    MagicMirror install on proxmox LXC Container?
    37 Posts 3 Posters 16.1k Views 3 Watching
    • kusselinK
      kusselin
      so installed again under “pi”…
      Commands executed by you here the result:
      login as: pi
      pi@192.168.200.74's password:
      Welcome to Ubuntu 22.04.1 LTS (GNU/Linux 5.15.35-1-pve x86_64)
       * Documentation:  https://help.ubuntu.com
       * Management:     https://landscape.canonical.com
       * Support:        https://ubuntu.com/advantage
      Last login: Sun Oct 16 09:53:33 2022 from 192.168.1.236
      pi@MagicMirror-live:~$ cd MagicMirror
      pi@MagicMirror-live:~/MagicMirror$ pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
      [PM2] [MagicMirror](0) ✓
      [PM2] Process successfully started
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 143  │ online    │ 0%       │ 4.0kb    │
      pi@MagicMirror-live:~/MagicMirror$ pm2 status
      │ 0  │ MagicMirror        │ fork     │ 308  │ online    │ 0%       │ 3.0mb    │
      │ 0  │ MagicMirror        │ fork     │ 363  │ online    │ 0%       │ 4.0kb    │
      If I now enter the following in the browser (Mozilla) then comes network overrun :-(
      http://192.168.200.74:8080
      I don´t know whta i can do :-(
      her my config
      /* MagicMirror² Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
      	address: "0.0.0.0", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: [], 	// Set [] to allow all IP addresses
      	language: "de",
      	locale: "de-DE",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "weather",
      				type: "current",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "YOUR_OPENWEATHER_API_KEY"
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      installed now is MagicMirror here
      /home/pi/MagicMirror
      • kusselinK
        kusselin
        When everyone have proxmox…please install it and give me feedback how you installed it.
        Thanks a lot
          sdetweil @kusselin
          @kusselin
          change the script that starts mm from
          npm start
          to
          npm run server
          a container has no desktop,
          npm start tries to load the graphical UI using electron.
          npm run server
          just starts the server side, for external browsers to access
          I can’t tell what that error is, but the internet has moved to https connections by default, and many browsers warn when accessing http sites like MagicMirror is running.
          so you either have to accept the warning, or find a way in the browser to disable to message
          https setup requires a certificate, which is not free.
          • kusselinK
            kusselin
            hi sdetweil, sorry my Linux knowledge is not good.
            Can you explain me how to change the script udn where in the script?
            Is my basic installation but with user “pi” so correct
              sdetweil @kusselin
              @kusselin my pm2 setup uses
              ~/MagicMirror/installers/mm.sh
              kusselinK 1 Reply Last reply
              • kusselinK
                kusselin @sdetweil
                @sdetweil said in MagicMirror install on proxmox LXC Container?:
                this standing in my mm.sh
                DISPLAY=:0 npm start
                an now i must put this into than looks like this
                npm run server
                so o.k.?
                  sdetweil @kusselin
                  @kusselin said in MagicMirror install on proxmox LXC Container?:
                  npm run server
                  no
                  npm run server
                  • kusselinK
                    kusselin
                    o.k…next try to step and hope i can start the MM
                    look…
                    curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                    [sudo] password for pi:
                    ## Installing the NodeSource Node.js 18.x repo...
                    ## Populating apt-get cache...
                    + apt-get update
                    Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
                    Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                    Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                    Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                    Fetched 224 kB in 2s (105 kB/s)
                    Reading package lists... Done
                    ## Confirming "jammy" is supported...
                    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/jammy/Release'
                    ## Adding the NodeSource signing key to your keyring...
                    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                    ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
                    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' > /etc/apt/sources.list.d/nodesource.list
                    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x jammy main' >> /etc/apt/sources.list.d/nodesource.list
                    ## Running `apt-get update` for you...
                    + apt-get update
                    Get:1 https://deb.nodesource.com/node_18.x jammy InRelease [4563 B]
                    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                    Get:5 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages [775 B]
                    Fetched 5338 B in 2s (2387 B/s)
                    ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
                    ## You may also need development tools to build native addons:
                         sudo apt-get install gcc g++ make
                    ## To install the Yarn package manager, run:
                         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                         sudo apt-get update && sudo apt-get install yarn
                    pi@MagicMirror-live:~$ sudo apt-get update && sudo apt-get install yarn
                    Hit:1 https://deb.nodesource.com/node_18.x jammy InRelease
                    Building dependency tree... Done
                    Note, selecting 'cmdtest' instead of 'yarn'
                    The following additional packages will be installed:
                      python3-cliapp python3-importlib-metadata python3-markdown
                      python3-more-itertools python3-pygments python3-ttystatus python3-zipp
                    Suggested packages:
                      python3-xdg python-markdown-doc python-pygments-doc ttf-bitstream-vera
                    The following NEW packages will be installed:
                      cmdtest python3-cliapp python3-importlib-metadata python3-markdown
                    0 upgraded, 8 newly installed, 0 to remove and 1 not upgraded.
                    Need to get 969 kB of archives.
                    After this operation, 5201 kB of additional disk space will be used.
                    Do you want to continue? [Y/n] Y
                    Get:1 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-cliapp all 1.20180812.1-4 [44.5 kB]
                    Get:2 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-more-itertools all 8.10.0-2 [47.9 kB]
                    Get:3 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-zipp all 1.0.0-3 [5440 B]
                    Get:4 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-importlib-metadata all 4.6.4-1 [16.2 kB]
                    Get:5 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-markdown all 3.3.6-1 [68.5 kB]
                    Get:6 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-ttystatus all 0.38-4 [14.7 kB]
                    Get:7 http://archive.ubuntu.com/ubuntu jammy/universe amd64 cmdtest all 0.32.14.gcdfe14e-2 [21.9 kB]
                    Get:8 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-pygments all 2.11.2+dfsg-2 [750 kB]
                    Fetched 969 kB in 1s (911 kB/s)
                    Selecting previously unselected package python3-cliapp.
                    (Reading database ... 29455 files and directories currently installed.)
                    Preparing to unpack .../0-python3-cliapp_1.20180812.1-4_all.deb ...
                    Unpacking python3-cliapp (1.20180812.1-4) ...
                    Selecting previously unselected package python3-more-itertools.
                    Preparing to unpack .../1-python3-more-itertools_8.10.0-2_all.deb ...
                    Unpacking python3-more-itertools (8.10.0-2) ...
                    Selecting previously unselected package python3-zipp.
                    Preparing to unpack .../2-python3-zipp_1.0.0-3_all.deb ...
                    Unpacking python3-zipp (1.0.0-3) ...
                    Selecting previously unselected package python3-importlib-metadata.
                    Preparing to unpack .../3-python3-importlib-metadata_4.6.4-1_all.deb ...
                    Unpacking python3-importlib-metadata (4.6.4-1) ...
                    Selecting previously unselected package python3-markdown.
                    Preparing to unpack .../4-python3-markdown_3.3.6-1_all.deb ...
                    Unpacking python3-markdown (3.3.6-1) ...
                    Selecting previously unselected package python3-ttystatus.
                    Preparing to unpack .../5-python3-ttystatus_0.38-4_all.deb ...
                    Unpacking python3-ttystatus (0.38-4) ...
                    Selecting previously unselected package cmdtest.
                    Preparing to unpack .../6-cmdtest_0.32.14.gcdfe14e-2_all.deb ...
                    Unpacking cmdtest (0.32.14.gcdfe14e-2) ...
                    Selecting previously unselected package python3-pygments.
                    Preparing to unpack .../7-python3-pygments_2.11.2+dfsg-2_all.deb ...
                    Unpacking python3-pygments (2.11.2+dfsg-2) ...
                    Setting up python3-ttystatus (0.38-4) ...
                    Setting up python3-more-itertools (8.10.0-2) ...
                    Setting up python3-zipp (1.0.0-3) ...
                    Setting up python3-cliapp (1.20180812.1-4) ...
                    Setting up python3-pygments (2.11.2+dfsg-2) ...
                    Setting up python3-importlib-metadata (4.6.4-1) ...
                    Setting up python3-markdown (3.3.6-1) ...
                    Setting up cmdtest (0.32.14.gcdfe14e-2) ...
                    Processing triggers for man-db (2.10.2-1) ...
                    pi@MagicMirror-live:~$ sudo apt install -y nodejs
                    The following packages will be upgraded:
                      nodejs
                    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 28.5 MB of archives.
                    After this operation, 52.4 MB of additional disk space will be used.
                    Get:1 https://deb.nodesource.com/node_18.x jammy/main amd64 nodejs amd64 18.11.0-deb-1nodesource1 [28.5 MB]
                    Fetched 28.5 MB in 1s (22.4 MB/s)
                    (Reading database ... 29937 files and directories currently installed.)
                    Preparing to unpack .../nodejs_18.11.0-deb-1nodesource1_amd64.deb ...
                    Unpacking nodejs (18.11.0-deb-1nodesource1) over (16.17.1-deb-1nodesource1) ...
                    Setting up nodejs (18.11.0-deb-1nodesource1) ...
                    pi@MagicMirror-live:~$ git clone https://github.com/MichMich/MagicMirror
                    Cloning into 'MagicMirror'...
                    remote: Enumerating objects: 23768, done.
                    remote: Counting objects: 100% (1/1), done.
                    remote: Total 23768 (delta 0), reused 1 (delta 0), pack-reused 23767
                    Receiving objects: 100% (23768/23768), 19.76 MiB | 12.35 MiB/s, done.
                    Resolving deltas: 100% (14649/14649), done.
                    pi@MagicMirror-live:~$ cd MagicMirror/
                    pi@MagicMirror-live:~/MagicMirror$ npm run install-mm
                    > magicmirror@2.21.0 install-mm
                    > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
                    npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
                    > magicmirror@2.21.0 postinstall
                    > npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                    > magicmirror@2.21.0 install-vendor
                    > " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    added 9 packages in 5s
                    > magicmirror@2.21.0 install-fonts
                    > echo "Installing fonts ...
                    > " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    added 2 packages in 1s
                    > magicmirror@2.21.0 prepare
                    > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                    no husky installed.
                    added 300 packages in 36s
                    pi@MagicMirror-live:~/MagicMirror$ cp config/config.js.sample config/config.js
                    pi@MagicMirror-live:~/MagicMirror$ npm run server
                    > magicmirror@2.21.0 server
                    > node ./serveronly
                    [16.10.2022 13:16.02.218] [LOG]   Starting MagicMirror: v2.21.0
                    [16.10.2022 13:16.02.225] [LOG]   Loading config ...
                    [16.10.2022 13:16.02.235] [LOG]   Loading module helpers ...
                    [16.10.2022 13:16.02.236] [LOG]   No helper found for module: alert.
                    [16.10.2022 13:16.02.252] [LOG]   Initializing new module helper ...
                    [16.10.2022 13:16.02.254] [LOG]   Module helper loaded: updatenotification
                    [16.10.2022 13:16.02.254] [LOG]   No helper found for module: clock.
                    [16.10.2022 13:16.02.513] [LOG]   Initializing new module helper ...
                    [16.10.2022 13:16.02.514] [LOG]   Module helper loaded: calendar
                    [16.10.2022 13:16.02.515] [LOG]   No helper found for module: compliments.
                    [16.10.2022 13:16.02.516] [LOG]   No helper found for module: weather.
                    [16.10.2022 13:16.02.536] [LOG]   Initializing new module helper ...
                    [16.10.2022 13:16.02.536] [LOG]   Module helper loaded: newsfeed
                    [16.10.2022 13:16.02.536] [LOG]   All module helpers loaded.
                    [16.10.2022 13:16.02.679] [LOG]   Starting server on port 8080 ...
                    [16.10.2022 13:16.02.695] [LOG]   Server started ...
                    [16.10.2022 13:16.02.696] [LOG]   Connecting socket for: updatenotification
                    [16.10.2022 13:16.02.696] [LOG]   Starting module helper: updatenotification
                    [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: calendar
                    [16.10.2022 13:16.02.697] [LOG]   Starting node helper for: calendar
                    [16.10.2022 13:16.02.697] [LOG]   Connecting socket for: newsfeed
                    [16.10.2022 13:16.02.698] [LOG]   Starting node helper for: newsfeed
                    [16.10.2022 13:16.02.698] [LOG]   Sockets connected & modules started ...
                    Ready to go! Please point your browser to: http://localhost:8080
                    is this now right abd is the info “no helper module” O.K.?
                    best regards
                    P.S. when i put “http://localhost:8080” in the browser linie - it´s not going :-(
                      sdetweil @kusselin
                      @kusselin remember, a container is a ‘system’
                      with its own IP address different than than the container hosting system (typically 172.xx.yy.zz)
                      also, localhost means ONLY apps INSIDE this same ‘system’, can access… so that means a browser running IN the container… oops… not possible
                      SO, you have to change the MM config.js to allow apps OUTSIDE the container to access the MM app
                      and THEN on the container setup , map the container MM port to some host port … (so u can access from another pc, phone, tablet, outside the container hosting system )
                      address:“0.0.0.0”.
                      ipWhitelist:[],
                      you didn’t have to reinstall mm… one install runs three ways
                      full (ui on same ‘system’), npm start
                      server (ui on some OTHER system (have to change config) npm run server
                      client (just the UI part), npm run client
                      • kusselinK
                        kusselin @sdetweil
                        @sdetweil what a fu…
                        now its running!!! Ohman!! yeahhhhhhh :-) thanks a lot…
                        o.k. i understand …in an lxc is not same as a pi with raspbia…because lxc is an container and has no graphic giu…then i have to start server (npm start server" right…
                        and i mut change the config as this here
                        address:“0.0.0.0”.
                        ipWhitelist:[],
                          sdetweil @kusselin
                          @kusselin yes, to help keep this organized for you
                          think of a container as a pi/nuc/laptop/extra machine with no display, running in text mode
                          and the only way to get to it is thru a proxy machine (your container host)
                          and then some other machine, laptop, phone, tablet that wants to display info…
                          so other machine, phone, tablet connects to proxy, who forwards request to pi, and returns response back.
                          the proxy doesnt DO anything but transport the info .
                          • kusselinK
                            kusselin
                            thanks sam…YOU ARE THE BEST :-)
                            • kusselinK
                              kusselin
                              one question: Where can i change the position from horizontal to vertical?
                              In what config can i change that?
                                sdetweil @kusselin
                                @kusselin well that becomes much more troublesome…
                                the container doesn’t have display, so u can’t force it there
                                also, server mode doesn’t know orientation of display system .
                                so this would typically be done on system w browser. full system in portrait or landscape.
                                I don’t know how you would do it just for one browser/tab…
                                • kusselinK
                                  kusselin
                                  ahh o.k. with installation on a pi there is the config.txt in boot an there you van change the display_rotate =1
                                  O.K: in Container is difficult. Its ok. then thanks
                                    sdetweil @kusselin
                                    @kusselin if u are running container on pi, AND displaying on pi, then it’s the same. if u are running container on windows, displaying on pi, it’s the same.
                                    if displaying on windows, then have to turn windows portrait mode
                                    • kusselinK
                                      kusselin @sdetweil
                                      how is this going under win 10?
                                      • kusselinK
                                        kusselin
                                        but there is a problem…when i started the server in the container with “npm run server” with putty… and i shut down the laptop the server is not reachable anymore :-(
                                        means if I then eb on the ipad the 192.168.200.74:8080 enter the mirror is not accessible :-(
                                        I have to enter again in putty then “npm run server” and then it is there…I shut down the laptop the server is no longer accessible :-(
                                        What can be the reason for this now?
                                        > node ./serveronly
                                        [16.10.2022 15:55.38.561] [LOG]   Starting MagicMirror: v2.21.0
                                        [16.10.2022 15:55.38.563] [LOG]   Loading config ...
                                        [16.10.2022 15:55.38.566] [LOG]   Loading module helpers ...
                                        [16.10.2022 15:55.38.567] [LOG]   No helper found for module: alert.
                                        [16.10.2022 15:55.38.582] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.38.582] [LOG]   Module helper loaded: updatenotification
                                        [16.10.2022 15:55.38.583] [LOG]   No helper found for module: clock.
                                        [16.10.2022 15:55.38.712] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.38.712] [LOG]   Module helper loaded: calendar
                                        [16.10.2022 15:55.38.713] [LOG]   No helper found for module: compliments.
                                        [16.10.2022 15:55.38.713] [LOG]   No helper found for module: MMM-OpenmapWeather.
                                        [16.10.2022 15:55.38.714] [LOG]   No helper found for module: weather.
                                        [16.10.2022 15:55.38.722] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.38.722] [LOG]   Module helper loaded: newsfeed
                                        [16.10.2022 15:55.38.722] [LOG]   No helper found for module: MMM-Traffic.
                                        [16.10.2022 15:55.38.723] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.38.724] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.21.0
                                        [16.10.2022 15:55.38.724] [LOG]   Version is ok!
                                        [16.10.2022 15:55.38.724] [LOG]   Module helper loaded: MMM-Fuel
                                        [16.10.2022 15:55.38.919] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.38.921] [LOG]   Module helper loaded: MMM-RNV
                                        [16.10.2022 15:55.39.141] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.39.158] [LOG]   Module helper loaded: MMM-PublicTransportHafas
                                        [16.10.2022 15:55.39.158] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.39.158] [LOG]   Module helper loaded: MMM-ioBroker
                                        [16.10.2022 15:55.39.209] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.39.209] [LOG]   Module helper loaded: MMM-COVID19-AMPEL
                                        [16.10.2022 15:55.39.211] [LOG]   Initializing new module helper ...
                                        [16.10.2022 15:55.39.211] [LOG]   Module helper loaded: MMM-SoccerLiveScore
                                        [16.10.2022 15:55.39.211] [LOG]   No helper found for module: MMM-Snow.
                                        [16.10.2022 15:55.39.212] [LOG]   No helper found for module: MMM-Carousel.
                                        [16.10.2022 15:55.39.212] [LOG]   All module helpers loaded.
                                        [16.10.2022 15:55.39.277] [LOG]   Starting server on port 8080 ...
                                        [16.10.2022 15:55.39.315] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                        [16.10.2022 15:55.39.321] [LOG]   Server started ...
                                        [16.10.2022 15:55.39.332] [LOG]   Connecting socket for: updatenotification
                                        [16.10.2022 15:55.39.332] [LOG]   Starting module helper: updatenotification
                                        [16.10.2022 15:55.39.333] [LOG]   Connecting socket for: calendar
                                        [16.10.2022 15:55.39.333] [LOG]   Starting node helper for: calendar
                                        [16.10.2022 15:55.39.333] [LOG]   Connecting socket for: newsfeed
                                        [16.10.2022 15:55.39.333] [LOG]   Starting node helper for: newsfeed
                                        [16.10.2022 15:55.39.334] [LOG]   Connecting socket for: MMM-Fuel
                                        [16.10.2022 15:55.39.334] [LOG]   Starting module helper: MMM-Fuel
                                        [16.10.2022 15:55.39.334] [LOG]   Connecting socket for: MMM-RNV
                                        [16.10.2022 15:55.39.449] [LOG]   Connecting socket for: MMM-PublicTransportHafas
                                        [16.10.2022 15:55.39.450] [LOG]   Connecting socket for: MMM-ioBroker
                                        [16.10.2022 15:55.39.451] [LOG]   Connecting socket for: MMM-COVID19-AMPEL
                                        [16.10.2022 15:55.39.452] [LOG]   Starting node helper for: MMM-COVID19-AMPEL
                                        [16.10.2022 15:55.39.452] [LOG]   Connecting socket for: MMM-SoccerLiveScore
                                        [16.10.2022 15:55.39.453] [LOG]   Starting node helper for: MMM-SoccerLiveScore
                                        [16.10.2022 15:55.39.453] [LOG]   Sockets connected & modules started ...
                                        Ready to go! Please point your browser to: http://0.0.0.0:8080
                                        and then this:
                                        ^C[16.10.2022 15:55.50.516] [LOG]   [SIGINT] Received. Shutting down server...
                                        [16.10.2022 15:55.50.516] [LOG]   Stopping module helper: updatenotification
                                        [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: calendar
                                        [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: newsfeed
                                        [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-Fuel
                                        [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-RNV
                                        [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-PublicTransportHafas
                                        [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-ioBroker
                                        [16.10.2022 15:55.50.518] [LOG]   Stopping module helper: MMM-COVID19-AMPEL
                                        [16.10.2022 15:55.50.518] [LOG]   Stopping node helper for: MMM-SoccerLiveScore
                                        wishmaster270W 1 Reply Last reply
                                        • kusselinK
                                          kusselin
                                          Sam, can you help me? What stopped the Server when i closed the putty Software?
                                          • wishmaster270W
                                            wishmaster270 Module Developer @kusselin
                                            @kusselin
                                            if your problem is only to keep the command running while/after you disconnected to the container you can use the “screen” command.
                                            It you should be installed with Ubuntu already. If not you can install it with
                                            sudo apt update && sudo apt install -y screen
                                            You then start a new screen with
                                            screen -S NAME
                                            while NAME is simply an alias and could be something like “mm”.
                                            After this you can start the mirror with
                                            npm run server
                                            And you can leave the screen with the keyboard combination
                                            CRTL+ad
                                            The screen then keeps running. If you want the resume to the screen you can use
                                            screen -r NAME
                                            kusselinK 3 Replies Last reply
