    MagicMirror install on proxmox LXC Container?
    37 Posts 3 Posters 15.9k Views 3 Watching
      sdetweil @kusselin
      @kusselin said in MagicMirror install on proxmox LXC Container?:
      DISPLAY=:0 npm start
      npm run server
      no
      npm run server
      • kusselinK
        kusselin
        o.k…next try to step and hope i can start the MM
        look…
        pi@MagicMirror-live:~$
        curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
        [sudo] password for pi:
        ## Installing the NodeSource Node.js 18.x repo...
        ## Populating apt-get cache...
        + apt-get update
        Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
        Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
        Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
        Fetched 224 kB in 2s (105 kB/s)
        Reading package lists... Done
        ## Confirming "jammy" is supported...
        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
        ## Adding the NodeSource signing key to your keyring...
        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
        ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
        ## Running `apt-get update` for you...
        + apt-get update
        Get:1 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
        Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [775 B]
        Fetched 5338 B in 2s (2387 B/s)
        ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
        ## You may also need development tools to build native addons:
             sudo apt-get install gcc g++ make
        ## To install the Yarn package manager, run:
             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
             sudo apt-get update && sudo apt-get install yarn
        pi@MagicMirror-live:~$ sudo apt-get update && sudo apt-get install yarn
        Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
        Building dependency tree... Done
        Note, selecting 'cmdtest' instead of 'yarn'
        The following additional packages will be installed:
          python3-cliapp python3-importlib-metadata python3-markdown
          python3-more-itertools python3-pygments python3-ttystatus python3-zipp
        Suggested packages:
          python3-xdg python-markdown-doc python-pygments-doc ttf-bitstream-vera
        The following NEW packages will be installed:
          cmdtest python3-cliapp python3-importlib-metadata python3-markdown
        0 upgraded, 8 newly installed, 0 to remove and 1 not upgraded.
        Need to get 969 kB of archives.
        After this operation, 5201 kB of additional disk space will be used.
        Do you want to continue? [Y/n] Y
        Get:1 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-cliapp all 1.20180812.1-4 [44.5 kB]
        Get:2 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-more-itertools all 8.10.0-2 [47.9 kB]
        Get:3 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-zipp all 1.0.0-3 [5440 B]
        Get:4 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-importlib-metadata all 4.6.4-1 [16.2 kB]
        Get:5 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-markdown all 3.3.6-1 [68.5 kB]
        Get:6 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-ttystatus all 0.38-4 [14.7 kB]
        Get:7 http://archive.ubuntu.com/ubuntu jammy/universe amd64 cmdtest all 0.32.14.gcdfe14e-2 [21.9 kB]
        Get:8 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-pygments all 2.11.2+dfsg-2 [750 kB]
        Fetched 969 kB in 1s (911 kB/s)
        Selecting previously unselected package python3-cliapp.
        (Reading database ... 29455 files and directories currently installed.)
        Preparing to unpack .../0-python3-cliapp_1.20180812.1-4_all.deb ...
        Unpacking python3-cliapp (1.20180812.1-4) ...
        Selecting previously unselected package python3-more-itertools.
        Preparing to unpack .../1-python3-more-itertools_8.10.0-2_all.deb ...
        Unpacking python3-more-itertools (8.10.0-2) ...
        Selecting previously unselected package python3-zipp.
        Preparing to unpack .../2-python3-zipp_1.0.0-3_all.deb ...
        Unpacking python3-zipp (1.0.0-3) ...
        Selecting previously unselected package python3-importlib-metadata.
        Preparing to unpack .../3-python3-importlib-metadata_4.6.4-1_all.deb ...
        Unpacking python3-importlib-metadata (4.6.4-1) ...
        Selecting previously unselected package python3-markdown.
        Preparing to unpack .../4-python3-markdown_3.3.6-1_all.deb ...
        Unpacking python3-markdown (3.3.6-1) ...
        Selecting previously unselected package python3-ttystatus.
        Preparing to unpack .../5-python3-ttystatus_0.38-4_all.deb ...
        Unpacking python3-ttystatus (0.38-4) ...
        Selecting previously unselected package cmdtest.
        Preparing to unpack .../6-cmdtest_0.32.14.gcdfe14e-2_all.deb ...
        Unpacking cmdtest (0.32.14.gcdfe14e-2) ...
        Selecting previously unselected package python3-pygments.
        Preparing to unpack .../7-python3-pygments_2.11.2+dfsg-2_all.deb ...
        Unpacking python3-pygments (2.11.2+dfsg-2) ...
        Setting up python3-ttystatus (0.38-4) ...
        Setting up python3-more-itertools (8.10.0-2) ...
        Setting up python3-zipp (1.0.0-3) ...
        Setting up python3-cliapp (1.20180812.1-4) ...
        Setting up python3-pygments (2.11.2+dfsg-2) ...
        Setting up python3-importlib-metadata (4.6.4-1) ...
        Setting up python3-markdown (3.3.6-1) ...
        Setting up cmdtest (0.32.14.gcdfe14e-2) ...
        Processing triggers for man-db (2.10.2-1) ...
        pi@MagicMirror-live:~$ sudo apt install -y nodejs
        The following packages will be upgraded:
          nodejs
        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 28.5 MB of archives.
        After this operation, 52.4 MB of additional disk space will be used.
        Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.11.0-deb-1nodesource1 [28.5 MB]
        Fetched 28.5 MB in 1s (22.4 MB/s)
        (Reading database ... 29937 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.11.0-deb-1nodesource1_amd64.deb ...
        Unpacking nodejs (18.11.0-deb-1nodesource1) over (16.17.1-deb-1nodesource1) ...
        Setting up nodejs (18.11.0-deb-1nodesource1) ...
        pi@MagicMirror-live:~$ git clone https://github.com/MichMich/MagicMirror
        Cloning into 'MagicMirror'...
        remote: Enumerating objects: 23768, done.
        remote: Counting objects: 100% (1/1), done.
        remote: Total 23768 (delta 0), reused 1 (delta 0), pack-reused 23767
        Receiving objects: 100% (23768/23768), 19.76 MiB | 12.35 MiB/s, done.
        Resolving deltas: 100% (14649/14649), done.
        pi@MagicMirror-live:~$ cd MagicMirror/
        pi@MagicMirror-live:~/MagicMirror$ npm run install-mm
        > magicmirror@2.21.0 install-mm
        > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
        npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
        > magicmirror@2.21.0 postinstall
        > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
        > magicmirror@2.21.0 install-vendor
        > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        added 9 packages in 5s
        > magicmirror@2.21.0 install-fonts
        > echo "Installing fonts ...
        > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
        added 2 packages in 1s
        > magicmirror@2.21.0 prepare
        > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
        no husky installed.
        added 300 packages in 36s
        pi@MagicMirror-live:~/MagicMirror$ cp config/config.js.sample config/config.js
        pi@MagicMirror-live:~/MagicMirror$ npm run server
        > magicmirror@2.21.0 server
        > node ./serveronly
        [16.10.2022 13:16.02.218] [LOG]   Starting MagicMirror: v2.21.0
        [16.10.2022 13:16.02.225] [LOG]   Loading config ...
        [16.10.2022 13:16.02.235] [LOG]   Loading module helpers ...
        [16.10.2022 13:16.02.236] [LOG]   No helper found for module: alert.
        [16.10.2022 13:16.02.252] [LOG]   Initializing new module helper ...
        [16.10.2022 13:16.02.254] [LOG]   Module helper loaded: updatenotification
        [16.10.2022 13:16.02.254] [LOG]   No helper found for module: clock.
        [16.10.2022 13:16.02.513] [LOG]   Initializing new module helper ...
        [16.10.2022 13:16.02.514] [LOG]   Module helper loaded: calendar
        [16.10.2022 13:16.02.515] [LOG]   No helper found for module: compliments.
        [16.10.2022 13:16.02.516] [LOG]   No helper found for module: weather.
        [16.10.2022 13:16.02.536] [LOG]   Initializing new module helper ...
        [16.10.2022 13:16.02.536] [LOG]   Module helper loaded: newsfeed
        [16.10.2022 13:16.02.536] [LOG]   All module helpers loaded.
        [16.10.2022 13:16.02.679] [LOG]   Starting server on port 8080 ...
        [16.10.2022 13:16.02.695] [LOG]   Server started ...
        [16.10.2022 13:16.02.696] [LOG]   Connecting socket for: updatenotification
        [16.10.2022 13:16.02.696] [LOG]   Starting module helper: updatenotification
        [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: calendar
        [16.10.2022 13:16.02.697] [LOG]   Starting node helper for: calendar
        [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: newsfeed
        [16.10.2022 13:16.02.698] [LOG]   Starting node helper for: newsfeed
        [16.10.2022 13:16.02.698] [LOG]   Sockets connected & modules started ...
        Ready to go! Please point your browser to: http://localhost:8080
        is this now right abd is the info “no helper module” O.K.?
        best regards
        P.S. when i put “http://localhost:8080” in the browser linie - it´s not going :-(
          sdetweil @kusselin
          @kusselin remember, a container is a ‘system’
          with its own IP address different than than the container hosting system (typically 172.xx.yy.zz)
          also, localhost means ONLY apps INSIDE this same ‘system’, can access… so that means a browser running IN the container… oops… not possible
          SO, you have to change the MM config.js to allow apps OUTSIDE the container to access the MM app
          and THEN on the container setup , map the container MM port to some host port … (so u can access from another pc, phone, tablet, outside the container hosting system )
          address:“0.0.0.0”.
          ipWhitelist:[],
          you didn’t have to reinstall mm… one install runs three ways
          full (ui on same ‘system’), npm start
          server (ui on some OTHER system (have to change config) npm run server
          client (just the UI part), npm run client
          kusselinK 1 Reply Last reply Reply Quote 0
          • kusselinK
            kusselin @sdetweil
            @sdetweil what a fu…
            now its running!!! Ohman!! yeahhhhhhh :-) thanks a lot…
            o.k. i understand …in an lxc is not same as a pi with raspbia…because lxc is an container and has no graphic giu…then i have to start server (npm start server" right…
            and i mut change the config as this here
            address:“0.0.0.0”.
            ipWhitelist:[],
              sdetweil @kusselin
              @kusselin yes, to help keep this organized for you
              think of a container as a pi/nuc/laptop/extra machine with no display, running in text mode
              and the only way to get to it is thru a proxy machine (your container host)
              and then some other machine, laptop, phone, tablet that wants to display info…
              so other machine, phone, tablet connects to proxy, who forwards request to pi, and returns response back.
              the proxy doesnt DO anything but transport the info .
              • kusselinK
                kusselin
                thanks sam…YOU ARE THE BEST :-)
                • kusselinK
                  kusselin
                  one question: Where can i change the position from horizontal to vertical?
                  In what config can i change that?
                    sdetweil @kusselin
                    @kusselin well that becomes much more troublesome…
                    the container doesn’t have display, so u can’t force it there
                    also, server mode doesn’t know orientation of display system .
                    so this would typically be done on system w browser. full system in portrait or landscape.
                    I don’t know how you would do it just for one browser/tab…
                    • kusselinK
                      kusselin
                      ahh o.k. with installation on a pi there is the config.txt in boot an there you van change the display_rotate =1
                      O.K: in Container is difficult. Its ok. then thanks
                        sdetweil @kusselin
                        @kusselin if u are running container on pi, AND displaying on pi, then it’s the same. if u are running container on windows, displaying on pi, it’s the same.
                        if displaying on windows, then have to turn windows portrait mode
                        • kusselinK
                          kusselin @sdetweil
                          @sdetweil said in MagicMirror install on proxmox LXC Container?:
                          how is this going under win 10?
                          • kusselinK
                            kusselin
                            but there is a problem…when i started the server in the container with “npm run server” with putty… and i shut down the laptop the server is not reachable anymore :-(
                            means if I then eb on the ipad the 192.168.200.74:8080 enter the mirror is not accessible :-(
                            I have to enter again in putty then “npm run server” and then it is there…I shut down the laptop the server is no longer accessible :-(
                            What can be the reason for this now?
                            > node ./serveronly
                            [16.10.2022 15:55.38.561] [LOG]   Starting MagicMirror: v2.21.0
                            [16.10.2022 15:55.38.563] [LOG]   Loading config ...
                            [16.10.2022 15:55.38.566] [LOG]   Loading module helpers ...
                            [16.10.2022 15:55.38.567] [LOG]   No helper found for module: alert.
                            [16.10.2022 15:55.38.582] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.38.582] [LOG]   Module helper loaded: updatenotification
                            [16.10.2022 15:55.38.583] [LOG]   No helper found for module: clock.
                            [16.10.2022 15:55.38.712] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.38.712] [LOG]   Module helper loaded: calendar
                            [16.10.2022 15:55.38.713] [LOG]   No helper found for module: compliments.
                            [16.10.2022 15:55.38.713] [LOG]   No helper found for module: MMM-OpenmapWeather.
                            [16.10.2022 15:55.38.714] [LOG]   No helper found for module: weather.
                            [16.10.2022 15:55.38.722] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.38.722] [LOG]   Module helper loaded: newsfeed
                            [16.10.2022 15:55.38.722] [LOG]   No helper found for module: MMM-Traffic.
                            [16.10.2022 15:55.38.723] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.38.724] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.21.0
                            [16.10.2022 15:55.38.724] [LOG]   Version is ok!
                            [16.10.2022 15:55.38.724] [LOG]   Module helper loaded: MMM-Fuel
                            [16.10.2022 15:55.38.919] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.38.921] [LOG]   Module helper loaded: MMM-RNV
                            [16.10.2022 15:55.39.141] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.39.158] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                            [16.10.2022 15:55.39.158] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.39.158] [LOG]   Module helper loaded: MMM-ioBroker
                            [16.10.2022 15:55.39.209] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.39.209] [LOG]   Module helper loaded: MMM-COVID19-AMPEL
                            [16.10.2022 15:55.39.211] [LOG]   Initializing new module helper ...
                            [16.10.2022 15:55.39.211] [LOG]   Module helper loaded: MMM-SoccerLiveScore
                            [16.10.2022 15:55.39.211] [LOG]   No helper found for module: MMM-Snow.
                            [16.10.2022 15:55.39.212] [LOG]   No helper found for module: MMM-Carousel.
                            [16.10.2022 15:55.39.212] [LOG]   All module helpers loaded.
                            [16.10.2022 15:55.39.277] [LOG]   Starting server on port 8080 ...
                            [16.10.2022 15:55.39.315] [WARN]  You're using a full whitelist configuration to allow for all IPs
                            [16.10.2022 15:55.39.321] [LOG]   Server started ...
                            [16.10.2022 15:55.39.332] [LOG]   Connecting socket for: updatenotification
                            [16.10.2022 15:55.39.332] [LOG]   Starting module helper: updatenotification
                            [16.10.2022 15:55.39.333] [LOG]   Connecting socket for: calendar
                            [16.10.2022 15:55.39.333] [LOG]   Starting node helper for: calendar
                            [16.10.2022 15:55.39.333] [LOG]   Connecting socket for: newsfeed
                            [16.10.2022 15:55.39.333] [LOG]   Starting node helper for: newsfeed
                            [16.10.2022 15:55.39.334] [LOG]   Connecting socket for: MMM-Fuel
                            [16.10.2022 15:55.39.334] [LOG]   Starting module helper: MMM-Fuel
                            [16.10.2022 15:55.39.334] [LOG]   Connecting socket for: MMM-RNV
                            [16.10.2022 15:55.39.449] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                            [16.10.2022 15:55.39.450] [LOG]   Connecting socket for: MMM-ioBroker
                            [16.10.2022 15:55.39.451] [LOG]   Connecting socket for: MMM-COVID19-AMPEL
                            [16.10.2022 15:55.39.452] [LOG]   Starting node helper for: MMM-COVID19-AMPEL
                            [16.10.2022 15:55.39.452] [LOG]   Connecting socket for: MMM-SoccerLiveScore
                            [16.10.2022 15:55.39.453] [LOG]   Starting node helper for: MMM-SoccerLiveScore
                            [16.10.2022 15:55.39.453] [LOG]   Sockets connected & modules started ...
                            Ready to go! Please point your browser to: http://0.0.0.0:8080
                            and then this:
                            ^C[16.10.2022 15:55.50.516] [LOG]   [SIGINT] Received. Shutting down server...
                            [16.10.2022 15:55.50.516] [LOG]   Stopping module helper: updatenotification
                            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: calendar
                            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: newsfeed
                            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-Fuel
                            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-RNV
                            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-PublicTransportHafas
                            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-ioBroker
                            [16.10.2022 15:55.50.518] [LOG]   Stopping module helper: MMM-COVID19-AMPEL
                            [16.10.2022 15:55.50.518] [LOG]   Stopping node helper for: MMM-SoccerLiveScore
                            • kusselinK
                              kusselin
                              Sam, can you help me? What stopped the Server when i closed the putty Software?
                              • wishmaster270W
                                wishmaster270 Module Developer @kusselin
                                @kusselin
                                if your problem is only to keep the command running while/after you disconnected to the container you can use the “screen” command.
                                It you should be installed with Ubuntu already. If not you can install it with
                                sudo apt update && sudo apt install -y screen
                                You then start a new screen with
                                screen -S NAME
                                while NAME is simply an alias and could be something like “mm”.
                                After this you can start the mirror with
                                npm run server
                                And you can leave the screen with the keyboard combination
                                CRTL+ad
                                The screen then keeps running. If you want the resume to the screen you can use
                                screen -r NAME
                                kusselinK 3 Replies Last reply Reply Quote 0
                                  sdetweil @kusselin
                                  @kusselin when u disconnect a terminal session any app still running is terminated…
                                  u can spinit off in the background with & at the end of the command
                                  npm run server &
                                  • wishmaster270W
                                    wishmaster270 Module Developer @sdetweil
                                    @sdetweil You are right in running apps with & in the background but if you disconnect the ssh session all background commands will be disconnected as well.
                                    Either screen or a command like nohup needs to be used to keep the command running.
                                      sdetweil @wishmaster270
                                      @wishmaster270 never had one disconnected w &
                                      • kusselinK
                                        kusselin @wishmaster270
                                        @wishmaster270 said in MagicMirror install on proxmox LXC Container?:
                                        @kusselin
                                        screen -S NAME
                                        npm run server
                                        CRTL+ad
                                        screen -r NAME
                                        Thanks, so it is going :-)
                                          sdetweil @kusselin
                                          @kusselin and typically you would setup the container to run MM inside without user intervention… so none of those commands would be needed
                                          • kusselinK
                                            npm run server
                                            have today what changed at the mirror udn had to make reboot… now it no longer works :-(
                                            After I executed the commands like :
                                            screen -S MM (MM is the Name)
                                            then
                                            npm run server
                                            and when i close the terminal the MMis stopping:-(
                                            and the same when i going to cd /MagicMirror
                                            and then i take this:
                                            npm run server &
                                            when i close the terminal MM is stopping…
                                            what is my problem guys?
