    How to make it as slim as possible?
    19 Posts 4 Posters 13.0k Views 3 Watching
    • ? Offline
      A Former User
      Hi all
      I’ve got my Magic Mirror running nicely, however now comes the part where I have to build it (where I have less experience).
      I intent for the mirror to replace the existing hanging mirror in the bathroom. It’ll be about 1200 x 600mm landscape with the monitor positioned portrait on the left hand side.
      So what I’m asking is…
      1. What monitor did you use (trying to get this as slim as possible)?
      2. Did you dissemble a monitor to make it slimmer?
      3. Any other tips?
      Leadfarmer
      • cowboysdudeC Offline
        cowboysdude Module Developer
        That’s a pretty big mirror…
        In US size that’s 2ft X 4ft…
        You’d need a TV for that size unless you want to pay big dollars for a monitor that big…
        Going to take some planning for that LOL.
        I’m currently building one out of a 32" TV and that’s a pretty big size as well… but mine won’t be a mirror… it’s going to be a control board for the house…
        BUT if you do build it that big and you do use a TV do your homework… not all TV’s display computer info that well… be careful ;)
        • ? Offline
          A Former User @cowboysdude
          @cowboysdude haha sorry I should have been more specific. The mirror is 1200 x 600mm landscape but the monitor will about about 24 inch but rotated to be portrait and positioned on the left end of the mirror.
          Hope that makes sense.
            Yes a lot more LOL I would try to find a monitor that uses the HDMI cable that plugs in from underneath not straight out of the back…
            Not sure where you’re from …
            I would use either a 24" monitor or bigger… but you go bigger and the prices does too LOL
            Something like this: https://www.amazon.com/Dell-E2416HM-G0RH1-24-0-Monitor/dp/B01LY59FT7/ref=sr_1_3?ie=UTF8&qid=1486872226&sr=8-3&keywords=24+inch+computer+monitor
            Feb is usually the month new computer things come out so prices dip… ;)
            BUT to solve my plugging directly into the back HDMI problem I used one of these :100:
            https://www.amazon.com/Postta-Adapter-Degree-Female-Connector/dp/B01HZ60L9Q/ref=sr_1_1?ie=UTF8&qid=1486872434&sr=8-1-spons&keywords=right+angle+hdmi+connector&psc=1
            • ? Offline
              A Former User
              I’m from Aus. Came across similar monitors but trying to find something even slimmer. This one looks slimmer but in reality it might not be.
              https://www.mwave.com.au/product/aoc-i2481fxh-238-fhd-ahips-ultraslim-led-monitor-ab92651?gclid=Cj0KEQiAifvEBRCVx5up6Ojgr5oBEiQALHw1TjWswuSF3s8KByUoY95zA1qCRWyJtvGYWJXxP4IjFLIaAuOp8P8HAQ#detailTabs=tabReviews
              The HDMI adapter could be useful!
              cowboysdudeC B 2 Replies Last reply Reply Quote 0
                cowboysdude Module Developer @Guest
                @leadfarmer That’s pretty slim… a lot slimmer then the one I bought… wow… I like that one! :)
                  broberg Project Sponsor @Guest
                  @leadfarmer yeah, at the moment you probably won’t find anything slimmer than that, what could it be 30mm at the base?
                  Don’t bother with an adapter just buy a hdmi cable with the angled connector instead, I think there is really short ones out there.
                  I’m also building a 120*60cm bathroom mirror, but I’m also putting in some 240v outlets in the frame so mine is around 10cm deep, I have lots of space inside.
                  Are you planning on a frame or just “studs” around/through the mirror?
                  And btw, I wouldn’t disassemble it, if it breaks while still under warranty, you will be glad you didn’t take it appart :)
                  ? 1 Reply Last reply Reply Quote 1
                  • ? Offline
                    A Former User @broberg
                    @broberg interested to see how yours comes out.
                    Decided to go with a different monitor that is only 57mm thick (including the case). The one I linked before has the hdmi/power plugs horizontal rather than vertical so that would have added more depth to the mirror.
                    I’m now going with a 1200 x 900mm mirror with a box frame that will be about 70mm deep.
                    I’m tempted to put a power socket in the ceiling and put the pi and pir sensor up there, meaning that I would just need to run the hdmi and monitor power cable down the wall to the mirror.
                    What do you think?
                      @leadfarmer sounds good! But going up in height of the mirror I would get a larger monitor to fill the height, 24" works well with the 600mm height, but with 900mm I would get a 32" monitor (aprox 720-750mm wide at 16:9).
                      • ? Offline
                        @broberg still gonna use a 24 inch. I’ve got the modules aligned down the left hand side and across the bottom and will have the monitor in the bottom left (portrait orientation). So from the outside the graphics will start about eye height and run down the left to the corner then across the bottom a little.
                          @leadfarmer I’m just thinking about the backlight of the screen, since no monitor has pure black there will always be bleed through on the mirror, and with a smaller monitor you get more visible edges than if you try to run the monitor as close to the mirrors edges as possible.
                          In a bright lighted room in most cases it doesn’t matter, but still, trying to eliminate that will make for a better magicmirror :-)
                          ? 2 Replies Last reply Reply Quote 0
                          • ? Offline
                            @broberg good point. You’d still get the bleed on the right hand edge though?
                            • ? Offline
                              @broberg speaking of the ‘bleed’ from the monitor - what percentage of light comes through your mirror? I was looking at 70-80% reflective…
                                @leadfarmer yeah you would get an edge to the right, but just to the right, not right and up :-)
                                I have a mirror with 57% reflection and 3% light transmission, 3% isn’t much and will probably give me a bit of an issue if the bathroom turns out to become super bright. But with only one window and dark tiles I’m hoping it will be enough crossing fingers
                                57% reflection gives a slight dark reflection, 65-75% would make for a better mirror surface.
                                • ? Offline
                                  @broberg hmmm that might be why you get a more obvious bleed.
                                  I might see if I can get some different samples and I’ll test which works the best.
                                    @leadfarmer actually 3% is better at hiding the backlight bleed through, since it lets less light thruu the coating, but it also effectivly dampens all light, so less visibility for whats being displayed. It helps to use a heavier and larger size font on everything :)
                                    If you can choose, try getting at least 12% light transmission, reading around the interwebbz 20% for normal lighted rooms and 40% for daylighy/really bright rooms.
                                    • ? Offline
                                      @broberg Thanks. I’ve contacted a local window tint shop and will pick up some samples in a few days when my monitor arrives. Means I can test different options over the monitor display and over the edge of the monitor.
                                        There you have it! :) Many hands make light work! Ask a question and VIOLA! :)
                                        Glad you are finding what you need… someday some ‘new’ guy/gal will be asking a question you can easily answer… that’s how we roll round here. :)
                                          dangjoeltang
                                          Hey sorry this is a really old post, but I found that using a laptop LCD with a display adapter helped me make my mirror under 1 inch in thickness. The glass I used was 6mm, and the thickest component I have is the raspberry pi, at about half an inch.
