    MMM-awesome-alexa on Orange Pi LTS 4
    6 Posts 2 Posters 597 Views 2 Watching
      SojuSlushy
      Hello,
      I am trying to run MMM-awesome-alexa on Magic Mirror through an Orange Pi LTS 4 running Kernel 5.15.76-rockchip64, Armbian 22.08.10 Jammy.
      I followed the instructions to install MMM-awesome-alexa and have run into an issue after using the wake word “Alexa”. While Magic Mirror is running, using the wake word “Alexa” returns a white circle that appears which then starts making static popping noises from my speakers, while the white circle just remains on the screen as a smaller dot.
      I tested my Microphone recording without any issues. I also tested speaker to listen to the recording. Both were working.
      Below is the error message I am receiving. Any help would be greatly appreciated.
      cindy@orangepi4-lts:~/MagicMirror$ npm start
      > magicmirror@2.21.0 start /home/cindy/MagicMirror
      [18.11.2022 11:47.44.084] [LOG]   Starting MagicMirror: v2.21.0
      [18.11.2022 11:47.44.093] [LOG]   Loading config ...
      [18.11.2022 11:47.44.099] [LOG]   Loading module helpers ...
      [18.11.2022 11:47.44.102] [LOG]   No helper found for module: alert.
      [18.11.2022 11:47.44.118] [LOG]   Initializing new module helper ...
      [18.11.2022 11:47.44.120] [LOG]   Module helper loaded: updatenotification
      [18.11.2022 11:47.44.121] [LOG]   No helper found for module: clock.
      [18.11.2022 11:47.44.328] [LOG]   Initializing new module helper ...
      [18.11.2022 11:47.44.329] [LOG]   Module helper loaded: calendar
      [18.11.2022 11:47.44.331] [LOG]   No helper found for module: weather.
      [18.11.2022 11:47.44.362] [LOG]   Initializing new module helper ...
      [18.11.2022 11:47.44.363] [LOG]   Module helper loaded: newsfeed
      [18.11.2022 11:47.44.393] [LOG]   Initializing new module helper ...
      [18.11.2022 11:47.44.394] [LOG]   Check MagicMirror² version for node helper 'MMM-NFL' - Minimum version: 2.15.0 - Current version: 2.21.0
      [18.11.2022 11:47.44.396] [LOG]   Version is ok!
      [18.11.2022 11:47.44.396] [LOG]   Module helper loaded: MMM-NFL
      [18.11.2022 11:47.45.329] [LOG]   Initializing new module helper ...
      [18.11.2022 11:47.45.329] [LOG]   Module helper loaded: MMM-awesome-alexa
      [18.11.2022 11:47.45.330] [LOG]   All module helpers loaded.
      [18.11.2022 11:47.45.436] [LOG]   Starting server on port 3000 ...
      [18.11.2022 11:47.45.451] [LOG]   Server started ...
      [18.11.2022 11:47.45.453] [LOG]   Connecting socket for: updatenotification
      [18.11.2022 11:47.45.454] [LOG]   Starting module helper: updatenotification
      [18.11.2022 11:47.45.455] [LOG]   Connecting socket for: calendar
      [18.11.2022 11:47.45.456] [LOG]   Starting node helper for: calendar
      [18.11.2022 11:47.45.457] [LOG]   Connecting socket for: newsfeed
      [18.11.2022 11:47.45.458] [LOG]   Starting node helper for: newsfeed
      [18.11.2022 11:47.45.459] [LOG]   Connecting socket for: MMM-NFL
      [18.11.2022 11:47.45.459] [LOG]   Starting module helper: MMM-NFL
      [18.11.2022 11:47.45.460] [LOG]   Connecting socket for: MMM-awesome-alexa
      [18.11.2022 11:47.45.461] [LOG]   Sockets connected & modules started ...
      [18.11.2022 11:47.45.830] [LOG]   Launching application.
      [12127:1118/114746.605662:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.606143:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.606489:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.606755:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.607268:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.607586:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.607874:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.608141:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.613226:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.613562:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.613819:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.614049:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.614275:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.614560:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.614795:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [12127:1118/114746.615024:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
      [18.11.2022 11:47.48.171] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [18.11.2022 11:47.48.280] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [18.11.2022 11:47.48.359] [INFO]  Checking git for module: MMM-NFL
      [18.11.2022 11:47.48.403] [INFO]  Checking git for module: MMM-awesome-alexa
      [18.11.2022 11:47.48.444] [INFO]  Checking git for module: default
      [18.11.2022 11:47.48.736] [INFO]  Calendar-Fetcher: Broadcasting 17 events.
      [18.11.2022 11:47.48.823] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
      [18.11.2022 11:47.53.057] [LOG]   transiting to state: listening
      [18.11.2022 11:48.00.703] [LOG]   transiting to state: busy
      [18.11.2022 11:48.05.905] [ERROR] <html>
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>We're sorry!</title>
      </head>
      <body style="padding: 4em; color: black; background-color: white; font-family: Verdana,Arial,Helvetica,sans-serif;">
      <h2>We're sorry!</h2>
      <p>
      An error occurred when we tried to process your request.
      Rest assured, we're already working on the problem and expect to resolve it shortly.
      </p>
      <h2>Désolés!</h2>
      <p>
      Une erreur s'est produite lorsque nous avons tenté de traiter votre requête.
      Soyez assuré que nous travaillons déjà à la résolution du problème que nous pensons trouver très rapidement.
      </p>
      </body>
      </html>
      [18.11.2022 11:48.05.907] [LOG]   transiting to state: idle
      [18.11.2022 11:49.47.260] [LOG]   Shutting down server...
      [18.11.2022 11:49.47.262] [LOG]   Stopping module helper: updatenotification
      [18.11.2022 11:49.47.263] [LOG]   Stopping module helper: calendar
      [18.11.2022 11:49.47.264] [LOG]   Stopping module helper: newsfeed
      [18.11.2022 11:49.47.265] [LOG]   Stopping module helper: MMM-awesome-alexa
        sdetweil @SojuSlushy
        @SojuSlushy said in MMM-awesome-alexa on Orange Pi LTS 4:
        this problem is related to the video GPU which electron tries to use by default…
        you can turn it off either way
        1. in the script process you use to start MM add the environment setting (if u start manually from a terminal window type this command there, before doing npm start)
          if you used my script to install, then the bash script used is ~/MagicMirror/installers/mm.sh
         export ELECTRON_DISABLE_GPU=1
        1. edit the ~/Magicmirror/package.json
          and change the start script clause from
        		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
        to
        		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --disable_gpu js/electron.js",
          SojuSlushy @sdetweil
          @sdetweil Thank you for your reply Sam.
          I tried your recommendation and ran export ELECTRON_DISABLE_GPU=1 and edited the ~/MagicMirror/package.json file to reflect the changes you mentioned above. However, now when I npm start within ~/MagicMirror I am seeing a black screen.
          This is what is returned below after I let it run for a couple of minutes and exit.
          cindy@orangepi4-lts:~/MagicMirror$ export ELECTRON_DISABLE_GPU=1
          > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron --disable_gpu js/electron.js
          [01.12.2022 21:26.02.260] [LOG]   Starting MagicMirror: v2.21.0
          [01.12.2022 21:26.02.267] [LOG]   Loading config ...
          [01.12.2022 21:26.02.274] [LOG]   Loading module helpers ...
          [01.12.2022 21:26.02.277] [LOG]   No helper found for module: alert.
          [01.12.2022 21:26.02.296] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.02.297] [LOG]   Module helper loaded: updatenotification
          [01.12.2022 21:26.02.298] [LOG]   No helper found for module: clock.
          [01.12.2022 21:26.02.521] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.02.522] [LOG]   Module helper loaded: calendar
          [01.12.2022 21:26.02.524] [LOG]   No helper found for module: weather.
          [01.12.2022 21:26.02.542] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.02.543] [LOG]   Module helper loaded: newsfeed
          [01.12.2022 21:26.02.572] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.02.574] [LOG]   Check MagicMirror² version for node helper 'MMM-NFL' - Minimum version: 2.15.0 - Current version: 2.21.0
          [01.12.2022 21:26.02.575] [LOG]   Version is ok!
          [01.12.2022 21:26.02.575] [LOG]   Module helper loaded: MMM-NFL
          [01.12.2022 21:26.03.058] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.03.058] [LOG]   Module helper loaded: MMM-GoogleAssistant
          [01.12.2022 21:26.03.257] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.03.258] [LOG]   Module helper loaded: Gateway
          [01.12.2022 21:26.03.262] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.03.262] [LOG]   Module helper loaded: EXT-Detector
          [01.12.2022 21:26.03.264] [LOG]   Initializing new module helper ...
          [01.12.2022 21:26.03.265] [LOG]   Module helper loaded: EXT-Alert
          [01.12.2022 21:26.03.265] [LOG]   All module helpers loaded.
          [01.12.2022 21:26.03.272] [LOG]   Starting server on port 8081 ...
          [01.12.2022 21:26.03.284] [LOG]   Server started ...
          [01.12.2022 21:26.03.284] [LOG]   Connecting socket for: updatenotification
          [01.12.2022 21:26.03.285] [LOG]   Starting module helper: updatenotification
          [01.12.2022 21:26.03.286] [LOG]   Connecting socket for: calendar
          [01.12.2022 21:26.03.286] [LOG]   Starting node helper for: calendar
          [01.12.2022 21:26.03.287] [LOG]   Connecting socket for: newsfeed
          [01.12.2022 21:26.03.288] [LOG]   Starting node helper for: newsfeed
          [01.12.2022 21:26.03.288] [LOG]   Connecting socket for: MMM-NFL
          [01.12.2022 21:26.03.289] [LOG]   Starting module helper: MMM-NFL
          [01.12.2022 21:26.03.289] [LOG]   Connecting socket for: MMM-GoogleAssistant
          [01.12.2022 21:26.03.291] [LOG]   [GA] Read config.js and check ConfigDeepMerge...
          [01.12.2022 21:26.03.291] [LOG]   [GA] Perfect ConfigDeepMerge activated!
          [01.12.2022 21:26.03.292] [LOG]   Connecting socket for: Gateway
          [01.12.2022 21:26.03.293] [LOG]   Connecting socket for: EXT-Detector
          [01.12.2022 21:26.03.294] [LOG]   [DETECTOR] EXT-Detector Version: 1.0.1 rev: 220315
          [01.12.2022 21:26.03.295] [LOG]   Connecting socket for: EXT-Alert
          [01.12.2022 21:26.03.296] [LOG]   Starting module helper: EXT-Alert
          [01.12.2022 21:26.03.296] [LOG]   Sockets connected & modules started ...
          [01.12.2022 21:26.03.624] [LOG]   Launching application.
          [9758:1201/212604.467252:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.467724:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.468061:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.468387:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.468799:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.469133:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.469452:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.469772:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.475242:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.475658:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.475969:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.476289:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.476617:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.476964:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.477288:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [9758:1201/212604.477625:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
          [01.12.2022 21:26.33.001] [LOG]   Shutting down server...
          [01.12.2022 21:26.33.008] [LOG]   Stopping module helper: updatenotification
          [01.12.2022 21:26.33.010] [LOG]   Stopping module helper: calendar
          [01.12.2022 21:26.33.011] [LOG]   Stopping module helper: newsfeed
          [01.12.2022 21:26.33.013] [LOG]   Stopping module helper: MMM-GoogleAssistant
          [01.12.2022 21:26.33.014] [LOG]   Stopping module helper: Gateway
          [01.12.2022 21:26.33.015] [LOG]   Stopping module helper: EXT-Detector
          [01.12.2022 21:26.33.017] [LOG]   Stopping module helper: EXT-Alert
            SojuSlushy
            @sdetweil Sorry if this duplicates but I couldn’t tell if the other reply went through.
              @SojuSlushy to stop spam, posts for users w reputation below 2 are reviewed before being posted.
                I do not know the cause of the error or any fix
