    MagicMirror install on proxmox LXC Container?
    37 Posts 3 Posters 15.5k Views 3 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @kusselin
      @kusselin
      if your problem is only to keep the command running while/after you disconnected to the container you can use the “screen” command.
      It you should be installed with Ubuntu already. If not you can install it with
      sudo apt update && sudo apt install -y screen
      You then start a new screen with
      screen -S NAME
      while NAME is simply an alias and could be something like “mm”.
      After this you can start the mirror with
      npm run server
      And you can leave the screen with the keyboard combination
      CRTL+ad
      The screen then keeps running. If you want the resume to the screen you can use
      screen -r NAME
      kusselinK 3 Replies Last reply Reply Quote 0
        sdetweil @kusselin
        @kusselin when u disconnect a terminal session any app still running is terminated…
        u can spinit off in the background with & at the end of the command
        npm run server &
          wishmaster270 Module Developer @sdetweil
          @sdetweil You are right in running apps with & in the background but if you disconnect the ssh session all background commands will be disconnected as well.
          Either screen or a command like nohup needs to be used to keep the command running.
            sdetweil @wishmaster270
            @wishmaster270 never had one disconnected w &
            • kusselinK Offline
              kusselin @wishmaster270
              @wishmaster270 said in MagicMirror install on proxmox LXC Container?:
              @kusselin
              screen -S NAME
              npm run server
              CRTL+ad
              screen -r NAME
              Thanks, so it is going :-)
                sdetweil @kusselin
                @kusselin and typically you would setup the container to run MM inside without user intervention… so none of those commands would be needed
                kusselinK 1 Reply Last reply Reply Quote 0
                • kusselinK Offline
                  npm run server
                  have today what changed at the mirror udn had to make reboot… now it no longer works :-(
                  After I executed the commands like :
                  screen -S MM (MM is the Name)
                  then
                  npm run server
                  and when i close the terminal the MMis stopping:-(
                  and the same when i going to cd /MagicMirror
                  and then i take this:
                  npm run server &
                  when i close the terminal MM is stopping…
                  what is my problem guys?
                  • kusselinK Offline
                    kusselin @sdetweil
                    @sdetweil said in MagicMirror install on proxmox LXC Container?:
                    Hi sam, unfortunately I have not yet understood why the server always stops when closing putty???
                    With the command npm run server I start the server… why does the container stop again?
                      sdetweil @kusselin
                      @kusselin because that is the way it works. when the terminal window closes, any running app also is forced closed. it’s a security thing
                      during development I would not close the window. after you are happy, I would make the container auto start mm as part of it’s startup.
                      a containers design is to run ONE app.
                      I do not know how I do this w lxc containers
                      w docker, u add a property to the Dockerfile to tell what app to start
                      • kusselinK Offline
                        @kusselin
                        screen -S NAME
                        npm run server
                        CRTL+ad
                        screen -r NAME
                        And what about this… yesterday i installed screen and i Type the Commander in putty and the Containers was already online…
                        Now, After an reboot Nottingham is Gong :-(
                          sdetweil @kusselin
                          @kusselin did the IP address change?
                          • kusselinK Offline
                            kusselin
                            Hi sam,
                            This was my Solution Now
                            https://forum.iobroker.net/topic/52195/magic-mirror-zusammen-mit-iobroker/173?_=1666207319057
                            Crontab
