the window. after you are happy, I would make the container auto start mm as part of it’s startup.
            a containers design is to run ONE app.
            I do not know how I do this w lxc containers
            w docker, u add a property to the Dockerfile to tell what app to start
            • kusselinK Offline
              @kusselin
              if your problem is only to keep the command running while/after you disconnected to the container you can use the “screen” command.
              It you should be installed with Ubuntu already. If not you can install it with
              sudo apt update && sudo apt install -y screen
              You then start a new screen with
              screen -S NAME
              while NAME is simply an alias and could be something like “mm”.
              After this you can start the mirror with
              npm run server
              And you can leave the screen with the keyboard combination
              CRTL+ad
              The screen then keeps running. If you want the resume to the screen you can use
              screen -r NAME
              And what about this… yesterday i installed screen and i Type the Commander in putty and the Containers was already online…
              Now, After an reboot Nottingham is Gong :-(
                sdetweil @kusselin
                @kusselin did the IP address change?
                • kusselinK Offline
                  kusselin
                  Hi sam,
                  This was my Solution Now
                  https://forum.iobroker.net/topic/52195/magic-mirror-zusammen-mit-iobroker/173?_=1666207319057
                  Crontab
                  • 4 / 4
