    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    UNSOLVED MMM-OpenWeatherMapForecast does not receive data from the Internet
    Troubleshooting
    • K
      Kostosso last edited by
      Good afternoon,
      My module MMM-OpenWeatherMapForecast does not receive data from the Internet.
      I installed MM on My Home Server in Docker. I used the karsten13/magicmirror image. Everything is set up and running great. In the default configuration, all modules worked except for the weather.
      I did not dwell on this, but installed my own configuration that had previously worked on Raspberry.
      All modules, including Google calendars, started up fine, but … But the weather forecast module does not work again.
      I checked that from the mm container the ping openweathermap.org
      command works fine.
      However, the mm logs contain the following entries:
      [OpenWeatherMapForecast] **ERROR** Error: socket hang up
      There are no more errors in the logs.
      Help me please. What is this error and how can it be removed?
      Thanks a lot in advance!
      • J
        Juliablack last edited by
        @Kostosso
        I a having a same things happens with me still not get solution.
