    MagicMirror install on proxmox LXC Container?
    37 Posts 3 Posters 15.2k Views 3 Watching
    • kusselinK Offline
      kusselin
      ahh o.k. with installation on a pi there is the config.txt in boot an there you van change the display_rotate =1
      O.K: in Container is difficult. Its ok. then thanks
        sdetweil @kusselin
        @kusselin if u are running container on pi, AND displaying on pi, then it’s the same. if u are running container on windows, displaying on pi, it’s the same.
        if displaying on windows, then have to turn windows portrait mode
        kusselinK 1 Reply Last reply Reply Quote 0
        • kusselinK Offline
          kusselin @sdetweil
          @sdetweil said in MagicMirror install on proxmox LXC Container?:
          how is this going under win 10?
          • kusselinK Offline
            kusselin
            but there is a problem…when i started the server in the container with “npm run server” with putty… and i shut down the laptop the server is not reachable anymore :-(
            means if I then eb on the ipad the 192.168.200.74:8080 enter the mirror is not accessible :-(
            I have to enter again in putty then “npm run server” and then it is there…I shut down the laptop the server is no longer accessible :-(
            What can be the reason for this now?
            pi@MagicMirror-live:~/MagicMirror$ npm run server
            > magicmirror@2.21.0 server
            > node ./serveronly
            [16.10.2022 15:55.38.561] [LOG]   Starting MagicMirror: v2.21.0
            [16.10.2022 15:55.38.563] [LOG]   Loading config ...
            [16.10.2022 15:55.38.566] [LOG]   Loading module helpers ...
            [16.10.2022 15:55.38.567] [LOG]   No helper found for module: alert.
            [16.10.2022 15:55.38.582] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.38.582] [LOG]   Module helper loaded: updatenotification
            [16.10.2022 15:55.38.583] [LOG]   No helper found for module: clock.
            [16.10.2022 15:55.38.712] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.38.712] [LOG]   Module helper loaded: calendar
            [16.10.2022 15:55.38.713] [LOG]   No helper found for module: compliments.
            [16.10.2022 15:55.38.713] [LOG]   No helper found for module: MMM-OpenmapWeather.
            [16.10.2022 15:55.38.714] [LOG]   No helper found for module: weather.
            [16.10.2022 15:55.38.722] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.38.722] [LOG]   Module helper loaded: newsfeed
            [16.10.2022 15:55.38.722] [LOG]   No helper found for module: MMM-Traffic.
            [16.10.2022 15:55.38.723] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.38.724] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.21.0
            [16.10.2022 15:55.38.724] [LOG]   Version is ok!
            [16.10.2022 15:55.38.724] [LOG]   Module helper loaded: MMM-Fuel
            [16.10.2022 15:55.38.919] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.38.921] [LOG]   Module helper loaded: MMM-RNV
            [16.10.2022 15:55.39.141] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.39.158] [LOG]   Module helper loaded: MMM-PublicTransportHafas
            [16.10.2022 15:55.39.158] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.39.158] [LOG]   Module helper loaded: MMM-ioBroker
            [16.10.2022 15:55.39.209] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.39.209] [LOG]   Module helper loaded: MMM-COVID19-AMPEL
            [16.10.2022 15:55.39.211] [LOG]   Initializing new module helper ...
            [16.10.2022 15:55.39.211] [LOG]   Module helper loaded: MMM-SoccerLiveScore
            [16.10.2022 15:55.39.211] [LOG]   No helper found for module: MMM-Snow.
            [16.10.2022 15:55.39.212] [LOG]   No helper found for module: MMM-Carousel.
            [16.10.2022 15:55.39.212] [LOG]   All module helpers loaded.
            [16.10.2022 15:55.39.277] [LOG]   Starting server on port 8080 ...
            [16.10.2022 15:55.39.315] [WARN]  You're using a full whitelist configuration to allow for all IPs
            [16.10.2022 15:55.39.321] [LOG]   Server started ...
            [16.10.2022 15:55.39.332] [LOG]   Connecting socket for: updatenotification
            [16.10.2022 15:55.39.332] [LOG]   Starting module helper: updatenotification
            [16.10.2022 15:55.39.333] [LOG]   Connecting socket for: calendar
            [16.10.2022 15:55.39.333] [LOG]   Starting node helper for: calendar
            [16.10.2022 15:55.39.333] [LOG]   Connecting socket for: newsfeed
            [16.10.2022 15:55.39.333] [LOG]   Starting node helper for: newsfeed
            [16.10.2022 15:55.39.334] [LOG]   Connecting socket for: MMM-Fuel
            [16.10.2022 15:55.39.334] [LOG]   Starting module helper: MMM-Fuel
            [16.10.2022 15:55.39.334] [LOG]   Connecting socket for: MMM-RNV
            [16.10.2022 15:55.39.449] [LOG]   Connecting socket for: MMM-PublicTransportHafas
            [16.10.2022 15:55.39.450] [LOG]   Connecting socket for: MMM-ioBroker
            [16.10.2022 15:55.39.451] [LOG]   Connecting socket for: MMM-COVID19-AMPEL
            [16.10.2022 15:55.39.452] [LOG]   Starting node helper for: MMM-COVID19-AMPEL
            [16.10.2022 15:55.39.452] [LOG]   Connecting socket for: MMM-SoccerLiveScore
            [16.10.2022 15:55.39.453] [LOG]   Starting node helper for: MMM-SoccerLiveScore
            [16.10.2022 15:55.39.453] [LOG]   Sockets connected & modules started ...
            Ready to go! Please point your browser to: http://0.0.0.0:8080
            and then this:
            ^C[16.10.2022 15:55.50.516] [LOG]   [SIGINT] Received. Shutting down server...
            [16.10.2022 15:55.50.516] [LOG]   Stopping module helper: updatenotification
            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: calendar
            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: newsfeed
            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-Fuel
            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-RNV
            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-PublicTransportHafas
            [16.10.2022 15:55.50.517] [LOG]   Stopping module helper: MMM-ioBroker
            [16.10.2022 15:55.50.518] [LOG]   Stopping module helper: MMM-COVID19-AMPEL
            [16.10.2022 15:55.50.518] [LOG]   Stopping node helper for: MMM-SoccerLiveScore
            • kusselinK Offline
              kusselin
              Sam, can you help me? What stopped the Server when i closed the putty Software?
              • wishmaster270W Offline
                wishmaster270 Module Developer @kusselin
                @kusselin
                if your problem is only to keep the command running while/after you disconnected to the container you can use the “screen” command.
                It you should be installed with Ubuntu already. If not you can install it with
                sudo apt update && sudo apt install -y screen
                You then start a new screen with
                screen -S NAME
                while NAME is simply an alias and could be something like “mm”.
                After this you can start the mirror with
                npm run server
                And you can leave the screen with the keyboard combination
                CRTL+ad
                The screen then keeps running. If you want the resume to the screen you can use
                screen -r NAME
                kusselinK 3 Replies Last reply Reply Quote 0
                  sdetweil @kusselin
                  @kusselin when u disconnect a terminal session any app still running is terminated…
                  u can spinit off in the background with & at the end of the command
                  npm run server &
                    wishmaster270 Module Developer @sdetweil
                    @sdetweil You are right in running apps with & in the background but if you disconnect the ssh session all background commands will be disconnected as well.
                    Either screen or a command like nohup needs to be used to keep the command running.
                      sdetweil @wishmaster270
                      @wishmaster270 never had one disconnected w &
                      • kusselinK Offline
                        kusselin @wishmaster270
                        @wishmaster270 said in MagicMirror install on proxmox LXC Container?:
                        @kusselin
                        screen -S NAME
                        npm run server
                        CRTL+ad
                        screen -r NAME
                        Thanks, so it is going :-)
                          sdetweil @kusselin
                          @kusselin and typically you would setup the container to run MM inside without user intervention… so none of those commands would be needed
                          • kusselinK Offline
                            npm run server
                            have today what changed at the mirror udn had to make reboot… now it no longer works :-(
                            After I executed the commands like :
                            screen -S MM (MM is the Name)
                            then
                            npm run server
                            and when i close the terminal the MMis stopping:-(
                            and the same when i going to cd /MagicMirror
                            and then i take this:
                            npm run server &
                            when i close the terminal MM is stopping…
                            what is my problem guys?
                            • kusselinK Offline
                              kusselin @sdetweil
                              Hi sam, unfortunately I have not yet understood why the server always stops when closing putty???
                              With the command npm run server I start the server… why does the container stop again?
                                sdetweil @kusselin
                                @kusselin because that is the way it works. when the terminal window closes, any running app also is forced closed. it’s a security thing
                                during development I would not close the window. after you are happy, I would make the container auto start mm as part of it’s startup.
                                a containers design is to run ONE app.
                                I do not know how I do this w lxc containers
                                w docker, u add a property to the Dockerfile to tell what app to start
                                • kusselinK Offline
                                  @kusselin
                                  screen -S NAME
                                  npm run server
                                  CRTL+ad
                                  screen -r NAME
                                  And what about this… yesterday i installed screen and i Type the Commander in putty and the Containers was already online…
                                  Now, After an reboot Nottingham is Gong :-(
                                    sdetweil @kusselin
                                    @kusselin did the IP address change?
                                    • kusselinK Offline
                                      kusselin
                                      Hi sam,
                                      This was my Solution Now
                                      https://forum.iobroker.net/topic/52195/magic-mirror-zusammen-mit-iobroker/173?_=1666207319057
                                      Crontab
